Evercool Royal
SUMMARY: An attractive unit, questionable performance
Box
Great packaging!
The good guys at Evercool were nice enough to send a sample of their Evercool Royal notebook cooling pad. This is one of the few I have seen which uses three fans.
Key Features:
  • Aluminum construction
  • Size: 400 x 300 x 40 (15¾” x 11.8″ x 1.6″); Weight: 1380 grams (3 pounds)
  • Three fans, 80 x 15 mm, 1500 rpm, <14 dBA, USB powered
  • Two USB Hubs
  • Two storage drawers
  • One USB patch cable
  • On/Off switch
This is a large pad which should accommodate larger laptops of the DTR type. The top cutouts are decorative and the whole appearance is well above anything I’ve seen in laptop coolers – although in use it will be hidden under the laptop.
Bottom
The bottom shows a very simple layout – basically three fans and two storage drawers:
Side
The side shows the On/Off switch and USB ports:
Drawer
The fans are 80x15mm, low noise:
Fan
Performance Test
I tested the Evercool Royal using a Compaq Presario 2200 laptop, with the following results:
Test
Stress (Prime 95)
Idle
CPU Die Temp – Fans ON
59-65ºC
49ºC
CPU Die Temp – Fans OFF
59-65ºC
51ºC
The temp range is due to the laptop’s fan cycling on and off. I would have expected to see more of a difference based on the difference in idle temps, but it is what it is. I even tried switching the fans from blowing out under the unit to blowing air onto the back of the laptop:
Fan
Fan
I found performance to be the same, so fan orientation is not an issue
CONCLUSIONS
An attractive unit, but I did not find cooling to be any better with it; I think the low-flow fans do not move enough air to make a substantial cooling difference.
Thanks again to Evercool for sending the Royal our way.
  1. Evercool 3.5″ Cool Wheel HD Cooler
  2. Evercool Sharks
  3. Evercool 610
  4. Evercool CUD-725
  5. Evercool Water Cooler Kit WC-201 Review
Tags:
