Some of us were at least a little disappointed with the GTX680′s …well, let’s say slightly under-built first offering. While they are performance behemoths, their intentionally hampered four-phase-with-blank-fifth-phase power section left something to be desired. EVGA has just announced their GTX680 FTW, with ”…an 8 Phase PWM design, an 8+6pin Power Input and Vapor Chamber cooling”, which sounds good to us.
These cards come clocked with a 1110 MHz base clock and 1176 MHz boost clock, a substantial increase over the stock offering. There is even a 4 GB version for those that thought the 2 GB initial release was a bit thin on video memory.
You can check out more details at EVGA’s page:
EVGA isn’t the only partner coming out with upgraded cards. ASUS has a GTX 680 DirectCU II that also has upgraded specs. While it has a stronger PWM (10-phase), its default clock is a little lower, at 1084 MHz boost clock.
Gigabyte and MSI have overclocked versions with upgraded cooling but don’t appear to have any physical PCB advantages over the stock card.
The GTX upgrade wars are under way and it looks like fun! Are any of you planning on jumping on the newly upgraded GTX 680s?
- Jeremy Vaughan (hokiealumnus)
Tags: 680, card, evga, ftw, Graphics, gtx, gtx 680, gtx680, new, nvidia, release
05-09-12 05:43 AM
Surely, the first thing to do is rip that off, put on better cooling and then overclock the hell out of it.
05-09-12 03:31 PM
The thin flat looking parts at the top of this heatsink are the ends of the vapor chamber, with heatpipes just outside them:
http://www.frostytech.com/articlevie...articleID=2654
05-09-12 06:26 PM
05-09-12 07:40 PM
05-09-12 07:46 PM
109715
05-09-12 10:12 PM
Though at the same time EVGA continues to have a very appetizing offering. TiN is a freak of nature, and you know that anything he puts work into is gonna perform quite a bit above expectations. I would be surprised if TiN didn't have at least some input into the design of this card. Since VGA power seems to be one of his party pieces.
05-09-12 10:29 PM
05-09-12 10:46 PM
Vastly more efficient than multiple small heatpipes.
The EVBot port on there looks promising
05-10-12 12:56 AM
05-10-12 04:15 AM
05-10-12 08:11 AM
http://www.evga.com/products/moreInf...s%20Family&sw=
05-10-12 02:28 PM
06-11-12 06:27 AM
