EVGA SuperSC 16GB DDR4-2800 Memory Kit Review
Add Your Comments
I was pretty surprised when I received the info that EVGA is offering a DDR4 memory kit for review. Somehow I missed the fact that EVGA had entered the DRAM market some time ago and has already presented DDR3 and DDR4 memory kits designed for both gamers and power users.
There is a good reason I could have missed the premiere of EVGA’s memory kits. This memory is available almost only in the USA, and I live in Europe. It simply isn’t available in local stores, even the EVGA online store for Europe isn’t selling memory kits. That’s enough about availability, let’s focus on the product itself.
Today’s review is based on the highest EVGA DDR4 quad channel kit – EVGA SuperSC 4x4GB DDR4-2800 CL16 1.2V. Lower series are named Superclocked and SuperSC is short for Super-Superclocked, giving very high expectations. We’ll check it out shortly.
Below you can see the other memory kits offered by EVGA.
Available EVGA Memory kits - Spec Chart
Available EVGA Memory kits – Spec Chart
Specifications and Features
EVGA_SSC_16GB_2800_grp2
Our review sample arrived in the retail package, which is a plastic clamshell. This transparent package is good enough to protect memory while letting us see what’s inside. No surprises here, it’s simply memory sticks inside. In this case it’s four of them since this is a quad channel kit.
EVGA SuperSC is memory designed for the X99 platform which, as I already mentioned, utilizes quad channel mode. I’ve additionally performed a couple of tests on the Z170 platform and had no problems with compatibility or stability. This is actually really good as many memory kits designed for the Haswell-E platform have run into problems on Skylake when using XMP profiles.
After opening the package we can read:
Engineered to Perform
EVGA Superclocked DDR4 Series memory is designed to provide excellent performance for the power user. Using carefully selected chips, optimal timings, a specially designed heat spreader – these modules deliver.
Optimized and tested for compatibility with the latest CPUs and Motherboards. Support for Intel XMP.
This doesn’t say much about the memory itself, but it gives promises that we will also check.
Product Photos
These EVGA memory modules use a black PCB which is then protected by black heatsinks, which gives very good aesthetics. Overall the design is not much different from other high end memory brands, and those designs are already accepted by enthusiasts and overclockers. It simply looks good and compliments most available motherboards. Of course it compliments EVGA’s motherboards which are mainly black pair nicely with this RAM.
The memory modules are based on Hynix IC’s. This is probably the best option for the X99 platform due to characteristics of these memory chips such as tight timings and the chance to run it at a frequency higher than it is rated for. High performance and high overclocking potential is what everyone is looking for in a high-end memory series. So far expectations are high regarding the EVGA SuperSC memory.
Stability at Rated Speed
EVGA SuperSC 16GB DDR4-2800 memory kit passed a few demanding tests including 5 hours of AIDA64 memory and cache stress test. Some readers can say it’s not enough but the testing took a couple of days and during this time there were no problems with stability.
Below is a screenshot of the mentioned 5 hour AIDA64 stability test. The test was performed on XMP settings.
EVGA_SSC_2800_st1
There is only one XMP profile, but that is enough for this type of memory. It’s working without issues on both the ASRock X99M Killer 3.1 and the ASUS Maximus VIII Hero which is based on the Intel Z170 chipset. As I already mentioned earlier, not all memory kits designed for the X99 chipset are working on the Intel Skylake platform, but in this case we shouldn’t have problems regardless of what platform we choose.
EVGA SSC 16GB DDR4-2800 on ASRock X99M Killer 3.1
Performance
EVGA_SSC_16GB_2800_grp1
Performance tests were performed on the popular Intel i7 5820K processor paired with a less popular, but great for overclocking (especially memory kits), ASRock X99M Killer 3.1 motherboard.
This platform isn’t anything unusual so readers shouldn’t have any problems comparing to results on their home computers. It is worth mentioning that the processor has been overclocked to 4.2GHz on the core and 3.5GHz on the cache to better show differences in memory performance. These settings are easy to achieve on any motherboard that is based on the X99 chipset.
Synthetic Memory Bandwidth and Calculation Tests
The first test will be AIDA64. This program has many diagnostic tools and also includes one of the best on the market benchmarks to measure memory and cache performance, so it’s perfect for all kind of memory reviews.
AIDA_EVGA_SSC_2800
Looking at our comparison, the EVGA SSC memory is performing well in AIDA64 memory tests. As expected it’s somewhere between DDR4-2666 and DDR4-3000 memory kits, with one exception where the G.Skill DDR4-2666 CL15 memory kit is slightly faster due to much tighter timings. However that difference isn’t big.
AIDA64 is performing tests in a multi-threaded environment while the next benchmark on our list, MaxxMem Preview, is only using a single-threaded test.
MMEM_EVGA_SSC_2800In MaxxMem we see a similar situation as in AIDA64, so EVGA SSC memory is about where is should be, right between lower and higher frequency memory kits. Also this time the difference in performance isn’t very significant. I would also like to add that most of the memory kits in this comparison are high end series with well designed XMP profiles. This only proves that EVGA did a good job designing its SuperSC memory series.
HPI_EVGA_SSC_2800To end this part of the performance tests we have HyperPi 32M, which is one of the more popular overclockers benchmarks. Its based on multi-threaded SuperPi calculations, making it better for new platforms. It also loves fast memory so it’s good for memory comparisons.
EVGA SSC DDR4-2800 memory is, again, in roughly the same place. The results are good in all bandwidth and calculation tests, so we can be sure that the XMP profile is well prepared just as EVGA promised.
Rendering and Tests Based on Daily Usage
This part of the testing is probably more important for most users. I will start with Cinebench which is one of the most popular rendering benchmarks.
CINE_EVGA_SSC_2800
Cinebench reacts well to memory bandwidth, but the Intel Haswell-E platform with its quad channel memory has good results regardless of the memory being used. This is probably the main reason that all our results in this benchmark are similar.
We can still see that increasing memory frequency is raising the benchmark score though. EVGA’s memory is performing well in this test, taking second place in our comparison.
3DM_EVGA_SSC_2800
Now it’s time for the Futuremark benchmarks. Above we can see the latest 3DMark Fire Strike and Fire Strike Ultra tests. Both tests are very demanding but, as with all 3D benchmarks, they are based more on graphics card performance than anything else. We can still see that memory performance slightly affects the processor and physics tests, which gives us small differences in the final scores.
EVGA SSC DDR4-2800 memory is not much slower than the DDR4-3000 memory. We can see that in Fire Strike Ultra the result was even slightly better, so I assume that on both frequencies the performance will be equal and gamers won’t see any difference.
PCM8_EVGA_SSC_2800
In PCMark 8 we can see bigger differences in scores, up to 200 points, which is significant considering that we are using the same processor, storage, and graphics card. In PCMark 8 both memory bandwidth and access time counts. We can see especially when comparing DDR4-2666 CL15-15-15 to DDR4-2800 16-16-16 memory kits. All the results of these kits are close to each other. We could also see similar situations in the calculation and bandwidth tests.
Overclocking
Overclocking is never guaranteed so the presented results may vary from results on other memory kits. I am not recommending overclocking if you do not know what are you doing. High voltages may damage hardware and it will not be covered by warranty.
At a standard voltage of 1.20V we can expect to set something like DDR4-2666 15-15-15 but at DDR4-2800 we won’t be able to set much better settings without raising the voltage.
At 1.35V, which is already the most common voltage for all DDR4-3000 or higher frequency memory kits, we are able to set DDR4-3000 15-15-15 or DDR4-3200 16-16-16. Both of these settings will give us similar performance in daily usage.
Below we can see the expected performance without additional timing tuning, meaning even less advanced users can set this easily. These settings also passed all our benchmarks like PCMark 8 and 3DMark.
EVGA SSC DDR4-2800@ 3000 CL15-15-15-35 1.35V
EVGA SSC DDR4-2800 @ 3000 CL15-15-15-35 1.35V
EVGA_SSC_2800_oc2
EVGA SSC DDR4-2800 @ 3200 CL16-16-16-36 1.35V
The maximum frequency achieved on our test platform was 1700MHz (DDR4-3400) at pretty tight CL16-17-17-36 main timings and command rate 1N. Voltage was in still in the reasonable range at 1.42V. This result wasn’t fully stable and only let us pass only less demanding tests. Below we can see the expected performance as tested in AIDA64.
Maximum Frequency - DDR4-3400 CL16 1.42V
Maximum Frequency – DDR4-3400 CL16 1.42V
Feel free to share your overclocking results on the Overclockers forums.
Conclusion
EVGA entered the memory market with very good products. As I mentioned at the beginning of this review, I was pretty surprised to see this memory simply because it has really limited availability. We can find it at the EVGA store, or exclusively at Micro Center where the price is much lower at about $130. It’s not cheap, but also not expensive. We’ll say it’s an average price for a 4x4GB DDR4-2800 memory kit nowadays.
EVGA SuperSC memory is well designed and passed all our tests without issues while showing high performance. The XMP profile even works on better Z170 motherboards, but typically with an updated BIOS.
Memory modules are all black, black heatsinks and PCB, which should match most motherboards on the market and all available EVGA motherboards if you wish to keep all components from one brand.
I hope that EVGA releases a wider line of DDR4 kits since we had the premiere of Intel Skylake. I also hope to see various colors of heatsinks and maybe a more unique design. Even though the modules look good, they are similar to what we can already see from other brands.
I also wish to see more aggressive memory settings like tighter timings or higher frequency. Right now the highest available version is presented in this review, the SuperSC DDR4-2800 16-16-16-36 1.20V memory kit. The specification is good and gives hope of high overclocking potential, but it’s a product designed for gamers and enthusiasts who may wish for something more above these already popular settings.
Since I mentioned overclocking, the EVGA SuperSC memory has a really high overclocking potential. We couldn’t stabilize it at the DDR4-3400 mark, but I guess it’s just a limit of the test platform as the timings used were pretty tight for such a high frequency and relaxing them was not helping at all. On the other hand, it gives me hope that maybe our readers will be able to achieve better results, as EVGA memory clearly has potential.
The EVGA Super SC 4x4GB DDR4-2800 memory kit is clearly worth recommending.
Overclockers_clear_approved
Click the stamp for an explanation of what this means
~ Bartosz Waluk (Woomack)
Leave a Reply
Discussion
  1. Love this memory for the price. Here in the states a 16gb 2400mhz ddr3 kit can be had for 85 bucks at micro center. Hard to beat that. Put it in all my systems kept the stock settings of 11-13-13-31 and just changed the command rate to 1t. stressed tested for 24hrs no errors. Best 85 bucks i spent. My First set i Actually got for 50 bucks as micro center had just got them and where advertising them. After a month they went up to 99 bucks and now they are 85 for the 16gb 2400 kits. Half the price for the smaller kits. And they also offer 1600mhz but once again for the price why not just grab the 2400 :)
