First Look: SOYO K7VTA-B
Add Your Comments
SUMMARY: An OK Socket A motherboard – competent but not as feature laden as the ABIT KT7 or ASUS A7V.
SOYO jumped into the Socket A motherboard market with its SOYO K7VTA-B. It features VCore and Multiplier adjustments, so we bought one to test out.
Notable Features
  • Multiplier adjustments by dipswitch (5 to 12.5)
  • FSB adjustments of 100, 1, 2, 3, 5, 7, 9, 10, 13, 15, 17 & 20
  • VCore adjustments in BIOS (range limited, .025 steps)
  • Five PCI slots, One ISA, no AMR nonsense
  • On-board Audio
  • Automatic shutdown if CPU fans fail (“FOC”)
  • CPU Temp Monitoring through in-socket thermistor
  • ATA 100 through the VIA chipset – no third party ATA 100 controllers
  • Two fan headers
  • Verbal prompts to aid in debugging boot problems
The VCore adjustments appear to have an upper limit – I could not go higher than 1.85 volts on my T-Bird 750 even though adjustments ranged from -0.1 to +0.25 volts, added to the CPU’s spec voltage. Anything that yielded a CPU voltage greater than 1.85 defaulted to 1.7 volts.
Dipswitches
As the pic shows, the dipswitch is quite small. It’s located on the upper right hand side of the board’s edge near the hard drive slots. I don’t think adjusting this switch inside a case is something you want to do on a routine basis.
Socket
The socket thermistor is a disappointment – it is located off center and does not come close to the CPU. The problem with this is that if you enable thermal shutdown of the CPU should it get too hot, by the time the thermistor registers the overheat situation, the CPU will probably have fried already. I noticed a very perceptible delay between temps I monitored using a heatsink thermistor and what I saw on screen with Motherboard Monitor.
Now this may seem like a sniggly point, but the socket only has two lugs on each side rather than the three you see on other boards. I did not like this as I use the two end lugs to hold down water blocks with a double clamp. If you break off a center lug, you have to repair it rather than use the two end lugs. However, note that the lug’s orientation allows you to mount a PEP66T very easily with unimpeded airflow.
I was not overwhelmed by SDRAM BIOS choices – there was not the usual “Fast” or “Turbo” settings you see on many other boards. The choices were limited to running SDRAM at 100 or 133 MHz, settings by SPD or User. The user can set CAS 2 or 3. There are Interleave settings – I enabled 4-Way Interleave for all benchmarks. Although skimpy, memory performance was competitive.
Cooling Considerations
One thing I have noticed in the heatsink testing we have been doing is that there are “secondary pathways” that impact CPU temps. One of these are the components you see arrayed around the socket. Compare what’s around the ABIT KT7 to the Soyo’s relatively cleaner arrangement, as shown below:
ABIT KT7
ABIT KT7
The ABIT board has a number of heat generating components close to the socket, most notably the VIA chipset and the power transistors. These heat sources warm up the board around the socket adding to the thermal load of the CPU’s heatsink.
SOYO
SOYO K7VTA-B
In comparison, the SOYO locates the VIA chipset further from the socket. In addition, the capacitors are not located as close to the socket as the ABIT board. Locating capacitors close to the socket not only interferes with heatsink mounting, but these capacitors act as heat conductors; with the heatsink blowing warm air onto them, it heats them up, raises board temperatures and can increase the CPU’s heat load by a degree or two.
I felt around the SOYO as it was running Prime95 and felt no hot spots as I did on the ASUS A7V (IMHO – one of the hottest running boards around).
Benchmarks
I benchmarked using SiSoft Sandra, 3DMark 2000 and Quake. The setup consisted of 128 MB HSDRAM, 7ns, Leadtek GeForce 2GTS, T-Bird 750 running at 1050 MHz, 1.85 volts, air-cooled using the Swiftech MC370-0A with Papst 33 cfm fan. Results:
SOYO K7VTA-B
Benchmark
Result
SiSoft CPU
2930/1464
SiSoft MultiMedia
3577/4907
SiSoft Memory
472/542
Quake Fastest
137.6/133.6
3DMark 2000
7879
3DMark 2000 800x600x16.
How does this stack up to, let’s say, the ASUS A7V running the same components and speed? My ASUS A7V yielded these results:
ASUS A7V
Benchmark
Result
SiSoft CPU
2962/1461
SiSoft MultiMedia
3613/4957
SiSoft Memory
469/556
Quake Fastest
140.5/137.1
3DMark 2000
8190
Very close on SiSandra, about 2-4% lower on the video benchmarks. I think the word is “competitive” but not “outstanding”.
I varied FSBs to see how high the SOYO could go, and was not able to get any higher than 105 MHz. My ASUS A7V and ABIT KT7 can run 110 MHz stable and post higher. This particular board did not have much headroom on FSBs – whether all will exhibit the same pattern is unknown.
Conclusion
Not a standout performer but not a slacker either. The inclusion of an ISA slot is an interesting choice and a handy one for those with 56K ISA modems. This strikes me as a competent board aimed at the upgrade market; the exclusion of the AMR slot would seem to point in that direction. The clear real estate around the socket is a plus for cooling.
Not the most feature rich board nor the handiest (small dipswitch), but a competitive entry from SOYO. At the right price, not a bad buy. If a future BIOS bypasses the dipswitch, even better.
Email Joe
Leave a Reply
