SUMMARY: A newcomer to the scene, the Fortis A102 proves to be a very competitive heatsink for Socket A/370 CPUs.
The good folks at Fortis Technology kindly send over three heatsinks for us to test out – the A102 is the most aggressive heatsink of the three (I’ll report on the other two shortly). This is a relatively tall unit compared to the more compact copper units we have been testing, although much lighter due to its aluminum body.
This is another copper/aluminum hybrid, featuring a copper base and aluminum fins. The fins have an interesting feature:
You will notice that there are two “bumps” on each fin – these appear to be punchouts designed to increase turbulence, thereby increasing efficiency. I have not seen this technique used too often, although I have seen similar “bumps” on some radiator fins.
The base is a copper plate that is free from machining marks. One edge is roughly finished, but this did not affect performance. It is 5mm thick (about 3/16″) at the thickest point.
The fan is another Delta 38 clone – this one by Young Lin Tech, model # DFC602512D, 7000 rpm at 7.8 watts; don’t hook this one up to your motherboard’s fan connectors! It is louder than the Delta 38 – I measured it at 72 dBA compared to 70 dBA for the Delta 38 (8″ from the fan’s intake). In addition, I found this fan to have a very annoying high-pitch whine to it – reminded me of a vacuum cleaner you might hear in an adjacent room.
The clip is user-friendly – you don’t need a screwdriver to put this one on. It has good tension and I found it easy to mount and dismount. It is not indexed, so make sure the base does not ride over the bump on the socket.
I prepared the Fortis A102 by boring a hole completely through the base so I could epoxy a thermocouple above the CPU. The thermocouple is attached to an Omega HH23 Digital Thermometer. Ambient temps were measured with a thermocouple placed about 1 inch from the fan’s intake. I used Prime 95 to stress a T-Bird, Duron, Palomino and PIII on an Iwill KK266+, ABIT KT7 and Iwill BD133 (MBM temps are on-die). Arctic Silver grease was used in all tests. CPU Case Temp is the temp at that point where the CPU contacts the heatsink, CPU Back Temps are measured by a thermocouple on the center back of the CPU.
| CPU/Motherboard |
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
CPU Back Temp
| T-Bird 650 @ 1000/Iwill KK266+ (70 watts) |
44.4 C
29.1 C
15.3
0.22
46 C
49.3 C
| T-Bird 1133 @ 1300/ABIT KT7 (83 watts) |
46.4 C
28.4 C
18.0
0.22
51 C
55.2 C
| T-Bird 1133 @ 1397/Iwill KK266+ (89 watts) |
47.7 C
31.1 C
16.6
0.19
48 C
59.2 C
| Palomino 1200 @ 1330/Iwill KK266+ (68 watts) |
42.6 C
27.3 C
15.3
0.23
41 C
49.4 C
| Duron 800 @ 1000/ABIT KT7 (63 watts) |
43.8 C
29.0 C
14.8
0.24
45 C
49.1 C
| PIII 700 @ 933/Iwill BD133 (26 watts) |
32.5 C
25.6 C
6.9
0.27
40 C
NA
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Very competitive C/Ws – results place the A102 in the lower range of heatsinks testing at C/Ws of 0.30 or less. When I see results in the lower ranges, I extend the testing to various CPUs and platforms over different days. In evaluating the range of results, I would recommend that users expect C/Ws of about 0.22 at best.
The Fortis A102 is competitive with a number of all-copper models and is worth serious consideration for Socket A cooling. However, fan noise is a real consideration – some users have abandoned Delta 38s due to excessive noise and the fan on the A102 is noisier.
Fortis includes a tube of silver grease and an “Owner’s Manual” (shows how to mount heatsinks) – both a nice touch. A power adapter to allow the use of a four pin plug should be included as well.
The packaging is nicely done. Fortis includes the phrase “Designed by OVERCLOCKERS” – this is a generic term – we have not participated in any way with Fortis on these products.
Related posts:
- Fortis A102 Pro
- JAMITECH 5E34B3
- Epoxy for CPU Cooling
- Thermaltake Volcano II
- Silver vs Copper Plates
Tags: Cooling
