- Nov 12, 2002
- Rootstown, OH
Welcome Asus MVG owners. The first post of this thread will share resources available for you. The replies and comments are for you to suggest additions to the first post, ask any MVG related questions, and connect with other MVG owners.
I have one of these personally, so I'll be sharing what I find on the subzero cooling side of things.
Reviews:
Maximus V Gene Z77 mATX Review @ Overclockers.com
HardwareCanucks - Guru3D.com - TechRadar.com - KitGuru.net - HiTechLegion.com - Motherboards.org - Eteknix.com - Reply to thread to add another review!
BIOS - Official:
BIOS - Un-official:
Tools:
MemTweakit - View attachment MemtweakIt-1016-setup.zip
Tweaking Guides:
m5gguide - View attachment m5gguide.pdf - LN2 tweaking by Shamino
Advice:
Results:
Results are sorted by Cooling/S-Spec/Batch Number/Frequency. Reply below to add your results.
LN2
I.M.O.G. - S-Spec: SR0PL - Batch: L206A973 - 5720MHz
Reviews:
BIOS - Official:
- 05/11/12 - Version 0813 View attachment MAXIMUS-V-GENE-ASUS-0813.zip - Improve Improve system stability, enhance compatibility with some USB devices, support new CPUs
- 04/18/12 - Version 0701 View attachment MAXIMUS-V-GENE-ASUS-0701.zip - 1.Improve system stability, 2.Improve memory compatibility, 3.Fixed S4 resume fail with Windows 8. (Fixes TurboV Failure to launch in certain versions of Winxp, Improves Full DIMM population overclocking when using Command Rate 1T)
- 03/29/12 - Version 0602 View attachment MAXIMUS-V-GENE-ASUS-0602.zip - First release Bios
- Reply to thread to add another BIOS!
BIOS - Un-official:
- 6/10/12 - Version 0904 View attachment MAXIMUS-V-GENE-ASUS-0904.zip - improves clear cmos, fix TCL12 boot problem
- 5/31/12 - Version 0086 View attachment MAXIMUS-V-GENE-ASUS-0086.zip - Added SPI Booster option, enable to see if can boost superpi times slightly
- 5/8/12 - Version 0078 View attachment MAXIMUS-V-GENE-ASUS-0078.zip - improve command rate 1T stability
- 05/3/12 - Version 0075 View attachment MAXIMUS-V-GENE-ASUS-0075.zip - added in one small tweak slightly updated
- 05/2/12 - Version 0074 View attachment MAXIMUS-V-GENE-ASUS-0074.zip - Updates dram tuning, memory presets, fix 6950 flash to 6970 bootup issue, fix rog connect show dram voltage wrongly, adds cpu ratio adjust to rog connect (pending fix: high Frequency 2Dimm/Chanel with Command Rate 1T)
- 04/23/12 - Version 0881 View attachment MAXIMUS-V-GENE-ASUS-0881.zip - Fixed data vref bug
- 04/18/12 - Version 0880 View attachment MAXIMUS-V-GENE-ASUS-0880.zip - Updates system compatibility, Improves performance, Improves DRAM Overclocking (bug: "Another bug with 0880 pls set DRAM Data VREF manually @ 0.50 or 0.495 since sometimes it is wrong with this bios")
- 04/13/12 - version 0805 View attachment MAXIMUS-V-GENE-ASUS-0805.zip - Added DRAM Tuning, Improved Performance, Default enable thunder bolt support, IRST Update
Tools:
Tweaking Guides:
Advice:
http://kingpincooling.com/forum/showthread.php?t=1721
This thread (first post) at kingpin cooling shows how to enable LN2 mode, how to set slow mode, and some other tips.
and"Points to watch when running LN2 Cooling for the best cold-bug free runs:
- Use a BCLK of 105MHz or higher
- Find the right CPU PLL Voltage that your CPU likes (can be higher or lower than default)
- Some CPUs may only initialize their high IMC Frequency at a warmer temperature though they may work fine after that
- ‘23’ when trying to boot means cpu imc not able to run at that frequency at that temperature. ‘30’ means the same and a bit more = ‘23’
- Highest DRAM Ratio known to be working = 2933 ratio
With CPU and PSC Chipset DRAM under LN2, it can churn out crazy numbers such as 2x2GB @ 3036MHz CL6-11-7-1T!"
A note on LN2’ed DRAMs
PSC scales on cold but ~ frosted temps, maybe -40+C is enough to max out the rams. Might not work too cold. May scale up to ~ 1.95v
BBSE Really scales on cold, the colder the better. May scale up to ~ 2.30v
Samsung just slightly chilled, colder and it gets worse. May scale up to ~ 2.20v
Hynix scales on cold but ~ frosted temps, maybe -40+C is enough to max out the rams. May scale up to ~ 1.95vPSC are almost always 2GB sticks and typically have rated RAS to CAS Delay much higher than CAS, for eg 8-11-8, 9-11-9, etc
Hynix presets are for 4GB sticks that are usually rated 2133 or more and have slopping upwards and then downwards rated timing, such as 9-11-10, 10-12-11. They normally don’t scale much past 1.67v as well.
Samsung Presets are for 4GB sticks that are usually rated 2133 or more and have slopping upwards and then evening out rated timing, such as 10-12-12. They normally scale up to 1.80v and can do unusually low TRAS at high speeds, such as 21.
Some other very good stuff in there as well.
Results:
LN2
Frequency: 5.72GHz at 1.75V would do wp32 and wp1024. Trouble getting into windows at 5.8GHz, though with more time/voltage I believe it could do it.
http://hwbot.org/submission/2279683_
http://hwbot.org/submission/2279684_
ColdBug: Cold boot bugs at -85C at the base of the pot, cold bugs around -115C at the base of the pot (my current temp probe reads -180 when dipped in LN2, so actual readings on probe were -75C/-105C). Tested CPU PLL from 1.7V to 1.95V (default read 1.812 in BIOS). Tested bclk from 105-110, trouble getting higher bclk to post. Tested CPU voltage from 1.0V to 1.75V. None of these items, with or without LN2 mode enabled on the MVG, made any difference at all upon the cold bug behavior of this particular chip from what I found.
Other: I did not test RAM. Really only tested cold bug behavior, and once I found I couldn't work around it with anything I was trying, I didn't want to press the chip any harder - it will be sold. Looking to get another from a different store (and hopefully different batch) in the next week or two.
