I have a crucial 64GB RealSSD C300 as my main drive. I really don't want Windows taking up 16gb when I know that atleast 6gb is completely useless tablet pc, speech recognition, and language options.
I have tried using vLite and build after build after build after build has failed to install. I started with removing tons of things then down to removing next to nothing and still they all fail at some point during the install it usually says something about it causes a restart and that I need to start the install process over.
I am trying to make a build of Windows 7 Premium 64 Bit
I have spent over 4 hours pulling and reading. Most of the stuff is old information and seems like they are pulling more off than me.
Does anyone know the easiest way to remove just the big crap to get the install to be sub 8GB. Also I would probably like to completely avoid using vLite if there is another option as vLite just seems to be broke.
Also just fyi No I am not doing the test installs on the SSD as that many would probably take a toll!
