Overclockers Forums
Overclockers Forums (http://www.overclockers.com/forums/index.php)
-   AMD Motherboards (http://www.overclockers.com/forums/forumdisplay.php?f=5)
-   -   SATA port 1 and 2 (http://www.overclockers.com/forums/showthread.php?t=332863)
CyNics 09-30-04 05:20 PM
SATA port 1 and 2
heard that the sata port 1 and 2 isn't usable at high HTT (>230-240)
is that true? can anyone confirm this?
Jess1313 09-30-04 05:41 PM
i have experienced this
sata 1/2 gave me 235-245 max HTT
sata 3/4 i could go up to 345htt.
Gl
-Jess-
CyNics 09-30-04 06:39 PM
Gl
-Jess-
so any idea why this thing happens?
and also..
A) let say if I run my HTT at 230, and 5x LDT multiplier, I would 1150 right (and 4 working sata port)
B) wouldn't that faster than running my HTT let say..at 281 and 4x LDT multiplier, which will result a clock speed of 1120?
assume we use an a64 3200+ for case A
and an a64 2800+ for case B, so that the CPU speed of both cases runs at the same speed.
just asking for some guidance before deciding which A64 I should go with , cuz I really need all the SATA ports :)
Jess1313 09-30-04 07:03 PM
and also..
AFAIK its an issue w/ the NVidia sata bios, and i have heard that Oskar_WU is working on a new sata bios to try to resolve these sata Problems.
on the Htt thng, most of the time, i would say that the "fsb"(the final # after you do HTTxLDT multi, IE 1120) usually doesnt have that much effect, but the HTT, when ram is ran at 1:1, has a large affect.
i would venture to say, that if ram was ran at 1:1 that
270x2(540mhz) would be MUCH faster that 220x5(1100mhz).
CyNics 09-30-04 09:33 PM
thanks :) greatly appreciated :)
my plan is to run my BH-5 ram at 230Mhz at 2-2-2-10 ..since that's the sweetest spot (without having to overvolt them)..and also hitting 2.5ghz range with the a64 that Im going to get..
there is no way my current pair of BH-5 can hit 270..even at 3.3v..
I know I can do higher HTT and use the ram divider to reach 230, but as I've said, I need all the 4 sata ports..so until oskar comes out with a fix, guess my current option is to get the 3200+ :)
thanks again :)
lil layzie 10-01-04 08:29 AM
Sorry to hijack but I was wondering is there any performance differences from using sata ports 1 or 3?
CyNics 10-01-04 11:21 AM
as far as I know..nope..
even if it existed, sata port 3 and 4 should be faster than 1 and 2..that's if this issus existed
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright ©2000 - 2013, iNET Interactive
