Overclockers Forums
Overclockers Forums (http://www.overclockers.com/forums/index.php)
-   Alternative Operating Systems (http://www.overclockers.com/forums/forumdisplay.php?f=25)
-   -   Dual Boot? (http://www.overclockers.com/forums/showthread.php?t=51938)
two_dope2000 12-14-01 11:31 PM
Dual Boot?
Is it possible to Dual boot windows98se and Mandrake 8.1? im pretty sure ive heard of people doing this and i would have a clue as to where to start
SpeeDj 12-14-01 11:35 PM
Yes it as long as you currently have win98 already installed you can either press F1 when the Mandrake cd boots and type in LNX4WIN at the command prompt all this will do is create a folder within windows that will house Linux. It will also make linux run slower. The better way is to run the recommended setup by Mandrake and re partition your hd in order to format some of it and use Mandrakes filesystem. Once you are all through the setup and configured your comp will reboot and you will notice you have a few choices to boot, Linux, Windows, floppy, and I think a few more. Choose linux and finish your setup and viola all done!
Need more help just let me know
J
jbell 12-14-01 11:48 PM
J
linux non-bd
and
failsafe
I believe are the other two....
David 12-15-01 07:19 AM
Linux will still allow you to use Windows. It will set up a boot menu for you to choose each time you boot.
dolemitecomputer 12-16-01 05:39 PM
Before doing that I highly recommend getting a copy of Partition Magic and just create a partition for Linux and for the Linux swap file from your free space. For me it is easier to do and in case you want to make changes to the Linux partition i.e. make it larger or smaller you can do that from within windows without having to reinstall Linux altogether.
two_dope2000 12-16-01 05:41 PM
about 20 minutes after i started this thread i figured it out and i made two 60gig partitions one for linux and one for windows2k and windows98se
jbell 12-18-01 12:07 AM
60 is WAY too much for Linux - you only need 10-15G at most....
XWRed1 12-18-01 02:47 AM
Yea, you only need to feed Linux 60gb if you are seriously planning to use it as your main OS, and even then, that space would be going towards holding huge movies, tons of mp3s, large game installs, etc.
two_dope2000 12-18-01 02:55 PM
my hardrives fill very, very, quickly, wiht mp3s and movies and games and big big apps, im no longer running my hardrives in RAID now either.
two_dope2000 12-18-01 02:56 PM
my hardrives fill very, very, quickly, wiht mp3s and movies and games and big big apps, im no longer running my hardrives in RAID now either. I just thought id distribute my space evenly between the two OS's(3 counting win2K but thier on same partition)
David 12-21-01 03:56 AM
Linux used to reside on a 20GB Reiser partition but it wasn't even 33% full. I have Windows XP on one 15GB partition and I will soon have Linux (SuSE) on another 14GB.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2009, iNET Interactive
