Ok, I recently got my AROIA 1600+ processor and plopped it into my 75DRV5. At the time I had 2 sticks of 256MB Crucial PC2100 Cas 2.5 and I was able to hit 151 FSB stock multiplier for a real 1900+ with no stability issues.
I had heard a lot of good stuff about the AROIA and how it was able to hit 2000+ and 2100+ easily with air cooling. Well, I figured I just needed some PC2700 to give it some more headroom because the Crucial memory wasn't overclocking very well at all and I kept getting memory dump errors in WinXP.
I got my 512MB stick of Mushking PC2700 (the on-sale variety without the heat spreader) and pulled out the Crucial hoping to hit a magical 166 FSB or at least a 157 for a real 2000+
Well, after trying for awhile I could simply not go beyond 154 FSB without major stability issues in WinXP and the same memory dump errors. The processor is running at a cool 45C max under load with my Swiftech MCX452 but just won't push harder. Upping the voltage to 1.85 hasn't helped either. I think it is the memory just not able to push hard enough. What do you guys think? Anything I could do? Is there a way to divide the PCI bus to possibly get some more stability? Any way to OC the RAM? The only options I have in the BIOS are 133 and 166.
I just don't know what else to do. I've pretty much exhausted everything I know of for this setup and it is killing me to be sooo close to 2000+ but not there. Any suggestions from successful 75DRV/1600+/Mushkin PC2700 owners would be highly appreciated and any info from anyone else as well.
I'm going to dig around the Soltek manual and see if I can find any info and maybe get a few more MHZ until then.
