I have a eheim 1048 pump. I have the innovatek water cooling kit, if any of you are familiar with it. I have my pump on the bottom/front of the case. I have my rad in the back where the power supply should be ( I made a special plate for my RAD and PSU. Only half of the intake on the PSU is exposed cause of the RAD. ) I have a maximum of maybe 3 feet of hose altogether. The order in which I have my flow running is. RES/PUMP to RAD to WB back to RES/PUMP. The RAD is about 1 foot above the PUMP. About a 45 degree angle to travel upwards, then its DOWN the rad, to the WB, then down to the RES/Pump. I am getting almost 45C under load. I am pretty dissapointed. I need a second 120mm fan for the RAD, But what else can I do to help cool it down, Is there anything wrong with my setup? Some advice would be great.
I am running:
1900+ @1800Mhz @ 1.85V (Unlocked)
Corsair PC 2100 Ram
ABit KR7A-133
Ati Radeon 8500 64MB DDR 275/275
Linksys Network card 10/100
Sound Blaster Audigy X-Gamer
I am running:
Corsair PC 2100 Ram
ABit KR7A-133
