- Jul 13, 2002
- United Kingdom
Just finished putting my new system together and I can't even get into the BIOS.
At the moment i'm temporarily using my old Nvidia TNT2 M64 card and all i get is the BIOS screen for the GFX card, then the system just hangs.
If I power up whilst holding delete then I can get into the BIOS but the system still hangs and I cant adjust any of the BIOS settings. There is a message on the right hand side of the screen saying that because I set the incorrect frequency for the CPU, it caused the system to hang and that it is now running in safe mode.
The problem is not with the GFX card as i'm using it now in another Pentium machine and it's working fine.
The mobo is set to Jumper Free mode. Tried clearing the BIOS but still I get the same proble
Can someone please help me out? I really wanted to get Win XP installed tonight.
