- Aug 22, 2002
- london
Hi,
Just to explain before i go on, i know nothing about "cpu ratios" and "host clock setttings" so please go easy on me
I currently have a jetway v266b mobo running an xp2000+ and 256mb 2100ddr.
On visiting the jetway site they say the v266b will run with an xp2600+ processor. Now im not thinking about buying one, i would just like to understand how this board could run with this cpu.
Jetways list of supported CPUs (v266b)
I understand the 2600+ comes in 2 flavours a 133(266ddr) & 166(333ddr) is that right ?
Now this is where i get totally confused..........
The v266b has a fsb of 133(266ddr).
And there are jumpers on the mobo to set the "cpu ratio" which go from x5 upto x12.5
My xp2000+ is running @ 12.5 x 133 = 1662.5mhz
There is also an option in the bios to alter the "Cpu host clock" which goes from 133 to 166.
So the question is "how can you run an xp2600+ with this mobo ?"
Would'nt the cpu ratio need to be 15.5 x 133 = 2061.5mhz
(if the CPU is 133)
or would you do 12.5 x 166 = 2075
(if the CPU is 266)
(you get 166 by upping the "cpu host clock" in the bios).
Here is the v266b spec sheet from the jetway site
Now i know im bound to be totally missing the point somewhere. Im sure jetway know which cpus work on their mobos but this doesnt make any sense to me
Oh, and one more thing before my head explodes trying to work this out.......
I visited the Crucial site to find out how much 512mb of 2100DDR would cost and their "memory selector" tells my the v266b takes 2100ddr and 2700ddr ?
I thought 2700ddr was for 266(333) mobos ?
As you can see im a bit lost with all this stuff and would really appreicate some help understanding it all.
Thanks in advance,
Space"Noob"Monkey
ps/ didnt know if this should go in CPU area or MOBO area (its a bit of both).
(if the CPU is 133)
(if the CPU is 266)
Thanks in advance,
Space"Noob"Monkey
