Finally finished my WC set up!
dem1an
Suwanee
Well it's been a year and half or so since i first set out to build my watercooling rig. Started out with an AMD T-bird 1.33ghz and ended up with an Intel 2.53ghz. Final touches tonight were adding a relay to start my pump and dropping the 120mm rad fan to 7volts. May have to add a 2nd fan on the inside or a rheostat since my temp went up a bit after closing the case up. Tonight is the first night that my case has been closed since i started. Here's to laziness! Cheers!
P4 2.53 C1
512 Corsair XMS DDR
Asus P4PE
Enermax 431W
Ti4200 128MB
WD 200GB SE 8MB
Maze 2 with 478 adapter
Eheim
Cooling Cube
Here's a picture of it when I still had the AMD.
thanks! with the case open, i was getting temps of around 37 to 38C idle and around 38 or 39 when overclocked to 3Ghz. i don't remember what it was like under load sorry. with the case closed up now and the 120mm at 7volts, i'm getting around 40C, which is why i'm considering adding a 7volt 120mm push on the inside. i don't like noise. the case temp is at 28C now, so i guess my temps aren't that bad for an older set up. i also hear that the P4PE reads temps high. don't know. i know i'm out of date with the new heatercores and 1/2" tubing and newer blocks, but hey it works and it's pretty quiet. =)
i have no complaints about the case. it has a lot of places to stick things here and there.
