i'm most likely going to be getting a TC-4 for my first water cooling setup (ima n00b)... however i'm unsure of which one to get....poly topped or aluminum top. i'll be using a maxi-jet 900 and chevette heater core. people say to go with the aluminum top to avoid possible cracking from stress from barbs and tubes. but others say poly becuse it has no chance of having a "battery" effect. i will be using water wetter......so which top should i get?
and another quick q. what's the best way to get the 1/2" barbs on the chevette heatercore... i do'nt have access to a butane torch or watever. do i just use JB WELD?
i know this Q is asked 3769824985 times but i'll be using 1/2" barbs all around. should i use 1/2" or 3/8" tubing. only reason i ask is because i everyone asks what fittings AND barbs should they should use. i just need to know what size tubing for 1/2" barbs.
thanks
thanks
