- Nov 21, 2002
- Colorado, USA
I am sitting here pondering where I would want to place all the WCing components if I decided to go that way. And I have ran into more questions! Keep in mind I like a clean looking case, no rat nests.
(1)
I have a chenming/chieftec BD-01 case and I am considering putting the pump/resivour in my lower harddrive holder. I figure I could fit a 6x4x3.75 inch container in there (custom built of course). So in the resivour I would have that much water minus the size of the pump. I think I am getting the maxi-jet 1200 (unless there is something quite a bit better for under $30). So one of my questions are: How much water should I have circulating in the system? More GPH the better, is the more water circulating also the better? Note: I will probably have a gpu cooling also.
(2)
I think I am going to put the radiator at the top of my case, like a blow hole w/ 120mm fan. I would like to keep the whole under 6.5x6.5in. How big is the '86 chevy radiator? What other kind of radiators could I use? All radiator thoughts/suggestions would be good.
I don't want to over spend $12 just to get 2C cooler. I'm not the hardcore... yet. But I also want to do it right the first time.
Thanks again for ALL the help.
(1)
(2)
