- Oct 20, 2001
- Carbondale, IL
my board only has 1/5 divider, and my 9500pro and g3 ain't happy with it @ fsb200. can a 9700/pro or g4 stand it?
OC Noob said:Does it have to be "pretty" or a particular color?
Overclocker550 said:then pci speeds are not an issue for his card
Angry said:
Before anybody see this let me point this out, I may not be entirely correct but On ll boards, with teh exception of the nforce2, when you up the FSB, the PCI,AGP,IDE (and a few others)...speeds go up...
The general rule is:
PCI=33mhz
AGP 1x=33mhz
AGP 2x=66mhz
AGP 4x=132mhz ( i think Not sure)
If you overclock the pic to say 40mhz then:
PCI=40mhz
AGP 1x=40mhz
AGP 2x=80mhz
AGP 4x=160mhz
Soo...I have a suggestion..after typeing all that out...Will your board let you set AGP to 2x? It should take some stress off teh card and make it stable...Yeah I know its meant for 8x but some 9xxx's have had trouble in the past running at that....
tainice said:
@ agp 2x, 9500pro won't even boot, g3 apg tearing. guess nforce2 is my only solution then...damn i hate it
