Pretty much. I really could not hear either one, even when it was just the pump running. I had to touch it to make sure it was on!wymjym said:was your 1048 just the same (sound & vibration) as the 1250?
wj
wymjym said:If yours are quiet, then they are quiet.
My 1250s would vibrate anything they were attached to. I'm certain that if I had left any of the 1250s in one of my cases (and it was isolated and secured) it would have shaken the rivets loose in very short order. As I'm sure you know, you are not removing the vibration but rather spreading it out a bit and also -hopefully- getting a little self cancelling at work.
If you would hold them (when pumping) your wrists would start to tingle then go numb. My easiest solution (after spending many days) was to go to remote system
wj
Literatii said:
Do you mean you put your WC gear in an external container?
