I've got 2 options on my new setup. I've got a chevette core with dual shroud/fan capability. Here's my problem......would there be a large change in temperature if I switched from 2 120x38mm fans that put out 130 cfm a piece, to 2 120x25mm fans that put out 88cfm a piece???? The reason I ask is the 120x38s I have work great, but they are extremely loud and they dont work well with temperature controlled circuits(such as the LM317). I would probably have better luck with PWM, but I want to avoid that route for awhile.
So what do you guys think.........would there be a large temp difference between the 2 different types of fans?
