- Sep 30, 2002
- Oregon
should I put my CPU block and my G4 block in series or parallel? the G4 block has 3/8th inch fittings, and the CPU has 1/2. I have a maxi-Jet 1200 and an 89 camaro HC with 5/8ths tubing.
also, when I get a NB block, should I use it in series or parallel?
oh, the CPU will be first in all cases, the order will be pump/res-->HC-->CPU(and G4?)-->(NB)-->(G4?)-->pump/res.
the things in perenthesis I have yet to install, and my pump is submerged in my res.
