- Jan 19, 2003
- Ottawa, Ontario
I've been mulling over the idea of changing out the fan on my Asus V8440 GF4 Ti4400 video card (the little orb) to something a little more powerful.
I'm wondering if this has already been tried (and if so, what were the results)?
After measuring the clearance I have available around the NV25 GPU (even measuring the white trace meant to define the boundary for the Nvidia GF4 reference cooler), I conclude there is enough space to fit this proposed cooling device.
Utilizing a Retail Celeron/P3 FC-PGA heatsink & fan (pic below), I would drill 2 holes to match the fastening points for the NVidia reference cooler. Utilizing some type of non-conductive bolting items, I would be able to fasten the device to the video card.
Note: I also took a look at the ThermalTake GF4 Copper Cooler Kit (here) and noted the measurements. 68mm x 60mm x 13mm (LxWxH). The Retail Celeron/P3 FC-PGA heatsink measures 64mm x 67mm x 26mm. (Celeron/P3 fan measures 70mm x 67mm x 25mm). I realize that this cooler will block the first PCI slot, however that is of no concern to me (have 4 others to utilize).
After looking at the bottom of the FC-PGA heatsink (pic below), you'll notice that the centre is raised slightly when compared to the rest of the block (understandable, as it did have to clear the Socket 370 CPU attachment interface).
Utilizing some non-conductive rubber washers which would be mounted on the 4 corners of the device, it could safely rest on the video card without completing any other circuits & shorting anything out.
Of course the standard Socket 370 clip would be removed (no use for it on a GPU).
Finally, the thermal pad would be removed and the heatsink would be lapped with 800 grit sandpaper to a fine smooth finish.
After physical attachment (with some Arctic Alumina compound) and bolting was completed, the modification would be complete.
Is what I'm proposing at all possible? Would the retail Intel CPU fan put out more CFM in a directed area than, say.. the ThermalTake GF4 Cooler Kit (50mm fan, 10.6 CFM @ 5500 RPM, 30 dbA)?
Suggestions? Comments? Feel free to voice them! Any and all help is appreciated!
