Hello,
I'm having problems overclocking my Duron 600.
If I raise the fsb any higher than 110 mhz, my pc crashes. I use SoftFSB to do this. When I use the 110 mhz FSB and then I reboot, I just get a black screen. I tried raising the voltage to 1.65 V, but this didn't help either.
I also tried the trick of connecting the L1 bridges, but it didn't work. I set the multiplier to 6.5 but it just booted at 600Mhz. I tried it with 2 different pencils but that didn't help.
I'm quite frustrated that I can only run my Duron @ 660 Mhz without being able to reboot while you guys seem to go to 900Mhz without any apparent problems.
My system:
AMD Duron 600 Mhz
PC 133 RAM
GeForce 256 (Creative)
ABIT KT7 (Non-Raid) MB
Any help is much appreciated.
Thanks,
mmg
My system:
AMD Duron 600 Mhz
PC 133 RAM
Thanks,
mmg
