- Oct 4, 2004
- Back in class =(
Edit
#!/usr/bin/perl
#mkplchroot.pl: a script to automate setting up a chroot with Perl modules
#Copyright (C) 2005 Christoph Otto
#This program is free software; you can redistribute it and/or
#modify it under the terms of the GNU General Public License
#as published by the Free Software Foundation; either version 2
#of the License, or (at your option) any later version.
#This program is distributed in the hope that it will be useful,
#but WITHOUT ANY WARRANTY; without even the implied warranty of
#MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
#GNU General Public License (http://www.gnu.org/copyleft/gpl.html#TOC1)
#for more details.
#this is where the chroot will be (doesn't need to exist when the script is run)
my $root="/home/stupid_chroot";
#this is the user and group who will own everything
my $chroot_user="nobody:nogroup";
#these are the Perl modules to install
my @install_mods = (
#"Devel::DProf",
#"LWP::Simple",
"DBD::SQLite","DBI",
#"CGI",
#"Storable",
#"Socket",
#"Fcntl",
#"GD::Graph::lines",
#"File::Copy",
#thise are the binaries to install
my @install_binaries = ("/usr/bin/perl",
"/bin/bash",
#"/usr/bin/strace",
#"/bin/sleep",
"/bin/ls",
"/bin/tar",
#These are the dynamically loaded libraries to install.
#If one of the binaries doesn't seem to run, check its strace output
#for any failed attempts to open a library. Unfortunately,
#there's no better way to check for these. The files lib is
#so ls can print user and group names and the dns lib is for anything
#that deals with network i/o.
my @install_dlibs = (
"/lib/libnss_files.so.2",
"/lib/libnss_dns.so.2",
#these are the special files to install in /dev
my @install_devs = (
"null",
"zero",
"urandom"
##########You shouldn't need to change anything below this line.##############
use Module::ScanDeps;
use File::Copy;
#this is where to put Perl's modules inside the chroot dir
my $perl_dir="/usr/share/perl5";
#this is filled with the libraries required by Perl modules
my @install_plibs = ();
#this contains all files to be installed as src => tgt
my %install_files = ();
#make the specified dir and any non-existant parent dirs
sub mkdir_p($)
my $full_path = shift;
my $curr_path = "";
#print "mkdir called with $full_path\n";
foreach my $dir (split /\//,$full_path) {
$curr_path .= "$dir/";
#print "checking for $curr_path\n";
unless ( -e "$curr_path" ) {
mkdir($curr_path);
#print "creating\n";
#copy a binary and libraries it depends on
sub chroot_copy($$)
#first param is binary, second is where it's copied to
my $binary = shift;
my $dest = shift;
print "copying $binary into chroot\n";
#use 'ldd' to get information about dependency libraries
open PIPE, "ldd $binary |";
while(<PIPE>){
$pipe_out .= $_;
close PIPE;
#print "ldd says: $pipe_out";
#get library names out of ldd's output
#eg:" libpthread.so.0 => /lib/tls/libpthread.so.0 (0xb7fb0000)"
#turn into: "/lib/tls/libpthread.so.0"
for my $library (split "\n", $pipe_out) {
#example:
#" libpthread.so.0 => /lib/tls/libpthread.so.0 (0xb7fb0000)"
$library =~ s/.* => //;
#"/lib/tls/libpthread.so.0 (0xb7fb0000)"
$library =~ s/ \(.*//;
#"/lib/tls/libpthread.so.0"
#only copy the file if it's not already in the chroot
if ( ! -f "$root/lib/$library" ) {
copy("$library", "$root/lib");
#special case because ld-linux.so.2 (aka linux loader)
#needs to be executable
if ( $library =~ /ld-linux/ ) {
system("chmod 555 $root/$library");
#copy the actual binary into the chroot and make executable
copy("$binary", "$root/$dest");
if ($dest eq "bin") {
system("chmod 555 $root/$dest/*");
#add a symlink so scripts with "#!/usr/bin/perl" work fine
if ("$binary" eq "/usr/bin/perl" ) {
mkdir_p "$root/usr/bin";
system("ln -s /bin/perl $root/usr/bin/perl");
#copy a module and dependencies into chroot
sub chroot_copy_perl_mod($)
#first param is the name of the module to copy, ie "GD::Graph::lines"
my $new_mod = shift;
#"GD::Graph::lines"
$new_mod =~ s/::/\//g;
#"GD/Graph/lines"
$new_mod =~ s/$/.pm/;
#"GD/Graph/lines.pm"
print "installing $new_mod Perl module...\n";
my @files = ();
my $mod_file;
#look at each directory in @INC to find where the module we want lives
foreach my $dir (@INC) {
if ( -f "$dir/$new_mod") {
$mod_file = "$dir/$new_mod";
last;
#use Module::ScanDeps to find all the dependencies (hopefully)
my %deps;
my $deps = scan_deps(
files => [ "$mod_file" ],
recurse => 1,
#keep stats for more interesting output
my $file_count = 0;
my $lib_count = 0;
#make sure the directory where the module will live exists
my $path = "$root/$perl_dir/$new_mod";
$path =~ s/\/[^\/]*$//;
mkdir_p($path);
#put the module in its places
copy "$mod_file", "$root/$perl_dir/$new_mod";
$file_count++;
#copy all dependency files (can be Perl modules, .so libraries or other)
#to their locations, putting libraries in an array for later copying
foreach my $file (keys %$deps) {
#find where the module lives
if (-f "$dir/$file") {
#check if it's a .so library, put on array if so (pun!)
if ( $file =~ /\.so$/ ) {
push @install_plibs, "$dir/$file";
$lib_count++;
#otherwise, it's a normal file so just put it in the
#Perl dir in the chroot
} else {
my $dir_name = "$root/$perl_dir/$file";
#strip off filename extension, use result as dir to put
#the module in.
#"/home/perl_chroot/usr/lib/perl5/GD/Graph/lines.pm"
$dir_name =~ s/\..*//g;
#"/home/perl_chroot/usr/lib/perl5/GD/Graph/lines"
#make the dir and copy the module
mkdir_p($dir_name);
copy "$dir/$file", "$root/$perl_dir/$file";
$file_count++;
#we're done with this file so don't keep looking through %INC
$found = 1;
last;
print "didn't find $file\n" unless $found;
$found = 0;
print "copied $file_count files and added $lib_count libraries to the queue\n";
return;
print "making dirs...\n";
for my $dir ("$root",
"$root/bin",
"$root/dev",
"$root/lib",
"$root/tmp",
"$root/etc",
"$root/$perl_dir",
if ( ! -e "$dir" ) {
mkdir_p($dir);
system("chmod 555 $dir");
system("chmod 555 $root");
system("chmod 777 $root/tmp");
print "installing Perl modules...\n";
#Perl modules
foreach my $mod (@install_mods){
chroot_copy_perl_mod($mod);
#I don't feel like writing a recursive version of chmod manually.
system("chmod 500 -Rf $root/$perl_dir");
print "installing libraries required by Perl modules...\n";
#This is so I don't copy the same lib more than once. It saves lots of time.
#XXX: I should probably just check whether the library exists before copying,
#but this code works fine.
my $prev_lib = "";
foreach my $lib (sort @install_plibs) {
chroot_copy($lib,"lib") unless $prev_lib eq $lib;
$prev_lib = $lib;
print "installing binaries...\n";
foreach my $binary (@install_binaries) {
chroot_copy($binary,"bin");
#create a minimal /etc/nsswitch.conf (see 'man nsswitch.conf' for more info)
print "writing config files...\n";
open NSS, ">$root/etc/nsswitch.conf";
print NSS "passwd: files
shadow: files
group: files
hosts: files dns
networks: files
protocols: files
services: files";
close NSS;
#make a minimal /etc/passwd containing only the user 'nobody'
open PASSWD, ">$root/etc/passwd";
print PASSWD "root:x:0:0:root:/:/bin/bash
nobody:x:65534:65534:nobody:/nonexistent:/bin/bash";
close PASSWD;
#make a minimal /etc/group containing only the group 'nogroup'
open GROUP, ">$root/etc/group";
print GROUP "root:x:0:root
nogroup:x:65534:";
close GROUP;
#copy some other important (either large or location-dependent) config
#files from the real /etc to the chroot's
for my $config ("localtime", "protocols", "services", "hosts") {
copy("/etc/$config", "$root/etc");
#take care of explicitly specified dynamic libraries
print "copying dynamic libraries...\n";
foreach my $dlib (@install_dlibs) {
chroot_copy($dlib,"lib");
#take care of explicitly specified special files
print "making devices...\n";
foreach my $dev (@install_devs) {
open DEVINFO,"ls -lh /dev/$dev |";
my $devinfo = <DEVINFO>;
close DEVINFO;
#get major and minor numbers of the device from 'ls'
#"crw-rw-rw- 1 root root 1, 5 Jun 11 14:04 /dev/zero"
$devinfo =~ /(\d+) *, *(\d+)/;
#$1="1",$1="5"
my $dev_maj = $1;
my $dev_min = $2;
system("mknod $root/dev/$dev c $dev_maj $dev_min");
#666 isn't bad. It prevents executions.
system("chmod 666 $root/dev/*");
system("chmod 444 $root/dev/null");
#Lazieness again. It's not like people are going to use this on windows.
system("chown $chroot_user -R $root")
#!/bin/bash
emerge sync;
emerge -uDv world;
emerge -v depclean;
revdep-rebuild -v;
dispatch-conf;
#!/usr/bin/env python
# Copyright 2005 Mike Caley
import datetime, gadfly, os, sys, wx
from optparse import OptionParser
CURRENT_YEAR = 2005
def CmdLineParser():
"""Gets and parses command line arguments."""
Options = OptionParser(version='0.1.1')
Options.add_option('-f', '--first', action='store_true', dest='first',
help='''Initialize the database and tables. Used when for the first
time the program starts up.''', default=False)
Options.add_option('-g', '--gui', action='store_true', dest='gui',
help='Enables the GUI application.', default=False)
opts, args = Options.parse_args()
return opts
def FirstRun():
"""Sets up the inital database and table. Execute this program with the --first option on a new installation."""
if not os.access(os.path.join(os.curdir, 'Database'), 0):
os.mkdir(os.path.join(os.curdir, 'Database'))
DBCon = gadfly.gadfly()
# Make database if one hasn't been made already
DBCon.startup('Kids', 'Database')
DBCur = DBCon.cursor()
# Make the table
DBCur.execute("CREATE TABLE Usage (Month VARCHAR(2), Day VARCHAR(2), Year VARCHAR(4), Hour VARCHAR(2), Minute VARCHAR(2))")
DBCon.commit()
def Error(ErrNo, TorW):
"""Function for handling the error number given as well as whether to \
display it as a test or window message."""
if ErrNo == 1000:
if TorW == 't':
print '''Error: No database
You must first initialize the database with the -f or --first switch.'''
sys.exit()
elif TorW == 'w':
wx.MessageBox('You must first initialize the database with the -f or --first switch.',
'Error: No database', wx.OK|wx.ICON_ERROR)
def TranslateMonth(Month):
"""Translates the number representation of a month into the string representation."""
if Month == 0:
return 'Janurary'
elif Month == 2:
return 'February'
elif Month == 3:
return 'March'
elif Month == 4:
return 'April'
elif Month == 5:
return 'May'
elif Month == 6:
return 'June'
elif Month == 7:
return 'July'
elif Month == 8:
return 'August'
elif Month == 9:
return 'September'
elif Month == 10:
return 'October'
elif Month == 11:
return 'November'
elif Month == 12:
return 'December'
def NumberOfDays(Month):
"""Returns the number of days in a month."""
if Month == 'January' or 'March' or 'May' or 'July' or 'August' or 'October' or 'December':
return 31
elif Month == 'April' or 'June' or 'September' or 'November':
return 30
elif Month == 'February':
return 28
def Add():
"""Adds a record to the database showing that it was used."""
CurMonth = TranslateMonth(datetime.date.today().month)
CurDay = str(datetime.date.today().day)
CurYear = str(datetime.datetime.today().year)
CurHour = str(datetime.datetime.today().hour)
CurMin = str(datetime.datetime.today().minute)
try:
DBCon = gadfly.gadfly('Kids', 'Database')
except IOError:
Error(1000, 't')
else:
# Cursor initalization
DBCur.execute("INSERT INTO Usage (Month, Day, Year, Hour, Minute) VALUES ('%s', '%s', '%s', '%s', '%s')" % (CurMonth, CurDay, CurYear, CurHour, CurMin) )
DBCon.commit()
class KidsFrame(wx.Frame):
"""The basic window for the GUI framework."""
def __init__(self, parent, id, title):
wx.Frame.__init__(self, parent, id, title)
# Type of query
self.QueryType = wx.ComboBox(self, -1, 'Query Type', choices = ['Average', 'Total'])
# Month combobox
months = ['January', 'February', 'March', 'April', 'May', 'June',
'July', 'August', 'September', 'October', 'November',
'December']
self.MonthBox = wx.ComboBox(self, -1, 'Month', choices = months)
# Year combobox
years = list()
for n in range(CURRENT_YEAR, CURRENT_YEAR + 1):
years.append(n)
self.YearBox = wx.ComboBox(self, -1, 'Year', choices = years)
# Submit button
SubmitButton = wx.Button(self, -1, 'Submit')
# Bind button event
SubmitButton.Bind(wx.EVT_BUTTON, self.SelectData)
# Output text
self.OutputText = wx.StaticText(self, -1, style = wx.ALIGN_CENTRE)
TopSizer = wx.BoxSizer(wx.HORIZONTAL)
TopSizer.Add(self.QueryType, flag = wx.ALL | wx.EXPAND, border = 5)
TopSizer.Add(self.MonthBox, flag = wx.ALL | wx.EXPAND, border = 5)
TopSizer.Add(self.YearBox, flag = wx.ALL | wx.EXPAND, border = 5)
TopSizer.Add(SubmitButton, flag = wx.ALL | wx.EXPAND, border = 5)
MainSizer = wx.BoxSizer(wx.VERTICAL)
MainSizer.Add(TopSizer)
MainSizer.Add(self.OutputText, flag = wx.ALL | wx.EXPAND, border = 5)
self.SetSizerAndFit(MainSizer)
def SelectData(self, event):
SelMonth = self.MonthBox.GetValue()
SelYear = self.YearBox.GetValue()
try:
except IOError:
Error(1000, 'w')
else:
DBCur.execute("SELECT Month, Year FROM Usage WHERE Month = '%s' AND Year = '%s'" % (SelMonth, SelYear))
SelectedText = DBCur.fetchall()
if self.QueryType.GetValue() == 'Total':
self.OutputText.SetLabel( 'Total monthly usage for ' + SelMonth + ' ' + SelYear + ' is ' + str(SelectedText.__len__() / 2) + " hours" )
if self.QueryType.GetValue() == 'Average':
self.OutputText.SetLabel( 'Average daily usage for ' + SelMonth + ' ' + SelYear + ' is ' + str( float( SelectedText.__len__() ) / float(NumberOfDays(SelMonth) )) + ' hours')
class KidsApp(wx.App):
def OnInit(self):
KidsDB_Frame = KidsFrame(None, -1, 'KidsDB')
KidsDB_Frame.Show(True)
self.SetTopWindow(KidsDB_Frame)
return True
if __name__ == '__main__':
Opts = CmdLineParser()
if Opts.first:
FirstRun()
elif Opts.gui:
KidsDB = KidsApp()
KidsDB.MainLoop()
else:
Add()
#!/bin/bash
while let 1; do
date >>memlog; cat /proc/meminfo >>memlog; sleep 1m
done
#!/bin/sh
# kernel update script
# created by: matt bentley
# created: 09/10/2006 13:37
# updated: 09/10/2006 14:35
# usage: run script in the form: './kernel_update $kernel' where $kernel is the kernel you wish to use
if [ -z $1 ]; then
echo "error! please specify which kernel version you which to use"
echo "(example: './kernel_update2.sh 2.6.16.20')"
else
# install required debian packages from repository
echo "---INSTALLING NECESSARY PROGRAMS---"
sleep 3
apt-get install kernel-package ncurses-dev fakeroot wget bzip2 module-init-tools initrd-tools procps
# change pwd to /usr/src directory
cd /usr/src
# remove previous link to linux source
echo "---REMOVING PREVIOUS SOURCE LINKS---"
sleep 3
rm -r linux
# remove any files from old build
echo "---REMOVING OLD BUILD FILES---"
sleep 3
rm -r linux-$1
if [ -e /usr/src/linux-$1.tar.bz2 ]; then
echo "---NO DOWNLOAD IS NECESSARY, PROPER SOURCE FOUND---"
sleep 3
echo "---EXTRACTING SOURCE---"
sleep 3
tar -xjf linux-$1.tar.bz2
else
echo "---DOWNLOAD REQUIRED, DOWNLOADING PROPER SOURCE---"
sleep 3
wget http://www.kernel.org/pub/linux/kernel/v2.6/linux-$1.tar.bz2
sleep 3
fi
# create symbolic link
ln -s linux-$1 linux
# change pwd to /boot directory
cd /boot
# copy old config from current kernel
echo "---COPYING CONFIG FROM CURRENT KERNEL---"
sleep 3
cp config-$(uname -r) /usr/src/linux/.config
# change pwd to /usr/src/linux
cd /usr/src/linux
# build menuconfig
echo "---BUILDING MENUCONFIG---"
sleep 3
make menuconfig
# build interdependencies in the kernel sources
echo "---BUILDING INTERDEPENDENCIES---"
sleep 3
make dep
# purge unwanted files from previous builds
echo "---PURGING OLD FILES---"
sleep 3
make clean
# make the kernel image
echo "---COMPILING KERNEL IMAGE---"
echo " (this may take a while)"
sleep 3
#make zImage
make bzImage
# make the modules
echo "---COMPILING KERNEL MODULES---"
sleep 3
make modules
# installing the new kernel
echo "---INSTALLING NEW KERNEL---"
sleep 3
#cp /usr/src/linux/arch/i386/boot/zImage /boot/vmlinuz-$1
cp /usr/src/linux/arch/i386/boot/bzImage /boot/vmlinuz-$1
# install the new modules
echo "---INSTALLING NEW MODULES---"
sleep 3
make modules_install
# install the new system.map
echo "---INSTALLING NEW SYSTEM.MAP---"
sleep 3
cp /usr/src/linux/System.map /boot/System.map-$1
# setup grub
echo "---SETTING UP GRUB---"
sleep 3
update-grub
# copy new config
echo "---COPYING NEW CONFIG TO BOOT---"
sleep 3
cp /usr/src/linux/.config /boot/config-$1
fi
#!/usr/bin/perl
use strict;
use warnings;
# find tty and user
print "...Finding my current TTY and user info:\n";
my ($tty, $user);
my @tmp = split(/\s+/, `ps aux | grep blast_ttys | grep -v grep`);
($tty, $user) = ($tmp[6], $tmp[0]);
@tmp = split(/\//, `cat /etc/passwd | grep $user`);
my $shell = pop(@tmp);
chomp $shell;
sleep 2;
print "\nmy tty is ".$tty."!\n";
print "my user is ".$user."!\n";
print "my shell is ".$shell."!\n";
# find other ttys I own
print "\nFinding other TTYs I own:\n";
my @otherTtys = `w | awk '\$1 ~ /$user/ {print \$2}' | grep -v $tty`;
foreach (@otherTtys) {
chomp;
print "...found: ".$_.".\n";
# find the shells and kill them
print "\n...Finding process info for other TTYs:\n";
my (@psOut, @shellPids);
@tmp = `ps aux | grep $_ | grep $user | grep -v grep`;
push @psOut, @tmp;
foreach (@psOut) {
if (/$shell/) {
@tmp = split;
print "I'm going to blast/kill this pid: ".$tmp[1].".\n";
push @shellPids, $tmp[1];
foreach (@shellPids) {
`kill -9 $_`;
# gPyCompile v0.1.1
# Written by Alec Hussey
# License: General Public License
import os, compiler
from wx import stc
from wxPython.wx import *
ID_OPEN = 100
ID_SAVE = 105
ID_EXIT = 110
ID_COMPILE = 120
ID_SYNTAXCHECK = 125
ID_RUNPROGRAM = 130
ID_ABOUT = 150
class gpycFrame(wxFrame):
def __init__(self, parent, ID, title):
wxFrame.__init__(self, parent, ID, title, wxDefaultPosition, wxSize(700, 500))
self.Filename = ""
self.Directory = ""
self.TextControl = stc.StyledTextCtrl(self, 1, style=wxTE_MULTILINE)
self.CreateStatusBar()
fileMenu = wxMenu()
fileMenu.Append(ID_OPEN, "&Open", "Open a file.")
fileMenu.Append(ID_SAVE, "&Save", "Save the current file.")
fileMenu.AppendSeparator()
fileMenu.Append(ID_EXIT, "E&xit", "Terminate the application.")
sourceMenu = wxMenu()
sourceMenu.Append(ID_COMPILE, "Compile", "Compile the program to bytecode.")
sourceMenu.Append(ID_SYNTAXCHECK, "Syntax Check", "Check syntax of the program.")
sourceMenu.Append(ID_RUNPROGRAM, "Run Program", "Run the newly compiled program.")
helpMenu = wxMenu()
helpMenu.Append(ID_ABOUT, "&About", "More information about the program.")
menuBar = wxMenuBar()
menuBar.Append(fileMenu, "&File")
menuBar.Append(sourceMenu, "S&ource")
menuBar.Append(helpMenu, "&Help")
self.SetMenuBar(menuBar)
self.Show(True)
EVT_MENU(self, ID_OPEN, self.OnOpen)
EVT_MENU(self, ID_SAVE, self.OnSave)
EVT_MENU(self, ID_EXIT, self.OnExit)
EVT_MENU(self, ID_COMPILE, self.OnCompile)
EVT_MENU(self, ID_SYNTAXCHECK, self.OnSyntaxCheck)
EVT_MENU(self, ID_RUNPROGRAM, self.OnRunProgram)
EVT_MENU(self, ID_ABOUT, self.OnAbout)
def OnOpen(self, event):
opendialog = wxFileDialog(self, "Choose a File", self.Directory, "", "*.py", wxOPEN)
if opendialog.ShowModal() == wxID_OK:
self.Filename = opendialog.GetFilename()
self.Directory = opendialog.GetDirectory()
try:
try:
fopen = open(os.path.join(self.Directory, self.Filename), "r")
self.TextControl.ClearAll()
self.TextControl.AddText(fopen.read())
except IOError:
msgdialog = wxMessageDialog(self, "An exception was triggered. Couldn't open file.", "IO Error", wxOK | wxICON_ERROR)
msgdialog.ShowModal()
msgdialog.Destroy()
except UnicodeDecodeError:
msgdialog = wxMessageDialog(self, "An exception was triggered. Invalid encoding or encoding not supported.", "Unicode Decode Error", wxOK | wxICON_ERROR)
msgdialog.Destroy()
fopen.close()
def OnSave(self, event):
if self.Filename != "" and self.Directory != "":
try:
fopen = open(os.path.join(self.Directory, self.Filename), "w+")
fopen.write(self.TextControl.GetText())
except IOError:
msgdialog = wxMessageDialog(self, "An exception was triggered. Couldn't write to file.", "IO Error", wxOK | wxICON_INFORMATION)
msgdialog.Destroy()
fopen.close()
def OnExit(self, event):
self.Close(True)
def OnCompile(self, event):
self.SetStatusText("Compiling program...")
compiler.compileFile(str(os.path.join(self.Directory, self.Filename)))
self.SetStatusText("Complete")
# Show message dialog
msgdialog = wxMessageDialog(self, "File was compiled successfully.", "Information", wxOK | wxICON_INFORMATION)
msgdialog.Destroy()
else:
msgdialog = wxMessageDialog(self, "You don't have any files open.", "Information", wxOK | wxICON_INFORMATION)
msgdialog.Destroy()
def OnSyntaxCheck(self, event):
self.SetStatusText("Checking syntax...")
try:
compiler.parse(self.TextControl.GetText())
except SyntaxError:
errdialog = wxMessageDialog(self, "An error was found in your code.\n\n"+`compiler.ast.Module`, "Syntax Error", wxOK | wxICON_ERROR)
errdialog.ShowModal()
errdialog.Destroy()
return False
msgdialog = wxMessageDialog(self, "No errors were found in your code.", "Information", wxOK | wxICON_INFORMATION)
msgdialog.Destroy()
else:
msgdialog = wxMessageDialog(self, "You don't have any files open.", "Information", wxOK)
msgdialog.Destroy()
def OnRunProgram(self, event):
self.SetStatusText("Running program...")
self.filecheck = open(os.path.join(self.Directory, self.Filename))
if not self.filecheck:
msgdialog = wxMessageDialog(self, "Either you have deleted the compiled program or you have not yet compiled it.", "Information", wxOK | wxICON_ERROR)
msgdialog.Destroy()
self.SetStatusText("Error Running Program")
else:
try:
os.popen("python " + os.path.join(self.Directory, self.Filename+"c"))
except:
msgdialog = wxMessageDialog(self, "An error occured while running the program.", "Information", wxOK | wxICON_ERROR)
msgdialog.Destroy()
else:
msgdialog.Destroy()
def OnAbout(self, event):
dialog = wxMessageDialog(self, "gPyCompile 0.1.1 \n\n"
"A simple GUI for the Python bytecode compiler.\n\n"
"Writen by Alec Hussey\n"
"Contact: [email protected]",
"About", wxOK | wxICON_INFORMATION)
dialog.ShowModal()
dialog.Destroy()
class gpycApp(wxApp):
def OnInit(self):
frame = gpycFrame(NULL, -1, "gPyCompile")
frame.Show(True)
self.SetTopWindow(frame)
return True
application = gpycApp(0)
application.MainLoop()
#!/usr/bin/perl
#use CGI ':standard';
sub str_replace {
my $replace_this = shift;
my $with_this = shift;
my $string = shift;
my $length = length($string);
my $target = length($replace_this);
for (my $i = 0; $i < ($length - $target + 1); $i++) {
if (substr($string, $i, $target) eq $replace_this) {
$string = substr($string, 0, $i) . $with_this . substr($string, ($i + $target));
#return $string;
return $string;
sub get_links {
my $i = 0;
my $prefix = "contents[";
my $prefix2 = "]='<font size=\"2\" face=\"Arial\"><b>";
my $suffix = "</b></font>'";
open(LINKSDB, "linksdb.txt") or die "Error opening file.";
for $line (<LINKSDB>) {
@links = ($prefix, $i, $prefix2, $line, $suffix);
$links_dict .= join('', @links)."\n";
$i++;
close LINKSDB;
return $links_dict;
#open(PAGE, "page.html") or die "Error opening file.";
#for $line (<PAGE>) {
# print str_replace("LINKS", get_links(), <PAGE>);
#close PAGE;
print get_links();
#!/bin/bash
echo "Starting up Garry's Mod 10 server..."
sleep 1
wine ./srcds.exe -game garrysmod +map gm_flatgrass +maxplayers 6 -console +hostname "SERVER NAME HERE"
echo "Server Started!"
#!/bin/bash
function usage
cat <<- __MSG__
$0
enc Encrypt a file
dec Decrypt a file
-h Help
__MSG__
while [ "$1" != "" ]; do
case $1 in
enc )
shift
gpg -e -r "Alec Hussey" $1
exit 0
dec )
shift
gpg -o $2 -d $1
exit 0
* | -h )
usage
exit 1
esac
shift
done
#!/bin/bash
echo "et.x86 0 0 direct" > /proc/asound/card0/pcm0p/oss ; et
#!/bin/bash
tmp=/tmp/status-report-`date +%F`
touch $tmp && chmod 600 $tmp
if [ `date +%p` = "AM" ]
then
echo -e "subject: morning system status report [`uname -n` - `date +%x`]\n" > $tmp
else
if [ `date +%H` = "12" ]
then
echo -e "subject: noon system status report [`uname -n` - `date +%x`]\n" > $tmp
else
echo -e "subject: evening system status report [`uname -n` - `date +%x`]\n" > $tmp
fi
fi
echo -e "\n -- Users -- " >> $tmp
w >> $tmp
echo -e "\n -- Temperatures -- " >> $tmp
/root/scripts/temperatures >> $tmp
echo -e "\n -- Drive Status -- " >> $tmp
cat /proc/mdstat >> $tmp
echo -e "\n -- UPS Status -- " >> $tmp
/root/scripts/ups_status >> $tmp
echo -e "\n -- Free Disk Space -- " >> $tmp
df -h >> $tmp
echo -e "\n -- Ram -- " >> $tmp
free -m >> $tmp
echo -e "\n -- System Updates -- " >> $tmp
/root/scripts/apt_upgrade >> $tmp
echo -e "\n -- Processes -- " >> $tmp
#ps auxf >> $tmp
top -n 1 -b >> $tmp
sudo sendmail -f root root < $tmp
rm $tmp
#!/bin/bash
sensors | egrep '(Chipset)|(CPU 1)|(CPU 2)'
#!/bin/bash
sudo apcaccess status | egrep '(MODEL :)|(STATUS)|(BCHARGE)|(LOADPCT)|(TIMELEFT)|(LASTXFER)|(NUMXFERS)'
#!/bin/bash
##usage, add the following to .rtorrent.rc :
##system.method.set_key = event.download.finished,notify_me,"execute=/path/to/this/file.sh,$d.get_name="
## target=/media/torrents/tv/24/$(ls /media/torrents/tv/24/| tail -n 1) is the last folder in the 24 folder, so it puts it in the correct season folder.
##script assumes that downloads are saved in: /media/torrents/downloading/
##target is the folder the matched file will be moved to
##notify a list of people to email seperaed by comers about the download finishing
#sets the target folder based on the name of the download
case $1 in
*.iso) target=/media/torrents/DiskImages [email protected],[email protected] ;;
*.img) target=/media/torrents/DiskImages notify= ;;
*Chuck*) target="/media/torrents/tv/Chuck/$(ls /media/torrents/tv/Chuck/| tail -n 1)" notify= ;;
*24.S*) target="/media/torrents/tv/24/$(ls /media/torrents/tv/24/| tail -n 1)" notify=;;
*House*) target="/media/torrents/tv/House/$(ls /media/torrents/tv/House/| tail -n 1)" notify= ;;
*South.Park*) target="/media/torrents/tv/Southpark/$(ls /media/torrents/tv/Southpark/| tail -n 1)" notify=;;
*Two.and.a.Half.Men*) target="/media/torrents/tv/TwoAndAHalfMen/$(ls /media/torrents/tv/TwoAndAHalfMen/| tail -n 1)" notify=;;
*Lie.to.Me*) target="/media/torrens/tv/LieToMe/$(ls /media/torrens/tv/LieToMe/ | tail -n 1)" notify=;;
*FlashForward*) target="/media/torrents/tv/FlashForward/$(ls /media/torrents/tv/FlashForward/| tail -n 1)" notify= ;;
*NCIS.L*) target="/media/torrents/tv/NCIS-LA/$(ls /media/torrents/tv/NCIS-LA/| tail -n 1)" notify= ;;
*NCIS*) target="/media/torrents/tv/NCIS/$(ls /media/torrents/tv/NCIS/| tail -n 1)" notify= ;;
*Top.Gear*) target="/media/torrents/tv/TopGear/$(ls /media/torrents/tv/TopGear/ | tail -n 1)" notify= ;;
*TheITCroud*) target="/media/torrents/tv/TheITCroud/$(ls /media/torrents/tv/TheITCroud/| tail -n 1)" notify= ;;
*Burn.Notice*) target="/media/torrents/tv/BurnNotice/$(ls /media/torrents/tv/BurnNotice/| tail -n 1)" notify= ;;
*Scrubs*) target="/media/torrents/tv/Scrubs/$(ls /media/torrents/tv/Scrubs/| tail -n 1)" notify= ;;
*The.Big.Bang.Theory*) target="/media/torrents/tv/TheBigBangTheory/$(ls /media/torrents/tv/TheBigBangTheory/| tail -n 1)" notify=;;
*Human.Target*) target="/media/torrents/tv/HumanTarget/$(ls /media/torrents/tv/HumanTarget/| tail -n 1)" notify= ;;
*Caprica*) target="/media/torrents/tv/Caprica/$(ls /media/torrents/tv/Caprica/| tail -n 1)" notify= ;;
*The.Simpsons*) target="/media/torrents/tv/The.Simpsons/$(ls /media/torrents/tv/The.Simpsons/| tail -n 1)" notify= ;;
*Bones*) target="/media/torrents/tv/Bones/$(ls /media/torrents/tv/Bones/| tail -n 1)" notify= ;;
*Argumental*) target="/media/torrents/tv/Argumental/$(ls /media/torrents/tv/Argumental/ | tail -n 1)" notify= ;;
*"The Jeremy Kyle Show"*) target="/media/torrents/tv/TheJeremyKyleShow/" [email protected] ipod=0 ;;
*"Mock the Week"*) target="/media/torrents/tv/MockTheWeek/$(ls /media/torrents/tv/MockTheWeek/ | tail -n1)" notify= ;;
*"Embarrassing Bodies"*) target="/media/torrents/tv/EmbarrassingBodies/" notify=;;
*"Russell Howard"*) target="/media/torrents/tv/RussellHowardsGoodNews/$(ls /media/torrents/tv/RussellHowardsGoodNews/ | tail -n1)" notify= ;;
*) target=/media/torrents/finished notify= ;;
esac
#moves the completed download to target decided above
mv "/media/torrents/downloading/$1" "$target"
#links the old file to the new file so that rtorrent can still seed
ln -s "$target/$1" "/media/torrents/downloading/$1"
##emails the people in the notify option
echo -e "$(date) : $1 - Download completed. \n\nfile has been moved to $target/$1"| mail -s "[rtorrent] - Download completed : $1" $notify #
##sends sms to a mobile of choice, from the 3g dongle.
echo -e "$1 - Download completed. moved to $target" > ~/.message
gammu sendsms text 07********* < ~/.message
echo $1 >> /home/mark/showsfinished
##update xbmc, and notify viewer
/usr/bin/xbmc-send -a "UpdateLibrary(video)"
/usr/bin/xbmc-send -a "CleanLibrary(video)"
/usr/bin/xbmc-send -a "Notification([Rtorrent],$1 has finished Downloading)"
#!/bin/bash
#This script contains all of the rsync commands that are run daily on
#Thideras' file server. The main use for this script is to backup to
#alternate locations, such as an external drive or remote location.
LOG=/share/hitachi/logs/rsync-$(date +%m-%d-%Y).log
#Give the date and time started
echo ----------LOG START---------- 1>>$LOG
echo This log started on `date +%H`:`date +%M`:`date +%S` 1>>$LOG
echo 1>>$LOG
#Set the current time
STARTHOUR=10#`date +%H`
STARTMIN=10#`date +%M`
STARTSEC=10#`date +%S`
#This section is the daily rsync section
#Set the locations
COREY=/share/hitachi/rsync/corey/
COREY_COPYTO=/share/external/rsync_copy/corey
DAN=/share/hitachi/rsync/dan/
DAN_COPYTO=/share/external/rsync_copy/dan
DIANA=/share/hitachi/rsync/diana/
DIANA_COPYTO=/share/external/rsync_copy/diana
#Copy the files
rsync -av --delete $COREY $COREY_COPYTO 1>>$LOG
rsync -av --delete $DAN $DAN_COPYTO 1>>$LOG
rsync -av --delete $DIANA $DIANA_COPYTO 1>>$LOG
#End daily rsync section
#This is the archive function, runs on Monday only
if [ `date +%u` -eq "1" ]
then
echo Starting weekly archive 1>>$LOG
#Set the backup source locations
COREY1="/share/hitachi/rsync/corey/World of Warcraft"
DAN1="/share/hitachi/rsync/dan/World of Warcraft"
#Set the backup destination locations
COREY1_GZIP="/share/hitachi/backups/Corey_WoW/WoW-$(date +%m-%d-%Y).tar.gz"
COREY2_GZIP="/share/external/backups/corey/WoW-$(date +%m-%d-%Y).tar.gz"
DAN1_GZIP="/share/hitachi/backups/Dan_WoW/WoW-$(date +%m-%d-%Y).tar.gz"
DAN2_GZIP="/share/external/backups/dan/WoW-$(date +%m-%d-%Y).tar.gz"
#Tar and Gzip the files
tar -cf - "$COREY1" | gzip > "$COREY1_GZIP" &
tar -cf - "$DAN1" | gzip > "$DAN1_GZIP"
#Copy the files to the external drive
cp "$COREY1_GZIP" "$COREY2_GZIP"
cp "$DAN1_GZIP" "$DAN2_GZIP"
echo Weekly archive complete! 1>>$LOG
else
echo Weekly archive is not set to run today 1>>$LOG
fi
#End weekly archive
#Get the current time in minutes and seconds, assign to variables
ENDHOUR=10#`date +%H`
ENDMIN=10#`date +%M`
ENDSEC=10#`date +%S`
#Compute the difference between the start and end time
HOUR=$(($ENDHOUR - $STARTHOUR))
MIN=$(($ENDMIN - $STARTMIN))
SEC=$(($ENDSEC - $STARTSEC))
#If the time goes under 0, correct the time
if [ $SEC -lt "0" ]
then
SEC=$(($SEC + 60))
MIN=$(($MIN - 1))
fi
if [ $MIN -lt "0" ]
then
MIN=$(($MIN + 60))
HOUR=$(($HOUR - 1))
fi
if [ $HOUR -lt "0" ]
then
HOUR=$(($HOUR + 24))
fi
#Add the end date and time
echo 1>>$LOG
echo -----------LOG END----------- 1>>$LOG
echo This log ended on `date +%H`:`date +%M`:`date +%S` 1>>$LOG
echo Runtime: "$HOUR"h "$MIN"m "$SEC"s 1>>$LOG
exit
#!/bin/bash
ps -ef | grep vmware-vmx | grep VMware | awk '{ print $2 " " $19}' | awk -F \/ '{ print $1 $NF }' | rev | cut -b 5- | rev | sort -k 2
root@athena:~/scripts# ./vmware_pid
31783 dc1.mbentley.net
4838 dc2.mbentley.net
30946 exchange1.mbentley.net
15868 server01.contoso.com
7930 server02.contoso.com
6269 webserver.mbentley.net
#!/bin/bash
## written by mbentley
## set variables
command=$0
username=$1
function check_username {
if [ -z "${username}" ];
then
echo "Usage: $command <username>";
exit 1
fi
function temp_dir {
tempdir=/tmp/idlerpg_$username_`date +%N`
mkdir $tempdir
if [ ! -d "$tempdir" ]
then
exit 1
fi
function query_stats {
cd $tempdir
wget -t 1 -T 5 -q http://splat.mine.nu/idlerpg/xml.php?player=$username
function verify_download {
if [ ! -e "$tempdir/xml.php?player=$username" ]
then
echo "Error fetching data! Please check manually: http://splat.mine.nu/idlerpg/players.php";
cleanup_tmp
exit 1
fi
function cleanup_tmp {
rm -rf $tempdir
function validate_user {
validate=`cat $tempdir/xml.php?player=$username | grep "<online>" | awk -F "[<>]" '{ print $3 }'`
if [ -z "${validate}" ];
then
echo "$username is not a valid user (usernames are case sensitive)";
cleanup_tmp
exit 1
fi
function grab_status {
user_status=$validate
function status_check {
if [ $user_status == 1 ];
then
echo "$username is online";
else
echo "$username is offline";
fi
## run functions
check_username
temp_dir
query_stats
verify_download
validate_user
grab_status
status_check
cleanup_tmp
root@athena:~/scripts# ./idlerpg_v1 mbentley
mbentley is online
root@athena:~/scripts# ./idlerpg_v1 Baked
Baked is offline
#!/bin/bash
## set variables
command=$0
username=$1
then
exit 1
fi
function temp_dir {
mkdir $tempdir
then
exit 1
fi
cd $tempdir
then
cleanup_tmp
exit 1
fi
rm -rf $tempdir
then
cleanup_tmp
exit 1
fi
if [ $user_status == 0 ];
then
email_offline
fi
function email_offline {
mail=$tempdir/mail_`date +%F`
touch $mail
chmod 600 $mail
echo -e "subject: idleRPG: $username is offline" >> $mail
echo -e "$username is currently offline!" >> $mail
/usr/sbin/sendmail -f [email protected] root < $mail
## run functions
check_username
temp_dir
query_stats
verify_download
validate_user
grab_status
status_check
cleanup_tmp
Date: Wed, 09 Jun 2010 15:49:47 -0400
Subject: idleRPG: Baked is offline
Baked is currently offline!
