- Jan 24, 2006
- South Dakota
#!/usr/bin/python
#As set out by progress the format for a structure file is the following:
b <location of bi file>.b1
d "Schema Area":6,32;1 <location of schema area>.d1
d <Area Name>:<Area Number>,<records per block>;<blocks per cluster> <location of extent>/<database name>_<area number>.d1 f <extent size>
#This script will interactively generate a structure file and the use progress tools to install them
#It relies heavily on while-loops for sanity checking.
import sys
import os
#Testing to make sure that user inputs the correct answers#
def sanity_check_expect_string(prompt_user, error_message):
acceptable_input_flag = 0
while acceptable_input_flag == 0:
expecting_string = raw_input(prompt_user)
if expecting_string != "":
acceptable_input_flag = 1
return expecting_string
else:
print error_message
def sanity_check_integer(prompt_user, error_message):
extent_size_not_digit = 0
#We want to make sure that what is being entered is a digit
expecting_integer = raw_input(prompt_user)
if expecting_integer.isdigit() == True :
if prompt_user == 'Please enter the number of extents in this area: ' or prompt_user == "How many BI extents do you wish to create: ":
if str(expecting_integer) == "1":
pass
else:
extent_size = sanity_check_integer("Please enter the extent size: ", "\n!!!!you did not enter a valid extent size \n")
while extent_size_not_digit == 0:
if extent_size.isdigit() == True:
extent_size_not_digit = 1
return expecting_integer
return extent_size
else:
print error_message
else:
print error_message
#######################################################3
#Get the database name
database_name = sanity_check_expect_string('Please enter the database name: ', "\n!!!!You left the database name blank\n")
#We need the dbms location in order to create the structure file there
dbms_location = raw_input('Please enter the full path to the dbms folder is located: ')
#here we are just removing the trailing slash for consistency throughout the script
if "dbms/" in dbms_location:
dbms_location = dbms_location.replace("dbms/", "dbms")
print "correcting dbms_location to ", dbms_location
#make sure that the user is actually entering a dbms location
while "/dbms" not in dbms_location:
print "\n!!!!The /dbms folder not specified\n"
#set the absolute path for the structure file
try:
structure_file_abs_path = dbms_location, "/", database_name, ".st"
structure_file_abs_path = "".join(structure_file_abs_path)
#Open the structure file for writing
structure_file = open('%s' % structure_file_abs_path, 'w')
except:
print "The location you specified does not exist ", "(", dbms_location, ")"
sys.exit()
database_block_size = raw_input('Enter the block size to use for the database (default: 8192): ')
#This sets the default block size to 8k
if database_block_size == "":
database_block_size = 8192
print "\nblocksize is ", database_block_size, "\n"
#convert the raw input into an integer for testing
database_block_size = int(database_block_size)
#This section determines which 'empty' database openEdge will use
#We set the flag in order to make sure that a correct block size gets entered
#If a correct size is entered and the flag gets changed to 1 breaking the loop
flag = 0
while flag == 0:
if database_block_size == 8192:
empty_database = "empty8"
flag = 1
elif database_block_size == 4096:
empty_database = "empty4"
flag = 1
elif database_block_size == 2048:
empty_database = "empty2"
flag = 1
elif database_block_size == 16384:
empty_database = "empty16"
flag = 1
elif database_block_size == 1024:
empty_database = "empty1"
flag = 1
else:
flag = 1
else:
print "\nYou did not enter a valid block size!"
database_block_size = raw_input('Enter the block size to use for the database: ')
################################BI area#######################
#Set the BI areas
number_of_bi_areas = sanity_check_integer("How many BI extents do you wish to create: ", "\n!!!!You did not enter a valid number of areas to create \n")
counter = 0
structure_file.write("#\n")
while counter < (int(number_of_bi_areas)) :
structure_file.write('b %s/%s.b%s \n' % (dbms_location, database_name, (counter + 1)))
counter +=1
#print the schema info which we want to always be the same
structure_file.write('d "Schema Area":6,32;1 %s/%s.d1 \n' % (dbms_location, database_name))
#This sanity check makes sure that the number of areas to create is an actual number
number_of_areas = sanity_check_integer("Enter the number of areas to create: ", "\n!!!!You did not enter a valid number of areas to create \n")
#######################Generation of the individual extent areas loop ###################
#get the name of the area
area_number = 0
while area_number < int(number_of_areas):
#Get the name of the area
area_name = sanity_check_expect_string('\nPlease enter the name of the area: ', "\n!!!!you did not enter a valid area name \n")
#get the number of extents
number_of_extents = sanity_check_integer('Please enter the number of extents in this area: ', "\n!!!!you did not enter a valid number of extents\n")
#get the records per block, usually indexes are 1 record per block. Data can vary
records_per_block = sanity_check_integer('How many records per block? ', "\n!!!!you did not enter a valid number of records per block \n")
#Get the number of blocks per cluster. For indexes there are usually 8 blocks per cluster, again data can vary
blocks_per_cluster = sanity_check_integer('How many blocks per cluser? ', "\n!!!!you did not enter a valid number of blocks per cluster \n")
#get the extent location
extent_location = dbms_location, "/", database_name, "_%s" % (area_number + 7), ".d%s" % (number_of_extents)
extent_location = "".join(extent_location)
counter = 0
structure_file.write("\n#\n")
#this prints the required number of extents -1. This assumes the last extent is going to be variable
while counter < (int(number_of_extents) - 1) :
structure_file.write('d "%s":%s,%s;%s %s f %s \n' % (area_name, (area_number + 7), records_per_block, blocks_per_cluster, extent_location, extent_size))
counter +=1
structure_file.write('d "%s":%s,%s;%s %s' % (area_name, (area_number + 7), records_per_block, blocks_per_cluster, extent_location))
area_number += 1
###############################End invidiual area extent generation ########################
print " "
#set the location of the database, which joins the dbms location with the database to create an absolute path to the database
database_location = dbms_location, "/", database_name
database_location = "".join(database_location)
#make sure that the file to parse exists in the CWD
if os.path.exists("create_blank_response.py") == True:
#we are assuming that the structure file builder is located in the same directory as the create_blacnk_response.py
#in order to grab the DLC
for line in open("create_blank_response.py", "r"):
if "path=" in line and "workpath=" not in line and "oem_path=" not in line and "oem_workpath=" not in line and "jdkHomePath" not in line and "esbpath=" not in line:
dlc_path = line.replace("path=", "")
else:
pass
#Locate the empty database file
empty_path = dlc_path.rstrip() + "/" + empty_database
#empty_path = "".join(empty_path)
print empty_database
print "The current DLC path is: ", dlc_path
print "The empty database is located ", empty_path
else:
print "Could not get the DLC from create_blank_response.py... is it located in the current working directory"
print "Aborting installation process. The structure file was created at: ", structure_file_abs_path
sys.exit()
#Close the structure file so that there can be no more writing
structure_file.close()
#Print the contents of the structure file for verification in read only mode
structure_file = open('%s' % structure_file_abs_path).readlines()
for line in structure_file:
print line,
#ask the user if they want to install the current structure file
install = raw_input('\nDo you wish to install with these settings (y/n)? ')
if install == "y" or install == "Y":
#create the database with a specified block size
os.chdir(dbms_location)
os.system("prostrct create %s %s.st -blocksize %s" % (database_location, database_name, database_block_size))
os.system("procopy %s %s" % (empty_path, database_name))
else:
print ""
print "OK, user aborted the installation"
print "The structure file is located at: ", structure_file_abs_path
#!/usr/bin/python
import re
import os
import sys
import MySQLdb
from BeautifulSoup import BeautifulSoup, NavigableString
last_line = '---' #if you reach this line, treat previous lines as a single block
scratch_file = "sit_new"
database_connection = MySQLdb.connect('192.168.89.22', 'root', '', 'nmap');
cursor = database_connection.cursor()
#nmap_output is the file which nmap will be piped to
nmap_output = "SIT_nmap_aggressive"
def createNmap():
#Run the nmap command with the option to querry the host OS
#os.system("sudo nmap -O 192.168.88.0/24 > '%s'" % str(nmap_output))
nmap_unformatted = open(nmap_output, "r").readlines()
#Words to exclude
word1 = "up"
word3 = "Starting"
word4 = "done"
word5 = "Not"
word6 = "MAC"
word7 = "Device"
word8 = "Network"
word9 = "detection"
#Here I am redirecting standard out to the scratch file
#So that the info can be more easily managed
old_stdout = sys.stdout
sys.stdout = open(scratch_file, "w")
for line in nmap_unformatted:
if word1 not in line and word3 not in line and word5 not in line and word6 not in line and word7 not in line and word8 not in line and word9 not in line:
#replace the blank lines with dashes so that they are easier to parse
if line.isspace():
print "---"
else:
print line.strip()
#Put the stardard out back to normal
sys.stdout = old_stdout
def parse_ports():
###############Parse known ports from the IANA list ####################
#open the xml file for reading
ports_xml = open("port_numbers.xml", "r")
search_xml = BeautifulSoup(ports_xml)
#This tells beautiful soup to pull out only the name tag
search_unassigned_numbers = search_xml.findAll('record')
#The file contains stuff we dont want (unassined and reserved ports)
#This list contains the known ports that we want
filtered_entries = []
#append the appropriate ports to the filtered_entries list
for entries in search_unassigned_numbers:
entries = str(entries)
if "Unassigned" in entries or "Reserved" in entries:
pass
else:
filtered_entries.append(entries)
#Turn the list into text so that Beautiful soup can use it
filtered_entries = "".join([x for x in filtered_entries])
#Change the soup tags so that it is searching the filtered entries
search_xml = BeautifulSoup(filtered_entries)
search_port = search_xml.findAll('record')
#set the list for the port_descriptions
port_description = []
port_names = re.compile(r'<name>.*</name>')
counter = 0
#while counter < len(port_number):
for ports in search_port:
ports = str(ports)
find_ports = port_names.findall(ports)
find_ports = " ".join(find_ports)
if "name" in find_ports:
find_ports = find_ports.replace("<name>", "").replace("</name>", "")
#print find_ports
port_description.append(find_ports)
else:
port_description.append("")
#set the list for the port numbers
port_number = []
port_names = re.compile(r'<number>.*</number>')
counter = 0
ports = str(ports)
if "number" in find_ports:
#remove the tags and leave only the port numbers going into the list
find_ports = find_ports.replace("<number>", "").replace("</number>", "")
#print find_ports
port_number.append(find_ports)
else:
port_number.append("")
protocol_name = []
protocol_names = re.compile(r'<protocol>.*</protocol>')
counter = 0
for protocol in search_port:
ports = str(ports)
if "protocol" in find_ports:
#remove the tags and leave only the protocol names going into the list
find_ports = find_ports.replace("<protocol>", "").replace("</protocol>", "")
protocol_name.append(find_ports)
else:
protocol_name.append("")
#############Begin parsing nmap###################
port_list = []
nmap_file = open(nmap_output).readlines()
flag = 0
for line in nmap_file:
if line.startswith('Nmap'):
flag = 0
if last_line in line:
flag = 1
if not flag and not last_line in line:
#append the line to the list and strip the dashes away
port_list.append(line.strip('---').rstrip())
#set the computer_id to 0. The computer_id represents the ID of the computer
#each port can have the same ID. In this way ports 80, 22, 443 etc all reference computer by ID
computer_id = 0
existing_ports = []
for ports_open in port_list:
starts_with_digit = re.match(r"[0-9]", ports_open) is not None
#For the ports section we dont want anything that starts with a letter
#If the line starts with a digit, parse out only the port number
if starts_with_digit == True:
ports_open = ports_open.split('/')[0]
#print "Inserting: ", ports_open
existing_ports.append(ports_open)
cursor.execute("INSERT ignore INTO Ports_Table(Port_ID, Open_Port) values('%s','%s')" % (computer_id, ports_open))
print "INSERT ignore INTO Ports_Table(Port_ID, Open_Port) values('%s','%s')" % (computer_id, ports_open)
continue
#If the line starts with Port, increase the computer_id. Nmap lists the PORT heading only once per computer
#Therefore it is a reliable way to indicate the ID of a new computer
elif starts_with_digit == False and "Nmap" in ports_open:
computer_id +=1
elif "All 1000" in ports_open:
print "no ports open at ID ", computer_id
ports_open = 0
#Loop through the open ports on your network and only add port descriptions of ports which exist on your network
#This was done to reduce querry time against the list of known ports
x = 0
while x < len(port_number):
if port_number[x] in existing_ports:
print "adding ", port_number[x], port_description[x], protocol_name[x], " to the database"
cursor.execute("INSERT ignore INTO Port_Description(Port_Number, Port_Description, Port_Protocol) values('%s', '%s', '%s')" % (port_number[x], port_description[x], protocol_name[x]))
else:
print "This port is not found among the open ports on your network.... OMITTING"
x +=1
def parse_dns():
#to parse the aggress nmap it seems to be required to reset the last line parameter
sit_nmap = open("SIT_nmap_aggressive").readlines()
last_line = "HOP RT"
os_list = []
flag = 0
#purge the stuff we dont want in the file
for line in sit_nmap:
if line.startswith('Nmap scan'):
flag = 0
flag = 1
if "SF:" in line or "SF-" in line:
pass
elif "OS: " in line:
os_list.append(line)
elif "tcp" in line:
pass
elif "====" in line:
pass
elif "OS:" in line:
pass
elif "|_" in line and not "NetBIOS" in line:
pass
else:
os_list.append(line.rstrip())
number_of_hosts = 0
newstring = []
#Pull out all of the netbios names to circumvent the dns since SIT does not keep Linux machines up to date in the dns
for x in os_list:
if "Nmap scan" in x:
number_of_hosts +=1
netbios = re.findall(r"NetBIOS name.*, ", x)
netbios = "".join(netbios)
if netbios == "":
pass
#in order to determine which computer the netbios name goes with, we insert the number in order to split it off later for insertion
else:
netbios = netbios.split(" ")
netbios = netbios[2].replace(",", "")
netbios = netbios, number_of_hosts
netbios = "".join(str(netbios))
newstring.append(netbios)
#In order to work around a parsing problem we insert blank entries
ID = 1
while ID < number_of_hosts:
cursor.execute("INSERT INTO Computer_Info(Computer_ID,DNS_Name) values('%s', '')" % ID)
cursor.execute("INSERT ignore INTO Computer_Ports(Computer_ID, Port_ID) values('%s', '%s')" % (ID, ID))
ID +=1
#The new string is mostly a dumby list to simply allow the computer name to be matched with the proper id
#There probably is a better way to do this...
for x in newstring:
x = x.split(" ")
name = x[0].replace("('", "").replace("',", "")
ID = x[1].replace("'", "").replace(")", "")
cursor.execute("UPDATE Computer_Info SET `DNS_Name`='%s' WHERE `Computer_ID`='%s'" % (name, ID))
#The counter keeps track of which host we are looping through
counter = 1
for ip_address in os_list:
if ip_address.startswith('Nmap scan'):
flag = 0
if last_line in ip_address:
flag = 1
if "scan report" in ip_address:
ip = re.compile(r'192.\d+.\d+.\d+')
find_ip = ip.findall(ip_address)
find_ip = str(find_ip).replace("['", "").replace("']", "")
cursor.execute("UPDATE Computer_Info SET `Computer_IP_Address`='%s', `OS_ID`='%s' WHERE `Computer_ID`='%s'" % (find_ip, counter, counter))
counter +=1
def parse_os():
os_list = []
flag = 0
starts_with_digit = re.match(r"[0-9]", line) is not None
flag = 0
flag = 1
pass
elif "SF:" in line or "SF-" in line:
pass
elif "tcp" in line:
pass
pass
pass
else:
newstring = []
counter = 1
#for my own tracking I am keeping a seperate list for Linux, Windows and other
microsoft = []
linux = []
other = []
computer_id = 0
for host_os in os_list:
#skip over the open ports as they are the only lines that start with digits
starts_with_digit = re.match(r"[0-9]", host_os) is not None
if "Nmap scan" in host_os:
computer_id +=1
pass
#As with before I append the computer number in order to line the OS with the appropriate computer_id
elif "| OS: Windows" in host_os:
host_os = host_os.split(":")
host_os = host_os[1].split("(")
host_os = host_os[0].replace("[' ", "")
host_os = computer_id, host_os
host_os = "".join(str(host_os))
microsoft.append(host_os.rstrip())
elif "OS details: Linux" in host_os:
host_os = host_os.strip("OS details: ")
host_os = computer_id, host_os.rstrip()
linux.append(host_os)
elif "OS details:" in host_os and "Microsoft" not in host_os and "Linux" not in host_os:
other.append(host_os)
elif "No exact" in host_os:
host_os = computer_id, "Not Available"
elif "Too many" in host_os:
counter = 1
ips = []
for x in os_list:
if x.startswith('Nmap scan'):
flag = 0
if last_line in x:
flag = 1
if "scan report" in x:
find_ip = ip.findall(x)
counter +=1
ips.append(find_ip)
#set the OS_ID, by setting the id but the OS_name blank at first
loop = 1
while loop < computer_id:
cursor.execute("INSERT into OS_Table (OS_ID) values('%s')" % (loop))
loop += 1
#Insert the Operating systems into the OS_Name
for x in microsoft:
x = x.split(",")
ID = x[0].replace("(", "")
os = x[1].replace("'", "").replace(")", "").rstrip()
cursor.execute("UPDATE Computer_Info SET `OS_ID`='%s' WHERE `Computer_ID`='%s'" % (ID, ID))
cursor.execute("UPDATE OS_Table SET `OS_Name`='%s' WHERE `OS_ID`='%s'" % (os, ID))
for x in linux:
x = x.split(",")
for x in other:
x = x.split(",")
parse_ports()
parse_dns()
parse_os()
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import pygtk
import gtk
import os
import sys
import MySQLdb
database_connection = MySQLdb.connect('localhost', 'root', '', 'nmap');
class Application(gtk.Window):
cells = {}
columns = {}
sort_order = gtk.SORT_ASCENDING
def __init__(self):
gtk.Window.__init__( self )
self.set_title("Netowrk Scanner")
self.set_position(gtk.WIN_POS_CENTER)
self.create_widgets()
self.connect_signals()
#self.window.show_all()
self.show_all()
gtk.main()
def create_widgets(self):
#Ask the user to search by operating system
self.vbox = gtk.VBox(spacing=10)
self.operating_system_label_hbox_1 = gtk.HBox(spacing=10)
self.label = gtk.Label("Search by Operating System :")
self.operating_system_label_hbox_1.pack_start(self.label)
#Set a check box so the user can choose to display ports
self.ports_hbox_8 = gtk.HBox(spacing=10)
self.ports_check = gtk.CheckButton("Display Ports")
self.ports_hbox_8.pack_start(self.ports_check)
self.halign_ports = gtk.Alignment(0,1,1,0)
self.halign_ports.add(self.ports_hbox_8)
self.os_entry_hbox_2 = gtk.HBox(spacing=10)
self.OS = gtk.Entry()
self.os_entry_hbox_2.pack_start(self.OS)
self.hostname_label_hbox_3 = gtk.HBox(spacing=10)
self.label = gtk.Label("Search by Hostname:")
self.hostname_label_hbox_3.pack_start(self.label)
self.hostname_entry_hbox_4 = gtk.HBox(spacing=10)
self.HOSTNAME = gtk.Entry()
self.hostname_entry_hbox_4.pack_start(self.HOSTNAME)
self.ip_label_hbox_5 = gtk.HBox(spacing=10)
self.label = gtk.Label("Search by IP:")
self.ip_label_hbox_5.pack_start(self.label)
self.ip_entry_hbox_6 = gtk.HBox(spacing=10)
self.IP = gtk.Entry()
self.ip_entry_hbox_6.pack_start(self.IP)
self.buttons_hbox_7 = gtk.HBox(spacing=10)
self.button_ok = gtk.Button("Get Results!")
self.buttons_hbox_7.pack_start(self.button_ok)
self.button_exit = gtk.Button("Get me Outta Here!")
self.buttons_hbox_7.pack_start(self.button_exit)
#The order in which you pack_start a widget is the order in which it is displayed on the screen
self.vbox.pack_start(self.operating_system_label_hbox_1)
self.vbox.pack_start(self.os_entry_hbox_2)
self.vbox.pack_start(self.hostname_label_hbox_3)
self.vbox.pack_start(self.hostname_entry_hbox_4)
self.vbox.pack_start(self.ip_label_hbox_5)
self.vbox.pack_start(self.ip_entry_hbox_6)
self.vbox.pack_start(self.halign_ports, False, False, 3)
self.vbox.pack_start(self.buttons_hbox_7)
self.add(self.vbox)
def connect_signals(self):
#Have the buttons start 'listening' for user interaction
self.button_ok.connect("clicked", self.button_click)
self.button_exit.connect("clicked", self.exit_program)
def button_click(self, clicked):
#This function gets the values of the input boxes as well as the check box
#And then passes them to the show_table function so it can get the correct results from the database
global ports_check, os, ip, hostname
os = self.OS.get_text()
ip = self.IP.get_text()
hostname = self.HOSTNAME.get_text()
ports_check = self.ports_check.get_active()
if os == "" and ip == "" and hostname == "":
error_message = gtk.MessageDialog(self, gtk.DIALOG_DESTROY_WITH_PARENT, gtk.MESSAGE_ERROR, gtk.BUTTONS_CLOSE, "You haven't entered anything to search for!")
error_message.run()
error_message.destroy()
else:
if hostname != "" and (os != "" or ip != ""):
error_message = gtk.MessageDialog(self, gtk.DIALOG_DESTROY_WITH_PARENT, gtk.MESSAGE_ERROR, gtk.BUTTONS_CLOSE, "If you know the hostname why are you searching with other options? Please search by hostname only")
error_message.run()
self.OS.set_text("")
self.IP.set_text("")
self.HOSTNAME.set_text("")
else:
self.show_Table(os, ip, hostname)
def show_Table(self, search_os, search_ip, search_hostname):
### Create the table
# List of items to display which represent IP, OS, DNS, Port number and Port description
# Columns
if ports_check == True:
cols = ['IP Address', 'Operating System', 'Hostname', 'Ports', 'Protocol Name']
else:
cols = ['IP Address', 'Operating System', 'Hostname']
self.newColumn("IP Address", 0)
self.newColumn("Operating System", 1)
self.newColumn("Hostname",2)
#I only want the ports columns to show if the user requests it because this calls different mysql querries
self.newColumn("Ports", 3)
self.newColumn("Protocol name", 4)
sequence = [str] * len(cols)
self.treestore = gtk.TreeStore( * sequence)
self.treestore.connect("rows-reordered", self.on_column_clicked)
self.treeview = gtk.TreeView(self.treestore)
self.treeview.cell = [None] * len(cols)
self.treeview_column = [None] * len(cols)
for column_number, col in enumerate(cols):
self.treeview.cell[column_number] = gtk.CellRendererText()
self.treeview_column[column_number] = gtk.TreeViewColumn(col, self.treeview.cell[column_number])
self.treeview_column[column_number].add_attribute(self.treeview.cell[column_number], 'text', column_number)
self.treeview_column[column_number].set_resizable(True)
self.treeview_column[column_number].set_reorderable(True)
self.treeview_column[column_number].set_sort_indicator(True)
self.treeview_column[column_number].set_sort_column_id(column_number)
self.treeview.append_column(self.treeview_column[column_number])
self.scrollTree = gtk.ScrolledWindow()
self.scrollTree.set_policy(gtk.POLICY_NEVER, gtk.POLICY_AUTOMATIC)
self.scrollTree.add(self.treeview)
#If the user is running a search on the hostname run these querries
if search_hostname != "":
cursor.execute("SELECT DISTINCT Computer_IP_Address, OS_Name, DNS_Name, Port_Description, Open_Port FROM Computer_Ports AS CP \
JOIN Computer_Info AS CI ON ( CP.Computer_ID = CI.Computer_ID ) \
JOIN Ports_Table AS PT ON ( CP.Port_ID = PT.Port_ID ) \
JOIN OS_Table AS OS ON ( CI.Computer_ID = OS.OS_ID ) \
JOIN Port_Description AS PS ON ( PT.Open_Port = PS.Port_Number ) \
WHERE DNS_Name LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address ), Open_Port" % (search_hostname))
#Otherwise just return the relevent data
else:
cursor.execute("SELECT DISTINCT Computer_IP_Address, OS_Name, DNS_Name FROM Computer_Info AS CI \
WHERE DNS_Name LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address )" % (search_hostname))
#If the user has specified the IP and the OS to search, run this querry
if search_os != "" and search_ip !="":
#Set up the querries. If the user has activted the checkbox, we need to include the ports in the querry
WHERE OS_Name LIKE '%%%s%%' and Computer_IP_Address LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address ), Open_Port" % (search_os, search_ip))
else:
cursor.execute("SELECT DISTINCT Computer_IP_Address, OS_Name, DNS_Name FROM Computer_Info AS CI ON \
WHERE OS_Name LIKE '%%%s%%' and Computer_IP_Address LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address )" % (search_os, search_ip))
#If the user has specified an OS but not an IP run this
elif search_os != "" and search_ip == "":
WHERE OS_Name LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address ), Open_Port" % search_os)
else:
WHERE OS_Name LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address )" % search_os)
#If the user has specified an IP but not an OS run this
elif search_os =="" and search_ip != "":
WHERE Computer_IP_Address LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address ), Open_Port" % search_ip)
else:
WHERE Computer_IP_Address LIKE '%%%s%%' ORDER BY inet_aton( Computer_IP_Address )" % search_ip)
#get the results and prepare to put them inside of lists
fetch_results = cursor.fetchall()
host_name_list = []
operating_list = []
ip_list = []
ports = []
#The element chosen to append to each list based on the order of retrieval in the mysql querry
for individual_result in fetch_results:
ip_list.append(individual_result[0])
operating_list.append(individual_result[1])
host_name_list.append(individual_result[2])
ports.append(individual_result[3])
#we are going to add blanks to the files in order to help readability
#when putting this into the chart
cleaned_host =[]
cleaned_ip = []
cleaned_os_list = []
index_counter = 0
#this loop will check to see if the entry already exists in the cleaned variables. If it does, it 'omitts' them by inserting a blank line
while index_counter < len(host_name_list):
if host_name_list[index_counter] in cleaned_host:
#print "found a duplicate in HOST....OMITTING"
cleaned_host.append("")
else:
#print "adding ", host_name_list[index_counter]
cleaned_host.append(host_name_list[index_counter])
if operating_list[index_counter] in cleaned_os_list and ip_list[index_counter] in cleaned_ip:
#print "found a duplicate in OPERATING....OMITTING"
cleaned_os_list.append("")
else:
#print "adding ", operating_list[index_counter]
cleaned_os_list.append(operating_list[index_counter])
if ip_list[index_counter] in cleaned_ip:
#print "Found a duplicate in IP.... OMITTING "
cleaned_ip.append("")
else:
#print "adding ", ip_list[index_counter]
cleaned_ip.append(ip_list[index_counter])
index_counter +=1
#this section appends to the list store depending on whether the user wants to see the ports or not
counter = 0
for single_result in fetch_results:
self.treestore.append( None,
[ cleaned_ip[counter], cleaned_os_list[counter], cleaned_host[counter], single_result[4], single_result[3] ]
else:
self.treestore.append(None,
[ single_result[0], single_result[1], single_result[2] ]
counter +=1
self.frm_table = gtk.Window()
self.frm_table.set_default_size(600, 800)
self.frm_table.set_title("Network scan results")
#Change the background to white instead of grey
self.frm_table.modify_bg(gtk.STATE_NORMAL, gtk.gdk.color_parse('#fff'))
self.frm_table.add(self.scrollTree)
self.frm_table.show_all()
def on_column_clicked(self, col1, col2, col3, col4 ):
#This function allows the columns to be resorted upon click
if self.sort_order == gtk.SORT_ASCENDING:
self.sort_order = gtk.SORT_DESCENDING
else:
self.sort_order = gtk.SORT_ASCENDING
#tc.set_sort_order(self.sort_order)
def exit_program(self, widget, callback_data=None):
gtk.main_quit()
if __name__ == "__main__":
app = Application()
database_connection.commit()
cursor.close()
database_connection.close()
#!/bin/bash
x=$(date +%Y-%m-%d_%H)
wget http://fah-web.stanford.edu/daily_team_summary.txt.bz2 -O /home/petteyg/folding/team-${x}.txt.bz2
bzip2 -d /home/petteyg/folding/team-${x}.txt.bz2
mv /home/petteyg/folding/team-${x}.txt /home/petteyg/folding/team-${x}.txt.orig
head -n23 /home/petteyg/folding/team-${x}.txt.orig | tail -n20 > /home/petteyg/folding/team-${x}.txt
rm /home/petteyg/folding/team-${x}.txt.orig
bzip2 -9 /home/petteyg/folding/team-${x}.txt
wget http://fah-web.stanford.edu/daily_user_summary.txt.bz2 -O /home/petteyg/folding/user-${x}.txt.bz2
bzip2 -d /home/petteyg/folding/user-${x}.txt.bz2
mv /home/petteyg/folding/user-${x}.txt /home/petteyg/folding/user-${x}.txt.orig
grep -P "\s32$" /home/petteyg/folding/user-${x}.txt.orig > /home/petteyg/folding/user-${x}.txt
rm /home/petteyg/folding/user-${x}.txt.orig
bzip2 -9 /home/petteyg/folding/user-${x}.txt
#!/usr/bin/python
#This script is designed to automatically update dhcp and dns as new hosts
#join the network. The danger in this script is having too many hosts joining the network without
import os
import sys
import time
import fileinput
import datetime
#The date is important to increment the serial in bind
#it takes the format year, month, day, minute (in case there are multiple edits in one day)
date = datetime.datetime.now().strftime("%Y%m%d%M")
dhcp_lease_file = "/var/lib/dhcp/dhcpd.leases"
dhcp_conf = "/etc/dhcp/dhcpd.conf"
dns_zone = "/etc/bind/zones/stratus-sphere.com.db"
#use os.stat is used to determine if the file has changed
watch = os.stat(dhcp_lease_file)
#set the current file and the last modified date to the modified time of the file to be watched
current_file = last_modified = watch.st_mtime
#create a temp file so that we are only capturing the last entry in the leases file
os.system("> /tmp/dhcp.tmp")
#create an infinite loop for monitoring the file
while 1:
host = ""
ip = ""
mac = ""
number_of_hosts = 0
#if the current time is less than the last modified, assume that the file has changed
if current_file > last_modified:
dhcp_lease = os.popen("tail -n 9 %s > /tmp/dhcp.tmp" % dhcp_lease_file).read()
last_modified = current_file
#loop through the temp file and parse out the proper host info
for line in open("/tmp/dhcp.tmp").readlines():
#Parse out the IP
if "lease" in line:
ip = line.rstrip().replace("lease ", "").replace(" {", "")
#Parse out the mac address
if "hardware ethernet" in line:
mac = line.replace(";", "").rstrip().replace(" ", "")
#Set custom host name based on the mac address... mostly useful for phones
if "78:d6:f0:d5:af:27" in line:
host = "rosanna-phone"
if "00:26:e8:f6:26:05" in line:
host = "steves-phone"
#Set the generic hostname
if "client-hostname" in line:
if host != "":
print "already have a host name"
else:
host = line.replace('client-hostname ', '').replace(';', '').replace(" ", "").replace('"', '').rstrip()
print "the current host is %s" % host
#Check to see if the host already exists in the dns
#if not we add the host
if host not in os.popen("cat %s" % dns_zone).read():
print "%s is not in the dns...adding" % host
print "%s IN A %s" % (host, ip)
dns_file = open(dns_zone, "a")
dns_file.write("%s IN A %s\n" % (host, ip))
dns_file.close()
#increment the Serial for bind
for line in fileinput.FileInput(dns_zone, inplace = 1):
if "Serial" in line:
line = " %s ; Serial\n" % date
print line,
else:
print line,
#get rid of the closing brack in the dhcp conf so that we can append to the file later
for line in fileinput.FileInput(dhcp_conf, inplace = 1):
if " }" in line:
print line,
elif "}" in line:
pass
else:
print line,
dhcp_file = open(dhcp_conf, "a")
dhcp_file.write(" host %s {\n" % host)
dhcp_file.write(" %s;\n" % mac)
dhcp_file.write(" fixed-address %s;\n" % ip)
dhcp_file.write(" }\n")
dhcp_file.write("}")
dhcp_file.close()
#Restart the DNS so that the changes take effect
print "\nrestarting DNS"
os.system("/etc/init.d/bind9 restart")
time.sleep(5)
else:
print "found host"
print ""
current_file = watch.st_mtime
time.sleep(1)
# m3u Playlist Generator
# Version 1.3.7 by Teque5
# 2010.10.30-2011.11.10
# Creative Commons Attribution-ShareAlike 3.0 Unported (CC BY-SA 3.0)
# [url]http://creativecommons.org/licenses/by-sa/3.0/[/url]
import os
import sys
import getopt
import random
import datetime
location = '.' # Default source directory
playlistName = 'playlist' # Default playlist name
verbose = True # Shows directories being searched
relativePath = True # Produces a relative file tree from specified folder
randomize = False # Randomizes playlist output
def info():
fileName = os.path.basename(sys.argv[0])
print 'Usage:',fileName,'[-qrh] [-l location] [-p playlistname]\n'
print ' -l <dir> scanning location for playlist (default is \'.\' )'
print ' -p <file> set output M3U playlist name (default is \'playlist\')'
print ' -q run in quiet mode'
print ' -r randomize playlist (default is sorted)'
print ' -h display this help\n'
sys.exit(1)
def createM3U():
global playlistName
# This puts output files in correct directories
if location != '.': playlistName = location + playlistName
playlistName = playlistName + '.m3u'
extensions = ['avi','mkv','mp4','m2ts','ogm','mpg','mpeg','ogv','divx','xvid','mp3']
home = os.path.abspath(location)
folderName = home.split('/')
folderName = folderName[len(folderName)-1]
descriptor = '#EXTM3U'
marker = '#EXTINF'
#this is using the 'time' module (depreciated)
#now = str(time.localtime().tm_year)+'.'+str(time.localtime().tm_mon)+'.'+str(time.localtime().tm_mday)+' '+str(time.localtime().tm_hour)+':'+ str(time.localtime().tm_min)+' PST'
now = str(datetime.datetime.now())
playlistF = file(playlistName,'w')
playlistF.write(descriptor + '\r\n')
#final.write(marker + ":" + str(track_length) + "," + artist + " - " + title + "\n")
media = []
for root, dirs, files in os.walk(home):
if verbose: print root # shows which directories are being indexed
for video in files:
if video[len(video)-3:] in extensions:
media.append(root + '/' + video + '\r\n')
count = len(media)
# Create playlists
while len(media)!=0:
media.sort()
if randomize: i = random.randint(0,len(media)-1)
else: i=0
if relativePath: media[i] = media[i].replace(home+'/','')
playlistF.write(media[i])
media.remove(media[i])
# Write EOF
playlistF.write('# Generated '+ now +' PST\r\n# '+str(count) + ' items automatically randomized by Teque5\'s Playlist Generator\r\n')
# Cleanup
playlistF.close
print ' Playlist generation completed.'
if randomize: print ' ',str(count),'items randomized into',playlistName
else: print ' ',str(count),'items sorted into',playlistName
print ' Source directory:',home
if __name__ == '__main__':
try:
optlist, args = getopt.getopt(sys.argv[1:], 'qsrl:p:')
except getopt.GetoptError, error:
print 'Error: %s\n' % error
info()
for op, arg in optlist:
if op == '-h': info()
elif op == '-l': location = str(arg)
elif op == '-p': playlistName = str(arg)
elif op == '-q': verbose = False
elif op == '-r': randomize = True
if len(optlist) == 0: info() # comment to enable script w/o options
# Run Main Function
createM3U()
#!/bin/awk -f
function to_sec(date, t) {
split(date, t, /:/);
return((t[1]*3600) + (t[2]*60) + t[3]);
function to_hr(sec, m, s) {
s = sec % 60;
sec = int(sec / 60);
m = sec % 60;
return(sprintf("%02d:%02d:%02d", sec, m, s));
function shell_quote(str) {
gsub(/'/, "'\\''", str);
return("'" str "'");
BEGIN {
FS = "[(]|%[)][[:blank:]]*$";
/^\[([0-9]{2}:){2}[0-9]{2}\]/ {
split($0, t, /[][]/);
if ((cur = to_sec(t[2])) < lastcur) {
day++;
mod = day * 24 * 60 * 60;
lastcur = cur;
time = cur + mod;
NF != 3 {
next;
!$2 {
wu++;
wu = wu ? wu : 1;
if (!(wu in start)) {
start[wu] = $2;
startt[wu] = time;
if ($2 == 100) {
end[wu] = last;
endt[wu] = time;
steps[wu,$2] = $0;
times[wu,$2] = time;
last = $2;
END {
if (FILENAME != "-") {
cmd = "stat -c %Y " shell_qoute(FILENAME);
cmd | getline mtime;
close(cmd);
mod = (systime() - mtime);
time = time + mod;
if (NF == 3) {
end[wu] = last;
for (i=start[wu]+1; i<=last; i++) {
tot += times[wu,i] - times[wu,i-1];
printf("\nThis WU:\n");
printf("%30s: %02d%%\n", "Current Progress", last);
if (last > 0) {
avg = int(tot/(last-start[wu]));
} else {
avg = time - startt[wu];
printf("%30s: %s\n", "AVG time per percent", to_hr(avg));
diff = time - startt[wu];
printf("%30s: %s\n", "Time spent on current WU", to_hr(diff));
rem = 100 - last;
printf("%30s: %s\n", "ETA to completion", to_hr((avg*rem)-mod));
fin = endt[wu-1];
} else {
fin = endt[wu];
printf("No WU currently in progress\n");
printf("\n");
if (wu > 1) {
perc = ftot = wtot = wus = 0;
for (i=1; i<=wu; i++) {
if (!end[i]) {
continue;
tot = 0;
for (j=start[i]+1; j<=end[i]; j++) {
tot += times[i,j] - times[i,j-1];
perc++;
wuperc = (end[i] - start[i]) / 100;
wtot += int(tot*(1/wuperc));
ftot += tot;
wus++;
printf("\nAll WUs in the log:\n");
avg = int(ftot/perc);
avg = int(wtot/wus);
printf("%30s: %s\n", "AVG time to complete WU", to_hr(avg));
diff = time - fin;
printf("%30s: %s\n", "Time since last completed WU", to_hr(diff));
} else {
printf("No previous WUs in the log\n");
printf("\n");
» check-fah FAHlog.txt
This WU:
Current Progress: 89%
AVG time per percent: 00:16:26
Time spent on current WU: 24:27:07
ETA to completion: 02:57:36
All WUs in the log:
AVG time per percent: 00:10:52
AVG time to complete WU: 18:13:44
Time since last completed WU: 24:34:07
#!/usr/bin/python
#This program will first go through a cleaning process.
#It will suspend virtual machines running inside of virtualbox
#Then it will tar them, attempt to extract the tar and finally it will resume the vms and email the results
Error checking is done by initializing the error variable to ""
in order to check it later. If there is an exception thrown,
the error variable gets reassigned to the thrown error
import os
import sys
import time
import datetime
import fnmatch
import subprocess
########################Global Variables##########################
email_addresses = "stratus"
#Set the time variables. These will be used to determine which files to clean up
#Since time is measured in seconds, we have to do the convertion
#The number of days held is directly related to the available storage space in /archive. If more VMs get added,
#the number of days a file can be held will have to be decreased.
seconds_per_day = 86400
number_of_days = 12
days_to_keep_files = seconds_per_day * number_of_days
current_date = time.time()
archive_path = '/archive/vms/'
#The following creates a new directory in /archive/vms with today's date
todays_date = datetime.datetime.now().strftime("%Y-%m-%d")
todays_directory = archive_path + todays_date
logfile = "/var/log/virtual_machine_logs/vm_backup_",todays_date,".log"
logfile = "".join([str(x) for x in logfile])
old_stderr = sys.stderr
#sys.stdout = open(logfile, "w")
#sys.stderr = open(logfile, "a")
#Initialize the error variables; blank variables mean no errors are present
error_archive = ""
error_suspend = ""
error_tar = ""
error_resume = ""
error_tar_check = ""
#Create the list of Virtual Machines
os.system("vboxmanage list runningvms > /backup_scripts/running_vms.txt")
vmlist = "/backup_scripts/running_vms.txt"
###########################End Global Variables##########################
#Make todays backup directory
try:
os.makedirs(todays_directory)
except:
pass
print "---------------------Starting backup processes on this date: --------->", datetime.datetime.now().strftime("%Y-%m-%d-%H:%M"), "<----------"
#This function reads the vm list from the top. Putting this as a function avoids "cut-and-paste" programming
def read_vm_list():
vm_list = open(vmlist, 'r')
return vm_list
################################################cleanup section ##############################################
#This function crawls through directories as specied. It is used to recursively search
#through the directories in archive2
def find_files(directory, pattern):
for root, dirs, files in os.walk(directory):
for basename in files:
#the fnmatch module is required (import fnmatch) for this section
#after finding the file, os.path is used to create an absolute path
#to the files. The filenames are then returned as a generator
if fnmatch.fnmatch(basename, pattern):
filename = os.path.join(root, basename)
yield filename
try:
print "The current disk usage is "
p = os.popen('df -h |grep -v usr |grep -v tmp |grep -v udev |grep -v var |grep -v home').read()
print p
print "Beginning the cleaning process of /archive"
print "Attempting to remove files from /archive which are older than ", ((days_to_keep_files + (10 * 86400))/86400), " days"
for archive_file in find_files(archive_path, '*.gz'):
#days_to_keep_files + 8 indicates the base number of days to keep a file in /archive and
#The additional number of days it will be kept in /archive2
if os.stat(archive_file).st_ctime < current_date - (days_to_keep_files + (5 * 86400)):
#os.path.basename strips the absolute path of the file away
#for example /tmp/test.file is turned into test.file
#this is done so that tarballs can be created in specific directories
#instead of in the directory where the original file was (which is default action)
try:
print "removing the following file:", archive_file, "--> it is older than ",((days_to_keep_files + (10 * 86400))/86400), "days"
os.remove(archive_file)
except Exception, error_archive:
print error_archive
print "The cleanup is complete and the disk usage is now: "
print os.popen("df -h |grep -v usr |grep -v tmp |grep -v udev |grep -v var |grep -v home").read()
print "-----------------------------------------------------------"
####################################backup procedures ########################################
#This section is a sanity check to make sure there is enough space to complete the backups
free_space = os.popen("df -h |grep archive |awk '{print $3}'").read().strip()
#We are going to assume that the free space will be displayed in Gb so we must strip off the "G" in order to evaluate
#if there is not enough space after the cleaning, abort the program. Based on current backup sizes
#The backups require approximately 200G to complete so we will use 210 as a buffer
free_space = free_space.replace("G", "")
if int(free_space) < 210:
print "Error: there is not enough space on /archive to continue...ABORTING"
#Change stdout back
sys.stderr = old_stderr
#mail the error message
mail_mes = 'mail -s "Not enough space for backup" %s < %s' % (email_addresses, logfile)
os.system(mail_mes)
sys.exit()
else:
print "/archive has at least 210G of free space. Commencing backup."
#Suspend the virtual machines
for individual_vm in read_vm_list():
try:
individual_vm = individual_vm.split(" {")
print ""
print "Suspending: %s" % (individual_vm[0]),
print ""
os.system('vboxmanage controlvm %s savestate' % (individual_vm[0]))
except Exception, error_suspend:
print "The following errors occured: "
print error_suspend
#Change to the directory where the files should be dumped
os.chdir(todays_directory)
#This function returns the total number of tar processes running
def getProcesses(search_process):
number_of_processes = subprocess.Popen("ps ax | grep '%s' |grep -v grep |grep -v .vmx|grep -v .tar.gz |wc -l" % search_process, shell=True, stdout=subprocess.PIPE)
output = number_of_processes.stdout.read()
number_of_processes.stdout.close()
number_of_processes.wait()
return output
############vm_list parsing function ###########
def split_individual_vm(vm):
individual_vm = vm.split(" {")
individual_vm = individual_vm[0]
get_vm_info = os.popen("vboxmanage showvminfo %s" % individual_vm).read()
if "vmdk" in get_vm_info:
#Get the vmdk path from the info
#We only care about the getting the folder name so we limit the output to a single entry
#even if the VM has more than one hard drive
get_vm_info = "vboxmanage showvminfo %s |grep vmdk |awk -F ':' '{print $2}' |head -n 1" % individual_vm
#Get the base name as we want to tar up all the files in the folder
vm_path = os.popen(get_vm_info).read().strip()
vm_path = os.path.dirname(vm_path.replace(" (UUID" ,""))
elif "vdi" in get_vm_info:
get_vm_info = "vboxmanage showvminfo %s |grep vdi |awk -F ':' '{print $2}' |head -n 1" % individual_vm
return vm_path
for vms in read_vm_list():
try:
#This section gets the number of processes so that we know how many tar processes are running at a time
output = getProcesses("tar_virtualbox_vms.py")
vm_path = split_individual_vm(vms)
print "tarring: ", vm_path
####end parsing ####
os.system("python /backup_scripts/tar_virtualbox_vms.py %s %s &" % (vm_path, todays_directory))
time.sleep(1)
#Since vm-server has 8 cores, we are going to set the thread to 7
#We will then ask the computer to wait 10 minutes before attempting another backup process
while int(output) > 5:
time.sleep(6)
except Exception, error_tar:
print error_tar
print "sleeping for 10 seconds"
time.sleep(1)
#resume VMs
try:
vm_path = split_individual_vm(individual_vm)
running_processes = getProcesses(vm_path)
while int(running_processes) != 0:
running_processes = getProcesses(individual_vm)
print "sleeping because this vm: %s is still being processed" % vm_path
time.sleep(600)
print "Resuming: %s" % (individual_vm)
print ""
os.system("VBoxManage startvm %s --type headless" % (individual_vm))
except Exception, error_resume:
print error_resume
print " "
print "VMs have been restarted successfully. Backup process is complete"
print "-------------------------------------------------------------------------"
#####################backup complete#####################
####################check the tar files ###############
for tar_file in find_files(todays_directory, '*.gz'):
try:
while int(output) !=0:
print "there are files still being tarred"
time.sleep(6)
print "checking ", tar_file
sys.stdout.close()
os.system("python /backup_scripts/check_tars.py %s &" % tar_file)
time.sleep(5)
running_tar_checks = getProcesses("check_tars.py")
while int(running_tar_checks) > 5:
time.sleep(6)
except Exception, error_tar_check:
print error_tar_check
except Exception, e:
e = str(e)
print e
sys.stdout = open(logfile, "a")
print "---------------------Backup processes is completed on this date: --------->", datetime.datetime.now().strftime("%Y-%m-%d-%H:%M"), "<----------"
sys.stdout.close()
######send mail ########
counter = 0
email_errors = []
if error_archive != "":
email_errors.append("Error cleaning /archive")
if error_suspend != "":
email_errors.append("Error suspending vms")
if error_tar != "":
email_errors.append("Error while attempting to tar suspended vms")
if error_resume != "":
email_errors.append("Error attempting to resume VMs")
if error_tar_check != "":
email_errors.append("Error while testing tar archives")
os.system("echo 'The following error(s) was ecounter: '%s'.' > /backup_scripts/mail.txt" % (email_errors))
#In python a list which is not empty considered true, therefore if email_errors evaluates to true, run the error messages
if email_errors:
mail_mes = "mutt -s 'Problems with vm backups' -a '%s' '%s' < /backup_scripts/mail.txt" % (logfile, email_addresses)
os.system(mail_mes)
#If the list is blank email no problems
else:
mail_mes = "echo 'The logs can be found at '%s'' |mail -s 'No problems with VM-weekly backup' %s " % (logfile, email_addresses)
os.system(mail_mes)
os.system("rm -rf /backup_scripts/mail.txt")
#!/usr/bin/python
#This program was designed to change the default group of specific people within /etc/passwd
import os
import sys
import fnmatch
import re
import fileinput
if len(sys.argv) < 4 or sys.argv[1] == "-h":
print """
This file is intended to change the default group of users in /etc/passwd
It expects you have a list of users in some text file, the usernames seperated by a whitespace
It will make a backup copy of the file you are working on to /tmp
USAGE
this_script.py <user_list file> <group number to insert> <passwd file location>
exit()
#read the list
peoples_group_to_change = sys.argv[1]
password = sys.argv[3]
people = open(peoples_group_to_change).readlines()
#make the backup
os.system("cp %s /tmp/" % password)
for individual_user in str(people).split(" "):
individual_user = str(individual_user).strip("'[").strip("]").replace("\\n'", "").rstrip()
for line in fileinput.FileInput(password, inplace = 1):
if str(individual_user) in line:
#Split the string into a list so that we can manipulate it
line1 = line.split(":")
#change the group number to the number specified by the user running this script
line1[3] = sys.argv[2]
#Change the list back into a string
line1 = ":".join([str(y) for y in line1])
print line.replace(line, line1),
else:
print line,
#!/bin/bash
# Goes through all jpeg files in current directory, grabs date from each
# and sorts them into subdirectories according to the date
# Creates subdirectories corresponding to the dates as necessary.
do
if [ -e $fil ]; then # if it exists
# try to get date from EXIF tags
datepath="$(exiftags -i $fil 2>/dev/null | awk '/Image Created/{print $3 }' | sed s%:%/%g)"
# otherwise get date from file time stamp
if [ -z $datepath ]; then
datepath="$(ls -g $fil | awk '{print $5 }' | sed s%-%/%g)"
fi
# hack -- this test could be hoisted outside the loop
if [ -z $PICTUREROOT ]; then
datepath=$HOME/Pictures/$datepath
else
datepath=${PICTUREROOT}/$datepath
fi
# Create destination directory when needed
if ! test -e "$datepath"; then
mkdir -pv "$datepath"
fi
# mv -u $fil $datepath
cp -np $fil $datepath
if test ${fil:(-4)} = ".NEF" ; then
fulloutputpath=$datepath/`basename $fil .NEF`.jpeg
echo $fulloutputpath $fil
dcraw -c -w $fil | cjpeg > $fulloutputpath
exiftool -overwrite_original -tagsfromfile $fil $fulloutputpath
fi
fi
done
#!/bin/bash
# set variables
version=$1
make_opts="-j5"
stop_services="nginx" #php-fastcgi
start_services="nginx" #php-fastcgi
function get_version {
if [ -z ${version} ]
then
echo -ne "\nplease enter the nginx version number you would like to upgrade to (ex - '0.8.54'): "
read version
version="nginx-${version}"
echo ${version}
echo -n "is this the version you would like to upgrade to? (y/n): "
read response
if [[ "$response" == [nN] ]]; then
echo -e "\n\nplease try again"
unset version
get_version
else
nginx_source
fi
else
echo -ne "\nupgrading to ${version}";
sleep 3
nginx_source
fi
function nginx_source {
cd /opt
if [ -e ${version}.tar.gz ]; then
echo -e "\n${version}.tar.gz exists, skipping download..."
else
echo -e "\ndownloading source..."
wget http://nginx.org/download/${version}.tar.gz
fi
if [ -d ${version} ]; then
echo -e "\nremoving old source directory..."
rm -rf ${version}
fi
echo -e "\nextracting archive..."
tar zxvf ${version}.tar.gz
chown -R root:root ${version}
cd ${version}
nginx_upgrade
else
echo "${version}.tar.gz did not download correctly!"
exit 1
fi
function nginx_upgrade {
echo -e "\nrunning 'configure' command..."
./configure \
--sbin-path=/usr/local/sbin \
--conf-path=/etc/nginx/nginx.conf \
--error-log-path=/var/log/nginx/error.log \
--pid-path=/var/run/nginx.pid \
--lock-path=/var/lock/nginx.lock \
--http-log-path=/var/log/nginx/access.log \
--with-http_dav_module \
--http-client-body-temp-path=/var/lib/nginx/body \
--with-http_ssl_module \
--with-http_realip_module \
--http-proxy-temp-path=/var/lib/nginx/proxy \
--with-http_stub_status_module \
--http-fastcgi-temp-path=/var/lib/nginx/fastcgi \
--with-debug \
--with-http_flv_module \
--add-module=/opt/ngx_http_auth_pam_module-1.2 \
--user=www-data \
--group=www-data
echo -e "\n\nplease check for configuration errors (press enter to continue)"
read
echo -e "\nrunning 'make' command..."
make ${make_opts}
echo -e "\n\nplease check for make errors (press enter to continue)"
read
echo -e "\n\nnew version number verification\n"
echo "expected: ${version}"
echo -n "actual: ${newver}"
./objs/nginx -v
sleep 1
echo -en "\ndo the version numbers match? (y/n): "
read response
echo -e "\n\ncheck for errors and try again."
post_install_cleanup
fi
echo -e "\nstopping services..."
for i in ${stop_services}
do
/etc/init.d/${i} stop
done
sleep 1
echo -e "\ninstalling ${version}..."
make install
sleep 1
echo -e "\nstarting services..."
for i in ${start_services}
do
/etc/init.d/${i} start
done
function post_install_cleanup {
cd /etc/nginx
if [ ! -d backups ]; then
echo -e "\ncreating backup directory..."
mkdir backups
fi
echo -e "\nremoving example files..."
mv *.default backups/
echo -e "\nremoving extracted source directory..."
cd /opt
rm -rf ${version}
echo -e "\ndone.\n"
get_version
#!/bin/bash
### set variables
version=$1
upgrade_cmd=/root/scripts/upgrade_nginx
list="athena.mbentley.net pandora.mbentley.net vps.mbentley.net pluto.mbentley.net"
#list="athena.mbentley.net vps.mbentley.net pluto.mbentley.net"
then
read version
fi
echo nginx-${version}
read response
unset version
get_version
else
run_upgrades
fi
function run_upgrades {
for i in ${list}
do
echo -e "\n==== executing upgrade on ${i} ====";
ssh root@${i} ${upgrade_cmd} ${version}
echo -e "==== upgrade on ${i} complete ====\n";
done
get_version
#!/bin/bash
/root/scripts/vm_service stop
/etc/init.d/vboxweb-service stop
/etc/init.d/vboxdrv stop
aptitude -y upgrade
## download and install latest extension pack
latest_ver=`curl -s http://download.virtualbox.org/virtualbox/LATEST.TXT`
cd ~
wget http://download.virtualbox.org/virtualbox/${latest_ver}/Oracle_VM_VirtualBox_Extension_Pack-${latest_ver}.vbox-extpack
VBoxManage extpack install --replace ~/Oracle_VM_VirtualBox_Extension_Pack-${latest_ver}.vbox-extpack
sleep 2
rm ~/Oracle_VM_VirtualBox_Extension_Pack-${latest_ver}.vbox-extpack
## restart services
/etc/init.d/vboxdrv restart
/etc/init.d/vboxweb-service restart
sleep 2
/root/scripts/vm_service start
I am pretty sure I have made tweaks to my nginx upgrade script since I originally posted it so here is my latest update:
Code:if [ "$response" == "n" ] || [ "$response" == "N" ]; then
Heh, thanks. I never claimed to be the best script writer ever. I go for pure functionality only
Most things I have just googled for and cobbled together so I greatly appreciate your feedback
#!/bin/bash
for i in {0..255}
do
#Change this IP to whatever range you want
currentip="192.168.0.$i"
currenthost=
echo "Looking up $currentip"
#Do the lookup, parse the output, and store it in the variable
currenthost=`nmblookup -A $currentip | grep "<00>" | grep -v "<GROUP>" | cut -f 2 | cut --delimiter=" " -f 1`
#If the variable is not blank, we got a response
if [ $currenthost ]
then
echo "Found host $currenthost at address $currentip"
echo -e "$currentip\t$currenthost" >> host
fi
done
HST=$(hostname)
USR=$(who -um | awk '{print $1}')
NAME=$(whoami)
if [[ ! -d $HOME/.sh_hist ]]
then
mkdir $HOME/.sh_hist
fi
HISTFILE=${HOME}/.sh_hist/${HST}_${USR}_as_${NAME}_$(date +%F).hist
echo `who -um` >> $HISTFILE
export HISTFILE
#!/usr/bin/python
#This script will create a virtualmachine from the CLI
import os
import sys
import subprocess
#Determine which OS we are running on. I assume either linux or windows
OS = sys.platform
if "linux" in OS:
vbox_binary = "vboxmanage"
else:
vbox_binary = "C:\\Program Files\\Oracle\\Virtualbox\\VBoxmanage.exe"
print ""
print "This program is designed to take your input and create a virtualmachine without having access to the gui"
print ""
print """The most likely OS types are:
WindowsXP_64
Windows7
Windows7_64
Windows2003
Windows2008
Windows2008_64
RedHat
RedHat_64
##############################Bare Minimum VM requirements##############################
#Get the information about the vm from the administrator
vm_name = raw_input("Please enter the name for this vm: ")
vdi_exists = raw_input("Does the virtual disk already exist? ")
#Try asking as few questions as possible. If the vdi already exists we can skip a lot of the questions
if "y" in vdi_exists.lower() or "yes" in vdi_exists.lower():
vdi_location = raw_input("Ok, please enter the location of the vdi: ")
iso_location = "none"
#If the vdi does not exist we need the user to tell us some more information
else:
vdi_folder = raw_input("Please enter the path where the vdi for this vm will be stored: ")
hdd_size = raw_input("Please enter the size of the hdd in Megs: ")
vdi_location = vdi_folder + os.sep + vm_name + ".vdi"
print ""
subprocess.call([vbox_binary, 'createhd', '--filename', vdi_location, '--size', hdd_size])
iso_location = raw_input("Please enter the FULL path to the iso to be used: ")
os_type = raw_input("Please enter the OS Type: ")
ram = raw_input("How much ram should this machine have? ")
number_cpus = raw_input("How many cpus/cores do you want to commit to this vm? ")
#These are the basic requirements of any vm, we will just append to it as options are added
vbox_command = [vbox_binary, 'modifyvm', vm_name, '--memory', ram, '--boot1', 'dvd', '--boot2', 'disk', '--boot3', 'none', '--boot4', 'none', '--cpus', number_cpus]
############################Networking #####################################################
nic = raw_input("""How should the network be configured?
bridged
nat
intnet (Internal)
hostonly (Host-Only)
#Here I am adjusting the networking portion of the modifyvm command
#This just cleans the code up a bit
nic = nic.lower()
if "bridge" in nic:
vbox_command = vbox_command + ['--nic1', 'bridged', '--bridgeadapter1', 'eth0']
elif "nat" in nic or "intnet" in nic or "hostonly" in nic:
vbox_command = vbox_command + ['--nic1', nic]
#We dont want the network to be left blank or be incorrect therefore we default to natted interface
else:
vbox_command = vbox_command + ['--nic1', 'nat']
print ""
#start creating the vm, first, create the dynamic disk
subprocess.call([vbox_binary, 'createvm', '--name', vm_name, '--ostype', os_type, '--register'])
#Do we want to turn on the vrde port?
remote_port = raw_input("Do you want to enable vrde? ")
if "y" in remote_port.lower() or "yes" in remote_port.lower():
vrde_port = raw_input("Which port should vrde listen on? ")
vbox_command = vbox_command + ['--vrde', 'on', '--vrdeport', vrde_port]
#Now that the options have been configured, load them into vbox
subprocess.call(vbox_command)
#Add the ide controller for dvd drives
subprocess.call([ vbox_binary, 'storagectl', vm_name, '--name', '"IDE Controller"', '--add', 'ide'])
#Depending on wheter its Windows XP/2003 or newer such as 7 or 2008, we need to set the hard drive type
if "2003" in os_type or "XP" in os_type:
subprocess.call([ vbox_binary, 'storageattach', vm_name, '--storagectl', '"IDE Controller"', '--port', '0', '--device', '0', '--type', 'hdd', '--medium', vdi_location])
subprocess.call([ vbox_binary, 'storageattach', vm_name, '--storagectl', '"IDE Controller"', '--port', '0', '--device', '1', '--type', 'dvddrive', '--medium', iso_location])
else:
subprocess.call([ vbox_binary, 'storagectl', vm_name, '--name', '"SATA Controller"', '--add', 'sata', '--controller', 'IntelAHCI'])
subprocess.call([ vbox_binary, 'storageattach', vm_name, '--storagectl', '"SATA Controller"', '--port', '0', '--device', '0', '--type', 'hdd', '--medium', vdi_location])
subprocess.call([ vbox_binary, 'storageattach', vm_name, '--storagectl', '"IDE Controller"', '--port', '0', '--device', '0', '--type', 'dvddrive', '--medium', iso_location])
start_vm = raw_input("Do you want to start the vm now? ")
if "y" in start_vm.lower() or "yes" in start_vm.lower():
print "ok starting vm now"
subprocess.call([vbox_binary, 'startvm', vm_name, '--type', 'headless'])
else:
print "ok, exiting the setup program"
lang en_US.UTF-8
keyboard us
timezone US/Eastern
auth --useshadow --enablemd5
selinux --enforcing
firewall --disabled
repo --name=base --baseurl=file:///var/www/html/centos/6/os/x86_64/Packages
repo --name=updates --baseurl=file:///var/www/html/centos/6/updates/x86_64/Packages
repo --name=SIT --baseurl=file:///var/www/html/centos/6/SIT
xconfig --startxonboot
part / --size 4096
services --enabled=sshd,haldaemon,mcstrans,NetworkManager,portmap,restorecond --disabled=anacron,auditd,bluetooth,cpuspeed,gpm,hidd,ip6tables,mdmonitor,microcode_ctl,netfs,network,nfslock,pcscd,readahead_early,readahead_later,rpcgssd,rpcidmapd,cups,abrt,lldpad,mcelog
%packages
syslinux
kernel
@base
@core
@basic-desktop
@internet-browser
@network-tools
@x11
@fonts
mtools
pax
python-dmidecode
genisoimage
nscd
xterm
xorg-x11-xdm
libXmu
gedit
nautilus-open-terminal
-abrt-addon-ccpp
-abrt-addon-kerneloops
-abrt-addon-python
-abrt-cli
-autofs
-b43-fwcutter
-cifs-utils
-dmraid
-firstboot
-fprintd-pam
-hunspell
-hunspell-en
-mdadm
-openswan
-samba-client
-spice-vdagent
-system-config-keyboard
-virt-what
-wacomexpresskeys
-wdaemon
-wireless-tools
-words
# livecd bits to set up the livecd and be able to install
memtest86+
#livecd-tools
anaconda
device-mapper-multipath
isomd5sum
%end
%post --log=/root/kickstart.log
mkdir -p /root/Desktop
#Setup the SITDev install Icon
cat > /root/Desktop/Install\ SITDEV.desktop << EOF_SITDEVIcon
[Desktop Entry]
Name=Install SITDEV
Categories=System;Utility;X-Red-Hat-Base;X-Fedora;GNOME;GTK;
Exec=python /root/dynamic_kickstart_sitdev.py
Terminal=true
Type=Application
Icon=anaconda
Encoding=UTF-8
StartupNotify=true
NoDisplay=true
X-Desktop-File-Install-Version=0.15
EOF_SITDEVIcon
#Setup the SIT-ADMIN install Icon
cat > /root/Desktop/Install\ SIT-ADMIN.desktop << EOF_SIT-ADMINIcon
[Desktop Entry]
Name=Install SIT-ADMIN
Exec=python /root/dynamic_kickstart_sitadmin.py
Terminal=true
Type=Application
Icon=anaconda
Encoding=UTF-8
StartupNotify=true
NoDisplay=true
EOF_SIT-ADMINIcon
rm -rf /etc/yum.repos.d/*
cat > /etc/yum.repos.d/SIT.repo << EOF_repo
[local_base]
name=SIT CentOS
baseurl=http://192.168.88.9/centos/6/os/x86_64/Packages
#baseurl=file:///var/www/html/centos/6/os/x86_64/Packages
enabled=1
gpgcheck=0
[local_updates]
name=SIT CentOS Updates
baseurl=http://192.168.88.9/centos/6/updates/x86_64/Packages
#baseurl=file:///var/www/html/centos/6/updates/x86_64/Packages
enabled=1
gpgcheck=0
[SIT]
name=SIT CentOS Extra
baseurl=http://192.168.88.9/centos/6/SIT
#baseurl=file:///var/www/html/centos/6/SIT
enabled=1
gpgcheck=0
[dag_local]
name=Dag Extras
baseurl=http://192.168.88.9/centos/6/dag_mirror
enabled=0
gpgcheck=0
EOF_repo
## default LiveCD user
LIVECD_USER="situser"
#customize the livecd desktop
echo "rm -rf /root/Desktop/liveinst.desktop" >> /etc/profile
echo "gconftool-2 --set --type string /desktop/gnome/background/picture_filename /root/buildenv.png" >> /etc/profile
echo "gconftool-2 --type boolean --set /apps/nautilus/desktop/computer_icon_visible false" >> /etc/profile
echo "gconftool-2 --type boolean --set /apps/nautilus/desktop/trash_icon_visible false" >> /etc/profile
echo "gconftool-2 --type boolean --set /apps/nautilus/desktop/home_icon_visible false " >> /etc/profile
#get the files which will customize the installer.
#The install script will have to remove the original files and put these files in place
cd /usr/lib/anaconda/iw/
wget http://localhost/scripts/congrats_gui_sitdev.py
wget http://localhost/scripts/congrats_gui_sitadmin.py
wget http://localhost/scripts/gui_sitdev.py
wget http://localhost/scripts/gui_sitadmin.py
cd /root
wget http://localhost/scripts/VBoxLinuxAdditions.run
wget http://localhost/scripts/dynamic_kickstart_sitadmin.py
wget http://localhost/scripts/dynamic_kickstart_sitdev.py
wget http://localhost/scripts/buildenv.png
wget http://localhost/scripts/progress_first.png
cp -f progress_first.png /usr/share/anaconda/pixmaps/
cp -f progress_first.png /usr/share/anaconda/pixmaps/progress_first-lowres.png
# Create a sub-script so the output can be captured
# Must change "$" to "\$" and "`" to "\`" to avoid shell quoting
cat > /root/post-install << EOF_post
#!/bin/bash
echo ###################################################################
echo ## Creating the livesys init script
cat > /etc/rc.d/init.d/livesys << EOF_initscript
#!/bin/bash
# live: Init script for live image
# chkconfig: 345 00 99
# description: Init script for live image.
. /etc/init.d/functions
if ! strstr "\\\`cat /proc/cmdline\\\`" liveimg || [ "\\\$1" != "start" ]; then
exit 0
fi
if [ -e /.liveimg-configured ] ; then
configdone=1
fi
exists() {
which \\\$1 >/dev/null 2>&1 || return
touch /.liveimg-configured
# mount live image
if [ -b \\\`readlink -f /dev/live\\\` ]; then
mkdir -p /mnt/live
mount -o ro /dev/live /mnt/live 2>/dev/null || mount /dev/live /mnt/live
fi
livedir="LiveOS"
for arg in \\\`cat /proc/cmdline\\\` ; do
if [ "\\\${arg##live_dir=}" != "\\\${arg}" ]; then
livedir=\\\${arg##live_dir=}
return
fi
done
# enable swaps unless requested otherwise
swaps=\\\`blkid -t TYPE=swap -o device\\\`
if ! strstr "\\\`cat /proc/cmdline\\\`" noswap && [ -n "\\\$swaps" ] ; then
for s in \\\$swaps ; do
action "Enabling swap partition \\\$s" swapon \\\$s
done
fi
if ! strstr "\\\`cat /proc/cmdline\\\`" noswap && [ -f /mnt/live/\\\${livedir}/swap.img ] ; then
action "Enabling swap file" swapon /mnt/live/\\\${livedir}/swap.img
fi
mountPersistentHome() {
# support label/uuid
if [ "\\\${homedev##LABEL=}" != "\\\${homedev}" -o "\\\${homedev##UUID=}" != "\\\${homedev}" ]; then
homedev=\\\`/sbin/blkid -o device -t "\\\$homedev"\\\`
fi
# if we're given a file rather than a blockdev, loopback it
if [ "\\\${homedev##mtd}" != "\\\${homedev}" ]; then
# mtd devs don't have a block device but get magic-mounted with -t jffs2
mountopts="-t jffs2"
elif [ ! -b "\\\$homedev" ]; then
loopdev=\\\`losetup -f\\\`
if [ "\\\${homedev##/mnt/live}" != "\\\${homedev}" ]; then
action "Remounting live store r/w" mount -o remount,rw /mnt/live
fi
losetup \\\$loopdev \\\$homedev
homedev=\\\$loopdev
fi
# if it's encrypted, we need to unlock it
if [ "\\\$(/sbin/blkid -s TYPE -o value \\\$homedev 2>/dev/null)" = "crypto_LUKS" ]; then
echo
echo "Setting up encrypted /home device"
plymouth ask-for-password --command="cryptsetup luksOpen \\\$homedev EncHome"
homedev=/dev/mapper/EncHome
fi
# and finally do the mount
mount \\\$mountopts \\\$homedev /home
# if we have /home under what's passed for persistent home, then
# we should make that the real /home. useful for mtd device on olpc
if [ -d /home/home ]; then mount --bind /home/home /home ; fi
[ -x /sbin/restorecon ] && /sbin/restorecon /home
if [ -d /home/\\\$LIVECD_USER ]; then USERADDARGS="-M" ; fi
findPersistentHome() {
if [ "\\\${arg##persistenthome=}" != "\\\${arg}" ]; then
homedev=\\\${arg##persistenthome=}
return
fi
done
if strstr "\\\`cat /proc/cmdline\\\`" persistenthome= ; then
findPersistentHome
elif [ -e /mnt/live/\\\${livedir}/home.img ]; then
homedev=/mnt/live/\\\${livedir}/home.img
fi
# if we have a persistent /home, then we want to go ahead and mount it
if ! strstr "\\\`cat /proc/cmdline\\\`" nopersistenthome && [ -n "\\\$homedev" ] ; then
action "Mounting persistent /home" mountPersistentHome
fi
# make it so that we don't do writing to the overlay for things which
# are just tmpdirs/caches
mount -t tmpfs -o mode=0755 varcacheyum /var/cache/yum
mount -t tmpfs tmp /tmp
mount -t tmpfs vartmp /var/tmp
[ -x /sbin/restorecon ] && /sbin/restorecon /var/cache/yum /tmp /var/tmp >/dev/null 2>&1
if [ -n "\\\$configdone" ]; then
exit 0
fi
## fix various bugs and issues
# unmute sound card
exists alsaunmute 0 2> /dev/null
# turn off firstboot for livecd boots
echo "RUN_FIRSTBOOT=NO" > /etc/sysconfig/firstboot
# turn off mdmonitor by default
chkconfig --level 345 mdmonitor off 2>/dev/null
# turn off setroubleshoot on the live image to preserve resources
chkconfig --level 345 setroubleshoot off 2>/dev/null
# don't start cron/at as they tend to spawn things which are
# disk intensive that are painful on a live image
chkconfig --level 345 auditd off 2>/dev/null
chkconfig --level 345 crond off 2>/dev/null
chkconfig --level 345 atd off 2>/dev/null
chkconfig --level 345 readahead_early off 2>/dev/null
chkconfig --level 345 readahead_later off 2>/dev/null
# disable kdump service
chkconfig --level 345 kdump off 2>/dev/null
# disable microcode_ctl service
chkconfig --level 345 microcode_ctl off 2>/dev/null
# disable smart card services
chkconfig --level 345 openct off 2>/dev/null
chkconfig --level 345 pcscd off 2>/dev/null
# disable postfix service
chkconfig --level 345 postfix off 2>/dev/null
# Stopgap fix for RH #217966; should be fixed in HAL instead
touch /media/.hal-mtab
# workaround clock syncing on shutdown that we don't want (#297421)
sed -i -e 's/hwclock/no-such-hwclock/g' /etc/rc.d/init.d/halt
# set the LiveCD hostname
sed -i -e 's/HOSTNAME=localhost.localdomain/HOSTNAME=SIT-BuildEnv/g' /etc/sysconfig/network
/bin/hostname SIT-BuildEnv
## create the LiveCD default user
# add default user with no password
/usr/sbin/useradd -c "LiveCD default user" $LIVECD_USER
/usr/bin/passwd -d $LIVECD_USER > /dev/null
# give default user sudo privileges
echo "$LIVECD_USER ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers
chmod 755 /home/$LIVECD_USER/Desktop/Install\ SIT-ADMIN.desktop
## configure default user's desktop
# set up timed auto-login at 10 seconds
cat >> /etc/gdm/custom.conf << FOE
[daemon]
TimedLoginEnable=true
TimedLogin=root
TimedLoginDelay=2
FOE
# add keyboard and display configuration utilities to the desktop
mkdir -p /home/$LIVECD_USER/Desktop >/dev/null
cp /usr/share/applications/gnome-display-properties.desktop /home/$LIVECD_USER/Desktop/
# disable screensaver locking
gconftool-2 --direct --config-source=xml:readwrite:/etc/gconf/gconf.xml.defaults -s -t bool /apps/gnome-screensaver/lock_enabled "false" >/dev/null
# disable PackageKit update checking by default
gconftool-2 --direct --config-source=xml:readwrite:/etc/gconf/gconf.xml.defaults -s -t int /apps/gnome-packagekit/update-icon/frequency_get_updates "0" >/dev/null
# detecting disk partitions and logical volumes
CreateDesktopIconHD()
cat > /home/$LIVECD_USER/Desktop/Local\ hard\ drives.desktop << EOF_HDicon
[Desktop Entry]
Encoding=UTF-8
Version=1.0
Type=Link
Name=Local hard drives
Name[en_US]=Local hard drives
Name[fr_CA]=Disques durs locaux
URL=/mnt/disc
Icon=/usr/share/icons/gnome/32x32/devices/gnome-dev-harddisk.png
EOF_HDicon
chmod 755 /home/$LIVECD_USER/Desktop/Local\ hard\ drives.desktop
CreateDesktopIconLVM()
cat > /home/$LIVECD_USER/Desktop/Local\ logical\ volumes.desktop << EOF_LVMicon
[Desktop Entry]
Encoding=UTF-8
Version=1.0
Type=Link
Name=Local logical volumes
Name[en_US]=Local logical volumes
Name[fr_CA]=Volumes logiques locaux
URL=/mnt/lvm
EOF_LVMicon
chmod 755 /home/$LIVECD_USER/Desktop/Local\ logical\ volumes.desktop
# don't mount disk partitions if 'nodiskmount' is given as a boot option
if ! strstr "\\\`cat /proc/cmdline\\\`" nodiskmount ; then
MOUNTOPTION="ro"
HARD_DISKS=\\\`egrep "[sh]d.\\\$" /proc/partitions | tr -s ' ' | sed 's/^ *//' | cut -d' ' -f4\\\`
echo "Mounting hard disk partitions... "
for DISK in \\\$HARD_DISKS; do
# Get the device and system info from fdisk (but only for fat and linux partitions).
FDISK_INFO=\\\`fdisk -l /dev/\\\$DISK | tr [A-Z] [a-z] | egrep "fat|linux" | egrep -v "swap|extended|lvm" | sed 's/*//' | tr -s ' ' | tr ' ' ':' | cut -d':' -f1,6-\\\`
for FDISK_ENTRY in \\\$FDISK_INFO; do
PARTITION=\\\`echo \\\$FDISK_ENTRY | cut -d':' -f1\\\`
MOUNTPOINT="/mnt/disc/\\\${PARTITION##/dev/}"
mkdir -p \\\$MOUNTPOINT
MOUNTED=FALSE
# get the partition type
case \\\`echo \\\$FDISK_ENTRY | cut -d':' -f2-\\\` in
*fat*)
FSTYPES="vfat"
EXTRAOPTIONS=",uid=500";;
FSTYPES="ext4 ext3 ext2"
EXTRAOPTIONS="";;
esac
# try to mount the partition
for FSTYPE in \\\$FSTYPES; do
if mount -o "\\\${MOUNTOPTION}\\\${EXTRAOPTIONS}" -t \\\$FSTYPE \\\$PARTITION \\\$MOUNTPOINT &>/dev/null; then
echo "\\\$PARTITION \\\$MOUNTPOINT \\\$FSTYPE noauto,\\\${MOUNTOPTION}\\\${EXTRAOPTIONS} 0 0" >> /etc/fstab
echo -n "\\\$PARTITION "
MOUNTED=TRUE
CreateDesktopIconHD
fi
done
[ \\\$MOUNTED = "FALSE" ] && rmdir \\\$MOUNTPOINT
done
done
echo
fi
# don't mount logical volumes if 'nolvmmount' is given as a boot option
if ! strstr "\\\`cat /proc/cmdline\\\`" nolvmmount ; then
MOUNTOPTION="ro"
echo "Scanning for logical volumes..."
if ! lvm vgscan 2>&1 | grep "No volume groups"; then
echo "Activating logical volumes ..."
modprobe dm_mod >/dev/null
lvm vgchange -ay
LOGICAL_VOLUMES=\\\`lvm lvdisplay -c | sed "s/^ *//" | cut -d: -f1\\\`
if [ ! -z "\\\$LOGICAL_VOLUMES" ]; then
echo "Making device nodes ..."
lvm vgmknodes
echo -n "Mounting logical volumes ... "
for VOLUME_NAME in \\\$LOGICAL_VOLUMES; do
VG_NAME=\\\`echo \\\$VOLUME_NAME | cut -d/ -f3\\\`
LV_NAME=\\\`echo \\\$VOLUME_NAME | cut -d/ -f4\\\`
MOUNTPOINT="/mnt/lvm/\\\${VG_NAME}-\\\${LV_NAME}"
MOUNTED=FALSE
if mount -o \\\$MOUNTOPTION -t \\\$FSTYPE \\\$VOLUME_NAME \\\$MOUNTPOINT &>/dev/null; then
echo "\\\$VOLUME_NAME \\\$MOUNTPOINT \\\$FSTYPE defaults,\\\${MOUNTOPTION} 0 0" >> /etc/fstab
echo -n "\\\$VOLUME_NAME "
MOUNTED=TRUE
break
fi
done
[ \\\$MOUNTED = FALSE ] && rmdir \\\$MOUNTPOINT
done
echo
else
echo "No logical volumes found"
fi
fi
fi
# give back ownership to the default user
chown -R $LIVECD_USER:$LIVECD_USER /home/$LIVECD_USER
EOF_initscript
# bah, hal starts way too late
cat > /etc/rc.d/init.d/livesys-late << EOF_lateinitscript
#!/bin/bash
# live: Late init script for live image
# chkconfig: 345 99 01
# description: Late init script for live image.
if ! strstr "\\\`cat /proc/cmdline\\\`" liveimg || [ "\\\$1" != "start" ] || [ -e /.liveimg-late-configured ] ; then
exit 0
fi
exists() {
touch /.liveimg-late-configured
# read some variables out of /proc/cmdline
for o in \\\`cat /proc/cmdline\\\` ; do
case \\\$o in
ks=*)
ks="\\\${o#ks=}"
xdriver=*)
xdriver="--set-driver=\\\${o#xdriver=}"
esac
done
# if liveinst or textinst is given, start anaconda
if strstr "\\\`cat /proc/cmdline\\\`" liveinst ; then
plymouth --quit
/usr/sbin/liveinst \\\$ks
fi
if strstr "\\\`cat /proc/cmdline\\\`" textinst ; then
plymouth --quit
/usr/sbin/liveinst --text \\\$ks
fi
# configure X, allowing user to override xdriver
if [ -n "\$xdriver" ]; then
exists system-config-display --noui --reconfig --set-depth=24 \\\$xdriver
fi
EOF_lateinitscript
# workaround avahi segfault (#279301)
touch /etc/resolv.conf
/sbin/restorecon /etc/resolv.conf
chmod 755 /etc/rc.d/init.d/livesys
/sbin/restorecon /etc/rc.d/init.d/livesys
/sbin/chkconfig --add livesys
chmod 755 /etc/rc.d/init.d/livesys-late
/sbin/restorecon /etc/rc.d/init.d/livesys-late
/sbin/chkconfig --add livesys-late
# go ahead and pre-make the man -k cache (#455968)
/usr/sbin/makewhatis -w
# save a little bit of space at least...
rm -f /var/lib/rpm/__db*
rm -f /boot/initrd*
rm -f /boot/initramfs*
# make sure there aren't core files lying around
rm -f /core*
# convince readahead not to collect
rm -f /.readahead_collect
touch /var/lib/readahead/early.sorted
EOF_post
/bin/bash -x /root/post-install 2>&1 | tee /root/post-install.log
%end
%post --nochroot
cat > /root/postnochroot-install << EOF_postnochroot
#!/bin/bash
# Copy licensing information
cp $INSTALL_ROOT/usr/share/doc/*-release-*/GPL $LIVE_ROOT/GPL
# add livecd-iso-to-disk utility on the LiveCD
# only works on x86, x86_64
if [ "\$(uname -i)" = "i386" -o "\$(uname -i)" = "x86_64" ]; then
if [ ! -d \$LIVE_ROOT/LiveOS ]; then mkdir -p \$LIVE_ROOT/LiveOS ; fi
cp /usr/bin/livecd-iso-to-disk \$LIVE_ROOT/LiveOS
fi
# customize boot menu entries
grep -B4 'menu default' \$LIVE_ROOT/isolinux/isolinux.cfg > \$LIVE_ROOT/isolinux/default.txt
grep -B3 'xdriver=vesa' \$LIVE_ROOT/isolinux/isolinux.cfg > \$LIVE_ROOT/isolinux/basicvideo.txt
grep -A3 'label check0' \$LIVE_ROOT/isolinux/isolinux.cfg > \$LIVE_ROOT/isolinux/check.txt
grep -A2 'label memtest' \$LIVE_ROOT/isolinux/isolinux.cfg > \$LIVE_ROOT/isolinux/memtest.txt
grep -A2 'label local' \$LIVE_ROOT/isolinux/isolinux.cfg > \$LIVE_ROOT/isolinux/localboot.txt
cat \$LIVE_ROOT/isolinux/default.txt \$LIVE_ROOT/isolinux/basicvideo.txt \$LIVE_ROOT/isolinux/check.txt \$LIVE_ROOT/isolinux/memtest.txt \$LIVE_ROOT/isolinux/localboot.txt > \$LIVE_ROOT/isolinux/current.txt
diff \$LIVE_ROOT/isolinux/isolinux.cfg \$LIVE_ROOT/isolinux/current.txt | sed '/^[0-9][0-9]*/d; s/^. //; /^---$/d' > \$LIVE_ROOT/isolinux/cleaned.txt
cat \$LIVE_ROOT/isolinux/cleaned.txt \$LIVE_ROOT/isolinux/default.txt \$LIVE_ROOT/isolinux/textboot.txt \$LIVE_ROOT/isolinux/basicvideo.txt \$LIVE_ROOT/isolinux/install.txt \$LIVE_ROOT/isolinux/textinstall.txt \$LIVE_ROOT/isolinux/memtest.txt \$LIVE_ROOT/isolinux/localboot.txt > \$LIVE_ROOT/isolinux/isolinux.cfg
rm -f \$LIVE_ROOT/isolinux/*.txt
# Forcing plymouth to show the logo in vesafb
sed -i "s/rhgb/rhgb vga=791/g" \$LIVE_ROOT/isolinux/isolinux.cfg
# Disabling auto lvm/disk mount (that will crash the "Install to Hard Drive feature")
sed -i "s/quiet/quiet nodiskmount nolvmmount/g" \$LIVE_ROOT/isolinux/isolinux.cfg
# Fix the "liveinst doesn't start in gui mode when not enough memory available" - switching to terminal mode
sed -i "s/Terminal=false/Terminal=true/" \$LIVE_ROOT/home/centoslive/Desktop/liveinst.desktop
EOF_postnochroot
/bin/bash -x /root/postnochroot-install 2>&1 | tee /root/postnochroot-install.log
%end
%post --log=/root/post-post_install.log
yum remove samba* abrt cups pulseaduio -y
yum update -y
yum install kernel-devel kernel-headers gcc samba make -y
#export KERN_DIR=/usr/src/kernels/2.6.32-279.5.1.el6.x86_64/
sh /root/VBoxLinuxAdditions.run
%end
