- Apr 22, 2001
I got my nice shiny new AXIA 1GHz only to find it being a bit of a pain to overclock.
System:
M/B: Abit KT7A-Raid
Cooler: Globalwin WBK38 (with arctic silver compound)
BIOS Version: Evaluation BIOS for SBLive fix that was posted on www.viahardware.com recently.
I've closed all the L1 bridges, tested it and it works fine up to 8.5 * 133Mhz, to give 1133Mhz, using the standard 1.75V
I am having problems getting anymore than this - the system won't even POST (I've increased the voltage up to 1.85V). I've even lowered the FSB to 100MHz and tried combinations of that but it's having none of it.
However, there is one setting in the BIOS which does work and I can't figure out why, it's the setting that says 1250~1700(100), with an automatic 12.5 multiplier.
This then boots the system at 12.5 x 104Mhz (1300MHz) and POSTs fine at 1.75V !!
What the F*** is going on with this board and CPU? I can't get it to POST at anything between 1133Mhz and 1300Mhz with the other settings, but this one setting does allow it to?
Advice please before I lose my head!
Thanks!
System:
M/B: Abit KT7A-Raid
Thanks!
