Well, its been a real bad day. I picked up a AXIA 1 GHz, 200 fsb, Week 12 Athlon yesterday and brought it home to play with.
I swapped out the motherboards in my computer and my fiancees computer, putting her Duron 700 in my Abit KT7 and putting my shiny new AXIA in her KT7A-Raid.
I had no problems with her computer at all, so on to my new AXIA and a little fun.
I prepared my new CPU with some Arctic Silver and popped on my trusty FOP38 and went into my office to boot her up.
Problem 1
Upon the initial boot with my new cpu I had the case open, watching to make sure all is well. I here a little pop as the notorious FOP38 clip came off and watched my heatsink come loose from the CPU. I pull the power as fast as humanly possible, smell ozone, and I am worried my new AXIA has died at the hands of a cr@ppy clip design.
Back to the bench to take a look. No visible burning, no cracking, no crunched core. Fix the clip and try again.
Now I am back on track. Everything boots fine, I can change the multiplier (so the pencil trick worked again!) and I watch as the core temperature hovers around the 100 deg F mark. Not bad at default voltage etc.
Problem 2
I am feeling a little bit better about things so I try to boot into windows at defualt speed (1GHz, 200fsb) and low and behold I can't get into windows. I remember when setting this machine up for my fiancee that AGP4x wouldn't work for her GeForceMX, and that is exactly what I have it set for. I guess I am gonna flash the bios and see what happens.
BAM! Midway through the bios flash and the power blips. This can't be good.
Cross my fingers and boot it again, no video, no memory count, no hard drive activity, nothing. Fans turn on etc, but I am not getting anything.
Question 1
Now I have to debate between 2 problems and I am looking for a little help from you fiends out there. Its obvious the bios is trashed and needs to be replaced. Can anyone tell me what the shipping revision is on the KT7A-Raid? I was trying to flash it to WZ, but I am going to need to know the shipping version when I order a new bios chip.
I know about the swapping of chips trick and could probrably do that with the bios out of the KT7 since its the same bios really, but I am unwilling to take that risk. My fiancees computer is her business so I can't risk hers. Gonna have to order a new bios for the KT7A-Raid. Any information you could give me on this would rock as well.
Question 2
What do you guys think is the probrability of my AXIA surviving the numerous setbacks today? Fate seemed to enjoy cr@pping on me today, not my best outing with a new CPU.
EtOH
Problem 1
Problem 2
Question 1
Question 2
EtOH
