ALTAR IN TEMPLE OF TIME:
(There are three hollows and an inscription here....)
Ye who owns 3 Spiritual Stone - Stand with the Ocarina of Time - And play the Song of Time
(That is how the inscription reads.)
NAVI, SEEING THE MASTER SWORD:
Link, isn't that...?!
(flies over to it)
It's that legendary blade... The Master Sword!
Link Pulls the Master Sword
GANONDORF, TALKING TO LINK TELEPATHICALLY:
Geh heh heh! Excellent work! As I thought, you held the keys to the Door of Time! You have led me to the gates of the Sacred Realm... Yes, I owe it all to you, kid!
(long, roaring laugh)
RAURU, WHEN LINK WAKES UP IN THE CHAMBER OF SAGES:
Link... Wake up... Link, the chosen one... I am Rauru, one of the ancient Sages... Ages ago, we ancient Sages built the Temple of Time to protect the entrance to the Sacred Realm... This is the Chamber of Sages, inside the Temple of Light...
The Temple of Light, situated in the very center of the Sacred Realm, is the last stronghold against Ganondorf's evil forces. The Master Sword--the evil-destroying sword that you pulled out of the Pedestal of Time--was the final key to the Sacred Realm. Link... Don't be alarmed... Look at yourself...!
(Navi: Look Link! You're big now!! You've grown up!)
The Master Sword is a sacred blade which evil ones may never touch... Only one worthy of the title of "Hero of Time" can pull it from the Pedestal of Time.... However, you were too young to be the Hero of Time... Therefore, your spirit was sealed here for seven years. And now that you are old enough, the time has come for you to awaken as the Hero of Time! Well, do you understand your destiny?
(yes)
But, remember... Though you opened the Door of Time in the name of peace...
Ganondorf, the Gerudo King of Thieves, used it to enter this forbidden Sacred Realm!
He obtained the Triforce from the Temple of Light, and with its power, he became the King of Evil... His evil power radiated from the temples of Hyrule, and in seven short years, it transformed Hyrule into a world of monsters. My power now has only little influence, even in this Sacred Realm... Namely, this Chamber of Sages. But there is still hope... The power of the Sages remains. When the power of all the Sages is awakened... The Sages' Seals will contain all the evil power in the void of the Realm... I, Rauru, am one of the Sages... And... Your power to fight together with the Sages makes you the Hero of Time! The Hero of Time, chosen by the Master Sword! Keep my spirit with you... And, find the power of the other Sages and add their might to your own!
(You received the Light Medallion!
Rauru the Sage adds his power to yours!)
(white screen)
Find the other Sages and save Hyrule!
Alrighty, update time
this time, its mostly been a lesson in frustration
I concidered and mused over putting a floppy in this rig, even though I really didnt want to. Eventually I gave in and figured, ehhh why not, it wont hurt. I took apart the floppy with no problems, sanded, painted, and started to put things back, when the thing started falling apart... first the top part under the actual top, then a random spring flew out when i was trying to put that part back in... after that I knew it wasnt going back together, so i decided to do this.
hahaha... ahh well, I didn't want it in the first place
onward
I started working on the door..
first by dremeling off the area around where a case badge would go, then came bondo time. First time around, I got it perfect... then the next day realized i didnt use enough hardner.... arrrrgh.. so I scraped it all off (as best i could) and had another go.
This is a shot of the 2nd round, after applying the new bondo coat on both the door and front panel. I sanded away on the door... to find out that the old bondo that was still left was coming back to haunt me... so i ended up scraping all the new bondo off, and found out that the unhardened bondo made the surface melt slightly.. ack
i'm going to give up on this door, and try a clean palette with the spare (thank you so much antec!!)
After that, I sanded down the front nicely, and decided it was time for primer
after priming, i see a few small errors that i just cant stand. I will be applying another application of bondo, smoothing thinly and hand sanding - i think using the drill sander caused me to be a little over zealous, resulting in the red circled area (if you can notice it, its basically not completely even with the original surface in some areas)
ahhhh, so much to do, and winter is quickly approaching
I have decided not to bother with using this case as my Art final project, but instead using a different completed mod. Theres no way i'll get this done by december 5th haha
thats all for this update, hope to have more in the upcoming week
