Link...
The time has come to test thy courage...
I have been cursed...
I need you to break the curse with your wisdom and courage.
Dost thou have courage enough to undertake this task?
The Curse: A stock case (Antec slk3700amb)
The Remedy: Modification
I have been a huge fan of the Legend of Zelda series, ever since I played Ocarina of time (yes I know that isnt very far back in the LOZ chronology, but this game hooked me with its deep story, wonderful layout and design, and for the time beautiful graphics.)
No one has made a Zelda themed case to my knowlege, and I feel that it deserves a tribute.
With that said, on with the work log!
for original stock images check out:
http://www.newegg.com/app/Showimage...22-06.JPG/11-129-122-02.JPG/11-129-122-01.JPG
first thing first, I cut out the back stock fangrill, the hexigonal shapes made it a bit of a hassle because they left holes where there shouldnt be, but i plan to fix that soon
I decided, before I go ahead with sanding the main case, I wanted to work on the psu. The color scheme for the outside is planned to be Green, with black accents, and other colors in accordance to design. First up, disassembly, but I ran into a snag. Other psu's i've worked with came apart with no problem, but this one had some little circuit board with an aparatus i'd guess was power surge protection, take a look in the pic below
So to work around that, i cut the wires connecting it to the psu and slipped a sandwich bag over/though the hole and taped it tightly at the end. From there it was ready to sand.
all sanded and ready for painting
More on the way very soon!!
