I have the 9800 XT with out of the box CAT 6.14.10.6387 drivers. I would like to O/C this card with either different drivers or some sort of utility that will allow me to adjust the core & memory clocks. Would like to raise my score a little.
the cat 3.2's are the best for benching as of this time...and you can use radclock to overclock the 9800 XT, if it didnt come with a OCing program on the CD...
If you enable overdrive while using a 3rd party clocker it will scale you down at unsafe temps. I think people are running up to 440+ air. Overdrive itself will put you at 432 on your core.
Try it on for a while and see which you like better. It uses the on board sensors to regulate the core's frequency according to your temps. At this time it only does the core so you can use a 3rd party utility to adjust the Ram and push the coare a little further.
