- Dec 23, 2002
- Doylestown, PA
Hey guys, I seem to have run into a pretty debilitating problem. For the past three days or so when my computer was shut down, restarted, or whatever, when I tried to boot up, it would take me to the screen where it says that windows was shut down due to hardware or software problems. When I chose to boot into and type of safe mode, "Last known good configuration, or to start Windows normally, it would simply restart and do this cycle eternally. I figured out that if I shut it down for a good hour or so though it would boot fine afterwards.
Well today the computer was shut down accidentally by my little brother. He was playing around on the internet, and he kicked the button on my surge protector, and turned everything off. I tried to boot, but the same problem as before. So I turned off the power to the power supply and waited a good hour or two, tried again....same cycle. I have been doing this since 3 this afternoon and no sucess.
I finally said "well crap, I may just have to format and re-install windows". So I went into the BIOS and switched the boot order to boot from my XP home disc, since the XP Pro disc is messed up. The computer would not boot from either CD-ROM. So, I went back into the BIOS and made every "boot from" option CD-ROM. Got a "Please insert system disc and press enter error" no matter which CD-ROM I put the CD into....I know it's a bootable CD since I have used it before. Next try was using all different IDE cables.....still no go.
I am at a loss as to what to do. Could the surge protector sudden shut down have done any damage? Is there any way to recover the data on the HD? Could it possibly be something with the PCI bus on the board? I cannot figure out a solution....I seriously need some help.
