in my case i have 3 80mm intakes, 92mm and 80mm in the psu and a 120mm blowhole. cpu heatsink is the sp-94 (considered the best heatsink by many). voltage is at stock. overclock is 3.3ghz on a 2.4. cpu fan is a 80mm high speed panflo on 12 volts. case fans are on 8volts and blowhole is on 6-7. i also have a vga silencer on the vid card. i get very good temps. case is usually around 25C and the cpu is around 33C when folding with two folding consoles. my room temp is probably 70-74 or so on average....the reason i feel my cpu temps are fairly accrurate is because ive felt the heatsink near the base and the heatpipes on the side and i dont notice a difference...its not colder than my fingers and its not warmer. so the temps are fairly accrurate. 39C, which you claim isnt possible without a 50C room temp, is 102F....the temp under your tongue (which is warmer than that of your fingers) should be 98F....my hands are usually cold compared to others.....therfore i believe my temps are accurate give a few degrees in either direction. when i come home at about 3...the temp in the house is about 76-78 degrees...even warmer in my room because the air conditioning is turned off and the windows are closed during the day...my case temps were 28 (mind you the censor is in the lower left hand corner, under my sound card, so its warmer there than most areas in the case) and the cpu temp was 36.....
with stock cooling and normal room temps, under 39C is probably not possible. however, with a good aftermarket heatsink, such as the thermalright sp-94 and 97, and good case air flow....under 39C is definatly possible and the results are comparible to some very good WC setups. however, it will usually be louder.
if people would use the search tool or read some stickies, they would find out that as long as your stable, temperature doesnt really matter, however as a vantage point, anything under 50C should be good.....however most cpus can take a lot more..but they become less and less stable with higher temps.
im not trying to bash the starter, but if your using a stock heatsink, you shouldnt be complaning of 50C temps, espcially since you live in Arizona (assuming you live in the lower half where its already in the 90s)
