- Feb 12, 2001
- Fayetteville, AR
Ok well I have not yet broken down and considered H2O, as I travel to Dallas now and again to LAN and such so I want enclosed portability - that being said I was looking at the newest HS on www.sidewindercomputers.com and saw that most if not all of the good ones, including the heatpipe one all mount via the 4mobo holes and no clips, I really dont want to have to take out my mobo 2x per day when im testing stuff w the heatsink
so what is the best HS that I can get that still uses the clip method, currently I have the "Thermalright ax-478" using a normal 80mm fan, its lapped and using as3.
Is that HS still a viable one, my 3.2c idle is showing 50-52c in BIOS, but seeing as how its an abit board its 8-10c high - but I just want a better HS that I can use and throw a 92mm fan on possibly
TYIA
TYIA
