CandymanCan
Disabled
- Aug 14, 2003
- Woodbridge, Va
Youre cpu the 0304 is an older unlocked Tbred, so youre lucky, the week's 0340 and above are locked, ?(thier Multies i mean)
You should be able to overclock alot then this, Raise the vcore to 1.85v, with the stock HSF you shuld be able to reach like 2200 mhz, you raise or lower the multi.
You have some pc2700 ram, do this before u do anything first. Lower the cpu multi to its lowest, Like 9 or something , then raise the RAM FSB to 166 (also raise the memory voltage to its max witch is like 2.8 or 2.9 on most boads.) After you raise the meory voltage then raise the fsb to 170, if it boots into windows and everything seems to run fine, try 175, then 180 and so on, Once youre computer gets error's or is instable or doesnt boot , Lower it back down by 5.
After you find out youre highest Possible FSB speed with youre memory, then you gradually raise the cpu Multi to like 8 or 9 or 10. Here say if u got 180fsb max on youre memory, then raise the cpu multi to 11, 11x180= 1980mhz, if it runs fine, then go to 12x180, 12x180=2160mhz, Dont forget to keep the cpu voltage @ 1.85v, After that if its stable in windows and prime95 for at least 30 minutes, raise the multi to 12.5x180=2250mhz (if u have that option) If you dont have 12.5 try 13x180.
Im using 180 as my Basis, you may or may not get 180fsb Just try what i said above first to see how far ur memory will go, then start to overclock the cpu.
