SantiMun said:
I just got my sapphire 9800pro today. I don't want take the heatsink/fan off yet until I get my vga cooler. It's got the hynix memory but I couldnt find the temp monitoring chip. It also has the black plastic mounts instead of the gold metal ones. Does my card have the R360 core or do I have to RMA this thing??
I have the EXACT same card, except Built by ATi.
I pulled off the heatsink and it was R360, but I would suggest you add some AS Creamique or AS5 because that thing heats up really hot.
Btw is your hynix have something on it saying F-28? I think that means it handels ~385mhz! which is higher than XT speeds, hehe. The VGA Silencer will help a lot. Right now I'm running on stock cooling with AS5 which stoped it from crashing, and I up'd the agp voltage to 1.7. I suggest you do the same. Your card will most likely be a R360 because it looks exactly like mine, except its a built by ati not saphire heh.
and no it doesnt have the temp monitoring on it nor does it have overdrive tab(if you do have the OD tab and dont have the monitoring chip, DONT TURN IT ON, or it will just keep on increasing clock speeds until is fries).
runs on 9800xt speeds fine on stock cooling for now, ima upgrade the cooling to whatever i can find thats NOT online hehe, no credit card.
are you sure its not a bba, because it has the bba heatsink, saphire has different heat sinks i thought.... hummmm
