- Jul 14, 2004
- Long Island
i just got a maze 4 for my evga 5900 and when i tryed to take off the stock heatsink it was really stuck on there from the thermal paste. after a few minutes of trying to get it off i gave it 1 final tug and off it came. but the heat spreader looks bent up not much but you can tell by looking at it. did i damage it taking it off or could it of come like that because i read a few reviews on the cards and they say the heatspreader isnt totally flat. should i just press on the maze 4 and tighten it alot or take it off and put the block directly on the core? i need help with this asap.
thanks for looking
-Bobby
thanks for looking
-Bobby
