ColtIce
Disabled
- Nov 20, 2002
- 9 months 43202 summer months 98951
this just started happening yesterday and it has me stumped.specs are all in sig and I am running XPpro sp2.Tuesday I went out and got Star Wars Battlefront and played it for a good 6 hours with no problems.Then yesterday I go to start it up and *BAM* reboot.so I'm thinking hmm my overclock is memtest/prime/3dmark stable but we had turned the AC off and temps had risen about 8c so I lower my overclock and voltage as well as turn the ac back on.same problem.at that point I said lets reinstall a few things and see if that helps so I reinstall DX9c,cat 4.9,audigy drivers,and chipset drivers for good measure.same problem.I then run the hard drive test from western digital on both of my HDD's and they come up clean(0 errors).I have done check disk and again it came up clean.at this point I'm down to thinking it is one of two things,either my psu is going out(tests strong with DMM and the only rail that moves is the 12v from 12.10 to 12.00 at full load) or my windows install is somehow corrupt.
I have checked the error log and the only thing that appears out the ordinary is some error with the sojubus which I googled but came up with very little info.sorry for the long post but I wanted to give as many details as possible.
