- Aug 18, 2004
Will get some Pics up relativley soon.
Well its gunna be a 2' high, 3' wide and about 9 inch deep wood PC thats going to be mounted on the wall behind my monitor. My dads crazy and said he was going to build his own case and mod the hell outta it so I had no choice but to support him.
Its going to be a water cooled PC, a Laing 4 GPM pump thats beent painted metallic blue, a Black Ice II Extreme radiator ( I can't convince him to get anything else :sigh: ). A swiffy P4 waterblock, cant remeber the name. A swiffy 9800 block. Hes cooling a 2.8 ghz P4, a 9800, he just finished ordering an A-bit ICG-7 Max-II, blue sleeving kit etc... There will be two comparments, the right compartment will be about 6 inches wide and will hold drives, power switch and radiator. The left will hold all the other parts, including the Pump. We are ripping a few pieces out of his and my old dell to use for drive mounting, PCI bracket etc...
So tell me what you think, I will get more detailed specs up about the pump once I get some pictures in.
The cabinet will be made out of Birch, We just got a piece of Birch for teh back and are trying to find 2x10's for the sides. The front will haev two windows, one in the main compartment and the other showing off the rad. It will have white lighting, with blue water and pretty much anything we can paint blue.
