Working on a xp home pc with an aopen ax37 mobo setup with raid1.The owner has it setup wrong since it's only seeing 1 30gig drive instead of 1 60gig (2 wd 30gig drives).I'm new to raid so I need help.I think it has to do with his jumper settings which one drive has no jumper and the other does.In raid1 mirror should both drives have the same jumper pin setting?Can I run both with no jumper pin?Lastly when making changes to get this working correctly will it damage the os and or data thats on the drives?The box boots very slow but runs ok,bios does not see the drives correctly and systems scans ide drives on every boot.
