- May 9, 2004
- Check your Six...
Ok, Im gonna be on the market for a new set of ram modules, I NEED 1gb (or 512mb, if cheap enough), as farcry seems a bit laggy...
I want TCCD ram, at speeds of PC3700 or HIGHER.
As I need to hit speeds of 300HTT or higher, with a 9x multi.
Links to the ram would be great!
I dont want to get a DDR booster for adding more volts.
Also, $200 is the budget.
And has to work with my Neo2
