MSI K8N Neo2 Owners Post your rig and settings!
crash0veride007
In and effort to help all owners/prospective buyers of the MSI K8N Neo2 Platinum board, I am posting my most current stable OC settings... Feel free to join in and post your rig and it's stable OC settings!
Pics of my rig can be found
HERE --> http://thematrix.homelinux.com/Pix/pix.html
MOBO: DUH! Bios Version Beta 1.51
CPU: AMD Athlon FX53 Stepping A REV. SH7-CG WC'd by lapped dangerden RBX Artic Silver 5
Memory: OCZ 3200 Platinum Rev2 2x512 2-2-2-5 in slot 1&2
Video Card: Ati Radeon x800 XT PE shim removed & WC'd by lapped D-tek GPU block Artic silver 3 & Lapped ramsinks added to all 8 GDDR3 chips.
HDD: WD Raptor 74Gb on SATA port 3
Sound Card: Soundblaster Audigy 2
Power Supply: Antec Truepower 550
Case: lian-li PC65
Radiator: danger den Double Heater Core cooled by 120mm panaflow
Reservoir: custom res....
Pump: Eheim 1250 @ 318Gph
N-force is cooled by lapped vantec copper orb
Coolant = Distilled water + water wetter + green dye-lite
BIOS VERSION = Beta1.51
Cell Menu-->
Memory Submenu --> Auto, 1T, 2.5, 3, 5, 3
Cell Menu-> shift+F2 then Alt+F3 -->
Hiperf = manual
agp drive = disabled
speedup = disable
Dram Strength = normal
spread-spec = disabled
HTT = 4x
Mult = 10.5x
FSB = 253
agp = 66
vcore = 1.55
vid = 3.3%
vdimm = 2.75
agp =1.65
My radeon is clocked @ 560/572
Hardware in Sig
BIOS VERSION = 1.3
Cell Menu-->
Memory Submenu --> 166, 1T, 2-3-3
Hiperf = manual
speedup = disable
HTT = 4x
Mult = 10x
FSB = 240
agp = 67
vcore = 1.55
vid = 8.3%
vdimm = 2.70
agp =1.50
it seems to be pretty stable. I was able to run a semi-stable 280fsb(still tweaking) for the first time after flashing it..
Thanks a bunch...im gonna flash shortly
The water cooling system on your pc is homemade?
How much we spend in a good watercooling system?
the blocks, pump, and heater core(radiator) and tubing are not but the fittings and the res are homemade.
danger den RBX CPU Waterblock --> $52.95
D-tek GPU Waterblock --> $42.99
danger den fill valve --> $11.95
eheim 1250 --> $105
tubing --> $1.25
danger den chevette double heater core --> $34.99
custom res-- $30
misc fittings --> $20
clamps --> $7.50
Distilled Water --> $1.05
Water Wetter --> $3.50
Dye Lyte --> $8.99
Total --> $320.17
MOBO: DUH! Bios Version 1.3
CPU: Winchester 3000+ @ 2.45ghz (272 x 9) - Stock AMD Heatsink (came with older S754 CPU) w/ Thermaltake SmartFan II
Memory:2 x 512mb PQI "turbo" PC3200 (Samsung TCCD) @ 272mhz 3-3-3-8 1T
Video Card:FIC A95P Radeon 9500 Pro @ 400mhz clock, 300mhz memory
HDD:2 x 80GB Hitachi 7k250 SATA in Raid 0 (SATA ports 3+4)
Sound Card: Onboard
Power Supply: Fortron "Aurora" 400W w/ 120mm Fan
Case: Chieftec Full-Tower (not sure of model #)
Stock chipset cooler has been replaced with an actual actively cooled heatsink (stock is just a fan attached to a metal base) obtained from an older Soltek Socket A board.
BIOS VERSION = 1.3
Cell Menu-->
Memory Submenu --> Auto, 1T, 3, 3, 8, 3
Cell Menu->
Hiperf = manuall
aggressive timings (don't remember exact wording) = enabled
HTT = 4x
Mult = 9x
FSB = 272
agp = 72
vcore = 1.45V
vdimm = 2.7V
agp =1.55V
hardware see sig, prime stable up to 250x10, RAM get unstable after that but can boot up to 285x10(stoll stock cooled WC setup in developpement). I'm waiting for some OCZ PC3200 plat rev.2(in the mail). That was on 1.33 bios, just flash to 1.51 and I'll get tweaking once I get me new ram.
Tekko what make is your radeon IE sapphire, MSI, Asus...?
Reason I ask is I have my x800 xt PE fully tricked out as you can see and I am not getting anywhre near the OC you have in your sig....
This is kinda a double post as I have posted / asked the same question in the CPU forum, but hopefully somebody here can help me out as I'm lost.
t this point, my system will boot, but windows will not, even in save mode. My settings are as follows:
Current CPU Clock 2403 Mhz
Current DDR Clock 267 Mhz
Dram Configuration
.....Max MemClock.............Auto
.....1T/2T Memory Timing....1T
.....CAS Latency...............2.5
.....RAS to CAS Delay........3
.....Min RAS # TRAS........10
.....Row Percentage Time...3
High Performance Mode......Manual
Aggressive Timing.............Disabled
Dynamic O/C....................Disabled
HT Frequency..................4x
Cool 'n Quiet....................Disabled
Adjust CPU Ratio...............STARTUP
Adjust CPU FSB Freq.........267
Adjust AGP Freq...............66
Adjust CPU VID................1.500
CPU Voltage....................Over VID %3.3
Mem Voltage....................2.75v
AGP Voltage.....................1.65v
Also, I have my AGP aperature size set to 256 in the Advanced Chipset menu (is this correct?)
I can get windows to boot up to 245, but anything above that and it will not.
It might also be worth pointing out that I have not reformatted / reinstalled since moving my SATA drives from the ports 3&4 (as marked on the board) to 1&2 (the ones closest the the cpu). Could that be part of the problem?
Oh, and my memory is in slots 1 and 2 versus 1 and 3. Correct?
Thanks,
Griffin
Dram Configuration
Thanks,
Griffin
what CPU are you running IE: model/stepping also what brand/model memory are you using? Also you are trying to run your hyper transport @ 1068Mhz drop the HTT down to 3x instead of 4x for anything above ~253-4Mhz FSB
Id like to know what voltage settings everyone is using to reach 2.5ghz and to what Ram settings as well. W/o adjusting anything Ive set it to 2.3ghz no problem.. I tried going higher to 2.5ghz downing to 3x HT and it wouldnt boot.. didnt change the voltage or timings at all though.. Just havent had enough time to play with it. Anyone give me a starting point please.
