Results 1 to 15 of 15
01-27-05, 08:28 PM #1
Quick and Easy guide on how to apply Arctic Silver
HOW TO APPLY ARCTIC SILVER
Anything in Blue indicates that that should only be done with AS1, AS2 or AS3
For all types of Arctic Silver:
Clean the mating surfaces with high-purity Isopropyl Alchohol (rubbing alchohol) thoroughly.
Arctic Silver 5 and Céramiqúe, Arctic Silver 1, 2, 3, or Alumina with a CPU/GPU with an IHS - Put a small blob of Arctic Silver 5 or Céramiqúe in the center of the IHS/die of your processor/GPU. It should be about the size of a B.B. Now put a small amount on the heatsink where the CPU/GPU die or IHS will meet with the heatsink, and spread it with a finger in a plastic bag until the paste gets very thin and almost dissappears. Now, mount the heatsink correctly, and twist it a few degrees to the left and right if possible...
This is the correct amount of TIM to use with a properly lapped heatsink:
http://www.bostonrinkrats.com/solidx...pplication.jpg
Note that not a SINGLE PORTION of that 'blob' of Ceramique is taller than 2mm. It is a very thin 'blob', but not as thin as it gets to be after the heatsink is applied. You can also make a smaller 'blob', but taller, but I prefer to do this. No difference
Arctic Silver 5 and Céramiqúe, Arctic Silver 1, 2, 3, or Alumina on an OPEN-DIE CPU/GPU - Place some Arctic Silver on the die of your processor/gpu. Get a CLEAN razor blade, and spread the thermal paste around the whole die. Now put a small amount on the heatsink where the CPU/GPU die will meet with the heatsink, and spread it with a finger in a plastic bag until the paste gets very thin and almost dissappears. Now, place the heatsink on the mating IHS/die, and mount. Twist a little bit to close voids between the mating surfaces...
This is how it should look spread:
http://www.bostonrinkrats.com/solidx...Open%20Die.JPGLast edited by SolidxSnake; 07-21-06 at 10:28 PM.
When I logon to Windows, I press Ctrl+Alt+ELITE
i7-2600 4001MHz @ 39x102.6~ASRock P67 Fatal1ty Professional~MSI N580GTX Lightning 1536MB @ 1000//2400 @ 1.149v~8GB Corsair Vengeance DDR3-1600 9-9-9-24~256GB Samsung 830 SSD and 60GB OCZ Vertex~2x Western Digital Caviar Green 1TBs in RAID1 ~BFG ES-800 PSUCustom Watercooling Loop | Apogee GT, MCW82, MCP35x + Res, Thermochill PA120.2 and 120.3 (both rev1) w/ Gentle Typhoon AP-15s pull, 7/16"x5/8" MasterKleer, 100% Distilled Water with Iodine ---All encased in a Silverstone TJ07B-W
Join in on the fun! Heatware OCForums Metal Club member #13224
01-27-05, 09:03 PM #2Member
- Join Date
- Oct 2003
- CA
The steps that you've recommended for AS 5 can be used with Ceramique, as well.
01-27-05, 09:10 PM #3
Instructions from Arctic Silve site seem t be good enough + they have photos. Bah, even on syringes they say to visit their sire for instructions.
01-28-05, 07:03 AM #4I wouldn't recommend spreading the paste on the die with your finger in a plastic bag. That won't create a very even layer, and you want a good, even, layer on that die, which is why AS suggests something like a razor blade or credit card....something firm with a flat edge as long as it's clean.
Originally Posted by SolidxSnake
01-28-05, 10:36 PM #5
edited to accommodate changes
01-28-05, 11:55 PM #6It does seem odd but using your finger in a plastic bags is the method AS suggested for applying the compound. Personally, I use the spreader that came with my Alunina Adhesive to spread the regular Alumina.
Originally Posted by SAOverclocker
CPU: AMD FX-8320
HEATSINK: Corsair H55
MOBO: ASUS M5A97 R2.0
HARD DRIVES: SanDisk SSD 128GB • Maxtor 160GB Slave
MEMORY: Crucial DDR3-1600
POWER: Corsair AX760
MONITOR: Acer S231HL
VIDEOCARD: EVGA GeForce 650GTX
O/S: MSFT Windows 10 Pro
CLUBS: Callaway X-14’s King Cobra 440cc Ping Anser 5 KS
01-28-05, 11:58 PM #7Disabled
- Join Date
- Oct 2003
- Banned Camp
http://arcticsilver.com/instructions.htm
That covers it.
01-29-05, 05:23 PM #8
Originally Posted by Redstone
they said to do that to put it in the heatsink.. to fill the microscopic gaps... not on the CPUWhen I logon to Windows, I press Ctrl+Alt+ELITE
01-29-05, 05:28 PM #9Member
- Join Date
- Oct 2003
- CA
Yeah, but once you spread it onto the heatsink to fill the microscopic gaps, you remove the TIM from the heatsink again. I believe that process is known as conditioning or tainting.
01-29-05, 05:54 PM #10
Spreading on heatsik part doesn't include AS5 and Ceramique. At least it didn't when I read the guide before I applied paste.
There are many methods to apply paste. Unfortunatly, not all work as expected.
Perhaps putting AS5 on heatsink isn't bad idea, but it would be pretty hard not to remove some parts of it while spreading.
01-29-05, 05:59 PM #11Disabled
- Join Date
- May 2004
- Uk
I find it really hard putting the XP-120 on, i wish it had the bolt down method like my old SLK-900, i couldn't put it on verticly, had to do it at an angle, hope it spreaded the AS5 ok.
01-29-05, 09:40 PM #12I stand corrected. I read it wrong. It did seem odd using the bag for the CPU. Guess I wasnt breaking the rules!
CPU: AMD FX-8320
01-29-05, 09:47 PM #13Member
- Join Date
- Oct 2003
- CA
It's not required, but it doesn't hurt.
Originally Posted by Ven0m
Doing this can actually help prevent air bubble in the TIM, so I'm sure it spread the AS5 fine.
Originally Posted by Grov
07-26-05, 05:43 PM #14
Update with pics of how to apply AS5/Ceramique to different kinds of procs
and yes, holy thread resurrectionWhen I logon to Windows, I press Ctrl+Alt+ELITE
08-04-05, 01:24 AM #15
nbody ever seems to understand this, but even if your speading isnt pefectly even, it will make ZERO difference, because the paste gets SQUISHED between the heatsink and the core anyway, and it will all become even.
GIGABYTE GA-MA785GM-US2H
AMD Sempron 140 2nd Core+ Cache Unlocked 230x13.5= 3105mhz(stock voltage and HSF for now, clock to go higher soon)
2GB GEIL DDR2 1066 RAM
ATi HD4200 Integrated Video @600mhz, new video card coming soon
Seagate Baracuda 7200.11 320GB HDD
Ubuntu Linux x86
Windows 7 Professional x64
23.7" Hannspree LCD Monitor
