- Jan 21, 2005
- Owosso, MI, USA
Hey all...I am building a switching power supply for a 226w. TEC I am getting. So I have a few questions...
1. does the voltage of supplied to the tec matter or just the ampers?....basically....do I need 24 v and 9.5a or can i use 12v and 19a?
2. Is a switching psu the best option...or should I go linear?
3. What is the time constant on the standard 226w tec?
4. If I pulse about 50% of the time and run 28.9 v (basically 14.45v ) will that satisfy the tec.
5. anything else I should know before I burn up my proc?
Thnx for you help!
Thnx for you help!
