hitechjb1 said:Actually the Fortron 350W is not for short burst testing. I figured out it should be OK before a full setup with more components.
The Fortron 350W had been used to test the system for more than one day continuously without a single BSOD, system hang, ..., with the Winchester between 2.7 - 2.9 GHz priming, the 6600 GT at rated 525/1050, as well as one HD and one OD, all drawing 12 V current.
From an engineering stand point, the 12 V current rating of the Fortron 350W (12 mm fan) is marginal at that level (16 A rated).
I swapped it with an Antec True 550 which is rated 24 A on 12 V for now until the time I feel a 24-pin PSU with higher 12 V current is needed.
Let's move onto something else than just PSU.
Gautam said:Ah, really? My mistake. Most impressive. And Winchesters do have a lower power draw than Clawhammers and Newcastles.
Ok, let's talk about how you went against your own advice to leave the 10x multi open; banking on hopes of both the motherboard and memory to hit 300MHz, and the processor hitting 2.7 GHz....odds wouldn't seem in your favor but yet you defied them anyways
Yeah come on folks. Hitech's threads are a great resource, but a long read, crapping it with a flame war on the side isn't helping anyone.
hitechjb1 said:939 Winchester 3000+ vs 3200+
One can run the memory bus frequency slower than the HTT with minimal impact on memory performance,
for example, assume bios only has 1:1, 5:6, 2:3 memory_HTT_ratio
For 3000+, max multiplier = 9, memory_divider available = 9, 11,
For 3200+, max multiplier = 10, memory_divider available = 9, 10, 11, 12, 15
So if the CPU clock frequency is 2500 MHz,
one would get memory at 277 or 227 MHz with a 3000+ (x9 max),
one would get memory at 277, 250, 227, 208, 167 MHz with a 3200+ (x10 max).
As can be seen, the 3200+ provides more flexible matching of memory frequency for given memory modules. In addition, one can also get a high CPU overclocking in case the motherboard and system cannot handle high HTT for whatever reason. Say, if HTT is stuck under 260 MHz, with a 3200+, one can still get 2.60 GHz with the x10 multiplier, but with a 3000+, the highest CPU overclock would be limited to 2.34 GHz.
On the other hand, in terms of budget and price-performance, one can argue that a 3000+ is a better choice. Which CPU can potentially give higher overclocking is a luck of draw, due to random nature over the stock frequency specification.
If mothboard and memory modules used can handle high HTT (to 300 - 330+ MHz such as DFI Nforce4) in combination with high memory bus frequency (such as TCCD based modules), and especially the motherboard and bios can provide a wide range of memory_HTT_ratio (more than 1:1, 5.6, 2:3, 1:2 such as the DFI Nforce3 and Nforce4 boards), then a 3000+ would be almost as good as a 3200+ on air as 2.7 - 3.0+ GHz would not be a barrier due to the x9 3000+ multiplier alone.
The above argument assumes CPU's are from similar week/stepping. In many cases, newer CPU (more recently dated) may be preferred, especially if supported by results and statistics, probably due to some process, yield improvements or some not-yet-known reasons.
TimoneX said:Excellent results and a very methodical review. I'm curious have you tried that particular processor in any other boards? It would be interesting to note the differences if any in results between an nF3 & nF4 board with the same processor.
Edit: You guys are really polluting this otherwise very informative thread with this PSU debate.
Yep, just playing with you. I know you'd never make a short-sighted purchase.hitechjb1 said:In the early Nforce3, due to limitation of motherboard, maybe also memory and its controller, 250 - 280 Hz HTT were about the top, so a 3200+ would be more flexible and almost a must in order to achieve 2.5+ GHz on CPU.
Recently, the MSI Neo2 (NF3 Ultra), Neo4 NF4 and the DFI LP NF4, teamed with TCCD modules, all seem to deliver 300 MHz HTT and 280-300 MHz memory bus. Further, the DFI NF4 has more memory ratio for fine tuning in case.
So a while back, I already revised the choice between 3000+ and 3200+ as:
In general, the 3200+ is preferred since lower motherboard HTT and memory frequency are sufficient to deliver the same CPU frequency, especially if it is not sure what the board and memory can achieve a priori.
Since I assumed (not a simple assumption but with quite a bit of research) the DFI LP Nforce4 and G. Skill 4400 have a good chance to deliver 300+ MHz memory bus 2.5-4-4-x and the CPU target was 2.7 GHz, so I picked that 3000+ instead of a 3200+, also based on cost saving as Venice maybe around the corner. Anything above 300 MHz memory and 2700 MHz CPU are above my objective.
hitechjb1 said:BTW, how well do your 3200+ Winchester and Neo2 NF3 Ultra overclock? What week is the 3200+?
hitechjb1 said:Conjecture:
NF3 Ultra tops out lower on memory bus and HTT, but higher efficiency, usually around 90+ %.
DFI NF4 can attain higher memory bus and HTT, but lower efficiency. Mine is only 81% at 300-320 MHz, e.g. 8225 MB/s raw bandwidth at 318 MHz, has to check more data from others.
So there may be an intrinsic bottleneck somewhere limiting HTT and/or memory.
d'oh! I did mean 324MHz HTT. Neways question still applies. Have you tried a lower multi?hitechjb1 said:The dual channel limitation may well be within the CPU itself or the interface between the CPU and the motherboard. For Nforce3 Ultra, the max is probably lower than the current Nforce4.
My current DFI NF4 Ultra is hitting a limit around 324 MHz for both HTT and memory 10-4-4-2.5 1T (very good memory), 2.92 GHz for CPU, not 292 MHz HTT.
I am working on finding out why, be it CPU, CPU's memory controller, CPU/motherboard interface, memory, .... Since lower memory frequency and relaxing memory timing won't help, it seems to be not memory related (at 324 MHz dual channel , efficiency only around 81% though).
Conjecture:
TimoneX said:...
Is it possible this efficiency loss is due to bank interleaving being disabled? I recall seing a screenie of this option on the DFI bios. Have you confirmed whether it's working or not?
Super Nade said:hitechjb1:
What are the stable versions of the same results?
Also, I request you test if TCCD chips like high voltages or not.
/*Will delete this post if necessary*/
Gautam said:d'oh! I did mean 324MHz HTT. Neways question still applies. Have you tried a lower multi?
I *think* that the 81% efficiency is common for your speeds. The oddity with the 939 A64's is that the CPU speed actually bottlenecks the memory bandwidth, because the controller is loaded too heavily at low CPU speeds. You will probably get similar bandwidth were you to run the memory at 324 or 292, because of this odd issue where the CPU speed actually bottlenecks the memory bandwidth. If you were to reach 324MHz memory speed along with the processor being at 3.24 GHz, you would actually see more memory bandwidth, as the memory controller scales up with the CPU speed. It's an odd phenomena that hasn't occured in any type of architecture prior to the dual channel A64's; CPU speed actually determining memory bandwidth.
c627627 said:Here's a question I always wanted to ask you and we can use this overclock as an example, in how many increments did you get to such a high overclock, I usually corrupt my Windows registry because of the 'too much too soon' impatient approach....
c627627 said:yah, confirmed no PR jump as of today.
Also, finally an answer re Venice:
The scenario from this September 17, 2004 thread about Winchesters will repeat itself with Venice:
http://www.ocforums.com/showthread.php?t=329781
In it, Winchester appeared in one or two shops, then the price sky rocketed and Winchesters remained scarce until weeks and weeks later.
So:
Venice will have full availability in Q3 2005 and limited availability (a store or two here & there) in Q2 2005...
so either place a pre-order from a reputable store like with Winchesters or buy on the day of release, do not wait or you'll likely pay more if you wish to get them before full Q3 2005 availability.
