- Mar 23, 2004
i have just hooked up my mach 1 to my Intel system and the lcd is saying
-40 but MBM is saying that my cpu temp is -12. Then after about 15mins. the temps on the mach 1 started to clamb pretty fast so i shut it off. Here are the spec's.
IC7 Max3
3.0 SL7KB Pessy
520 ocz power supply
ocz pc 4400 mem
120 sata hard drive
9800 xt video card
Plus i dont know if this will help or not but the compressor is hot very hot like it could burn you hot
IC7 Max3
3.0 SL7KB Pessy
ocz pc 4400 mem
120 sata hard drive
9800 xt video card
