- Jun 19, 2002
How much of an effect does running your RAM asynchronously have for an A64 939 system?
Zero. RAM speed is dependant on the CPU speed and not the chipset. Thus A64s take no penalty going asynch other than the lower dram speed.Gregory_WE said:How much of an effect does running your RAM asynchronously have for an A64 939 system?
Overclocker550 said:running async takes a hit because of lower bandwith. I dont know why people keep insisting there is no performance hit, if that was true, why not just buy pc2100 ram and run the ram at 100 divider instead of 200? You need about 150MHz cpu to make up for going from 200 to 166 divider due to loss of ram bandwith
glock19owner said:I fully agree with OC on this one...
Now running async might not hurt the CPU performance...but it does hurt the overall system performance from the lower memory bandwidth...so any real world app or such that needs/wants more memory bandwidth then CPU Ghz/Mhz is going to perform less then running at 1:1 with a lower FSB/HT with better memory bandwidth...
Steven4563 said:they are not way off. i also a agree with them because ive tried it and i KNOW for a FACT that theres alittle bit of a proformance hit theres not an incrediable amount but theres some
Simple way to prove it is to get someone to test a 3500+ run it at 229 x 11 at 1:1 and 280 x 9 at 5:6 that way the cpu and ram frequencies are virtually identical and if running async does give a performance hit then it would show up in benchmarks.Overclocker550 said:running async takes a hit because of lower bandwith. I dont know why people keep insisting there is no performance hit, if that was true, why not just buy pc2100 ram and run the ram at 100 divider instead of 200? You need about 150MHz cpu to make up for going from 200 to 166 divider due to loss of ram bandwith
Miguita said:On the platform in question though, one has the option of adjusting the memory speed and HTT independently of each other, without losing performance due to latencies, as the RAM doesn't use the HTT. I'm not saying one should lower the memory speed just for fun. But if the memory cannot run as fast as the HTT, it can be adjusted so that it still runs stable, without losing performance due to the latency-issues that are seen on platforms that have an FSB. Thus allowing higher CPU-clock (on a locked CPU). And again, there is no such thing as "running in sync" with A64s.
warlock110 said:do you know how much of a hit it would be? is it as big as 200mhz? because if it is then it's pointless to hit high speed cuzz lower speed with ram sync will result in lower votage, lower temp, more stablity, and all that stuff.
