- Mar 15, 2004
- Swindon England
Have just treated myself to a Vapochill XEII (intel socket lga 775) would like some views & sugestions on a power supply, will be using for games & running seti.
mach's dont draw that much power from the PSU. that molex acts mainly as a sensor for whether the comp is powered up or not. note how the lcd and control system run when the psu is off, they run off the mach's seperate power line.Sucka said:PCP&C 510 runs my Mach II, system, water pump, all that with rock solid rails. Little pricey, but worth the money.
yeah, that's what i thought, that's why i suggested the heavier supplies...hawtrawkr said:pretty sure all the vapochills except the ls run off the psu that powers the mobo and everything else.
in that case, something like a fortron 530 should be fine if you dont want to put out the big $$ for a supply.snvpa said:nah the xeII uses its own powersupply so no real need for a big time heavy hitter. I must say though that since i got an ocz600 I'd never use anything else. They really are that much better.
