- May 22, 2005
- NY
Mr.Guvernment said:for $80 you can not go wrong!
Without a PSU it is $50 at newegg though.
I got one as well, I haven't gotten my mobo/cpu/vcard yet so I can't confirm how well it works, but I will say that after plugging in an old motherboard/psu to test it they ran very quiet on low and an audible whisper on high (with the door open). I don't think you will need to replace the fans unless you want some loud super-high cfm fans. I also believe that there is room on the bottom front for a fan as well, only thing is that you might want to make that an intake, but then you would need to turn the other fan in the middle around (if I remember correctly) so you don't cause an interruption in air flow.Jacobman said:WOW!!! Your guide gave more information then i have read on the net so far. I have 1 question though, besides the 3 stock fans that come with it, you can only put 1 120mm fan in the upper front for intake and is that a 25mm thickness? So no 120mm fan can be placed in the front bottom? Are the stock fans pretty good for airflow or should i buy some for it?
Also on the sight CJ4 said to buy it from they say it only comes with 2 fans, is that an error? Im guessing it is.
Mine came with 3 fans, the top and back were 120x25's and the bottom one in the middle is a 120x38 and they are pretty quiet on low. I tried squeezing a 120 in the front lower grill but there is nothing to mount it to, you can put one there but you will have to make some kind of mounts for it. I set mine up so that the middle fan is pulling air from the front across the hard drives. I left the center trays out and let the front middle fan pull air in towards the motherboard. The back and top are exhaust.Jacobman said:WOW!!! Your guide gave more information then i have read on the net so far. I have 1 question though, besides the 3 stock fans that come with it, you can only put 1 120mm fan in the upper front for intake and is that a 25mm thickness? So no 120mm fan can be placed in the front bottom? Are the stock fans pretty good for airflow or should i buy some for it?
bigdaddyTank said:Mine came with 3 fans, the top and back were 120x25's and the bottom one in the middle is a 120x38 and they are pretty quiet on low. I tried squeezing a 120 in the front lower grill but there is nothing to mount it to, you can put one there but you will have to make some kind of mounts for it. I set mine up so that the middle fan is pulling air from the front across the hard drives. I left the center trays out and let the front middle fan pull air in towards the motherboard. The back and top are exhaust.
Jacobman said:Are you using the little black air duct thing? Also can it hold 2 80mm fans or just 1?
Yea it only takes one fan but it didnt fit with the fan on so I just left the entire duct out.Jacobman said:Are you using the little black air duct thing? Also can it hold 2 80mm fans or just 1?
That should fit fine. The fan in the bottom of the case is setup to blow across the powersupply and pull air from the front of the case, the stock fan is a 120x38 and the back of the case all the way around the powersupply is vented so it should cool your PS just fine. I have the Fortron AX500 and I mounted it with the main fan on the PS pointed up.Spanko said:Im looking at buying a P180 but I have doubts about using my powersupply in it, can any of you that have one let me know if this PSU will fit, and be cooled properly in a P180? http://www.svc.com/sf-550psu-blu.html Mostly im worried about the single fan, in the P180 it doesnt look like it will get any air, also if it helps, I currently have a Lian Li PC70.
Mr.Guvernment said:Centurion 5
Wwing49 said:RAIDMAX SUCKSSSSS!!~^@$*#$^%#W4432985234!! I know because i have one now... Soon to upgrade to a P180
