- May 26, 2005
- Northern Virginia
My venice is running at 2.52GHz 6:5 divider at 1.52v and Prime95 stable for almost 7 hours (choose to end test). I'm running my memory at 2.5-3-3-5 @ 2.85v. When I try to do 2.61 @ 1.52v it fails Prime95 fairly quick and it takes 1.62v to run for however long w/o any errors and memory at 2.5-4-4-7 2.85v(rated timings). 9x300 @ any voltage will not even post. If I run the 133mhz memory divider I can load windows @ 9x300 1.62v, but it fails Prime95 almost instant. I've tried relaxing my timings a little bit as that didn't help. I also have ran CPU Burn-in twice for 8hours and 9hours with the processor running 2.52GHz @ stock vcore. Should I run cpu burn-in for ~18 hours in hope to break this plateau or is my venice just not the badass OC'er I was hoping it would be. I'm also contemplating about dropping this stock cooler and getting an XP-90 and seeing if that won't improve my OC. I'm also thinking maybe my psu is the problem since I noticed my 6800 will barely OC above stock settings unlike before on my athlon xp setup. Any advice is appreciated.
System Specs:
A64 3000+ venice 2.52GHz 1.52v
1GB GeiL DDR500 @ 2.5-3-3-5 2.85v
MSI Neo2 Platinum (1.8 Bios)
eVGA GeForce6800 (12p/6v)
WD 120GB
Enlight 420watt (only 18a on 12v)
System Specs:
WD 120GB
