I responded to your PM, but I will also post here in case other people in the same situation are trying to figure this out too. The system bus speeds of Intel and FSB (front side bus) speeds are a little confusing.
Ok, 400 and 533 is the system bus speed because P-4 systems use a quad pumped system bus. But, 100 FSB X 4 = 400 system bus and 133 FSB X 4 = 533 system bus. For example, a 2.4B is a 533 bus processor. It uses a 18X multiplier and 133 FSB (18X133=2400 or 2.4 gig). The rest of the chipset runs at 533 bus speed, but that is not used to figure processor clock speed. So, 100 FSB is the default speed of 400 bus CPUs. If you put a 533 bus CPU in your motherboard, it will probably run at 100 FSB by default. So, that 2.4B will run at 1.8 gig unless you manually set the FSB to 133, then it will run at 2.4 gig. Make sense now?
A 533 bus CPU will work in your mobo, worse case is it will run slower than advertised speed. Looks like you can manually set the FSB to 133 to make it run at it's normal speed. That is what we do to overclock, we raise the FSB to make the CPU run faster.
