Its running at 3.6Ghz now with 1.6v being fed to the chip, memory is at 240. Its running an XP-90 heatsink with a 90mm Panaflo on top of it. In the summer (now) I keep the case side off to aid cooling....so its idling at 41, with the case on it idles at 44 or so.
Its not quite PRIME stable at this speed (would be if I threw more volts at it) but games, benchmarks generally run fine and without incident.
My problem here is that two times in the past few weeks its done a soft reboot on itsself, which I can only assume was heat related.
At what cpu temperature would I begin to see heat-related problems occurring like soft reboots and such.....
